Question about Select Jazzy Used Electric Wheelchair
I AM IN MOROCCO FROM NEW YORK. MY JAZZY 1100 ONLY CHARGES WHEN THE BATTERIES ARE CONNECTED DIRECTLY TO AC AND NOT WITH THE POWER PLUG. WHAT COULD BE THE PROBLEM? THANKS.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 347 Answers
Hello,if you visit the people who built the wheelchair,Shoprider for example is where i went for 1 solution & there i was able to download a PDF File of the troubleshooter,you should also be able to print it off for your future records,there was so many solutions there,pics of the joystick with different lights lit up and a solution beside each 1.i am disabled myself,i hope i have been of good help Colin.
Posted on Jul 09, 2010
Why when charging battery seems to drain instead
The 3rd wore of the charger plug tells the controller to shut off all power to the scooter while the charger is on. Check the plug for a broken wire
May 17, 2014 | Pride Jazzy 614 Hd JAZZY 614HD
My jazzy is used but i bought new batteries for it but the key pad will only cut on when the charger is attached. and wont cut on at all with out the charger.
super hmmm new batteries? well I would check the battery connections because you should be getting power to the joystick. The charger is providing power thru your joystick to be able to turn it on. Now when you plug in the charger are you getting any movement on the meter at the rear of the chair? If not but staying at zero then the charger is not charging the batteries and your batteries are not hooked up correctly. You will have to remove the seat and cover over the base to have access to the batteries check all the connections and make sure that if the plugs are colored that the red and white plug is plugged into the red and white plug going to the front of the chair and that the black and white plug is plugged into the black and white plug going to the front of the chair. If the wiring is ok then get a meter and read the voltage across each battery they should read 13+ volts fully charged. Plug in the charger and read the voltage at the batteries again if charging then you should read 16+ volts. If the voltage doesn't change then the charger isn't working correctly and if reading a good voltage then the batteries are bad and need to be replaced. Hope this helps
Apr 17, 2011 | Pride Jazzy Select 6 Indoor Power...
Jazzy Select 6, Charge batteries. Green light comes on...run for a few seconds and goes directly to red light. Chair will continue running. One battery shows a charge of 12 volts the other 13 volts. Has...
Hi You need new batteries If you have a battery store near home or an interstate battery distributor have them get you 2 U1 batteries. Charge before use and you should be go to go for another 3 years or so Hope this helps
Feb 10, 2011 | Pride Jazzy Select 6 Indoor Power...
Laptop battery is not charging
Hi, this information represents a basic troubleshooting guideline. Refer to your user guide for specific charging and connection instructions. Manuals may be available online in the Support Web site of HP.
Remove the battery from the computer.
Confirm the battery contacts are free of any foreign material that may prevent charging.
Reinsert the battery into the computer.
Verify that the AC adapter cord is properly connected and plugged directly into a known working AC power outlet.
NOTE: If the battery charges correctly when the AC adapter is plugged directly into an AC power outlet, but not when plugged into a power strip or surge protector, the problem is with the power strip or surge protector and not the computer battery or AC adapter.
Verify the correct AC adapter is being used.
Ensure the AC adapter box power light is on. This will be an illuminated green light.
If the AC adapter power light is not on, the AC adapter and power cord will need to be replaced.
Verify the charging indicator is illuminated on the computer.
If the issue still exists, install a different compatible HP battery, if available.
NOTE: If a replacement battery charges and operates correctly, the problem is with the first battery.
If neither the original nor a replacement battery charges, service may be required for the computer.
Dec 21, 2010 | HP 417035-001 - HP Pavilion dv2000 Series...
When I replace my power chair jazzy 1100 batteries is it normal for the amp meter to start at 0?
The meter will not indicate anything until you have the charger plugged in and will move to zero when fully charged Hopes this helps you
Aug 24, 2010 | Pride Mobility Products Health & Beauty
I have a new e627 used only once before today. Battery connection was partially out and screen indicated low battery. After five minutes screen went black and now I cannot power up.
Maybe your battery is totally drained.
Try to connect the AC adaptor of your laptop and plug it to the wall outlet and let it charge for 3 hours or more. When you plug it on the wall socket, it won't show the laptop's led blinking since it was totally drained. But after 3 minutes or more, it will start to show the blinking led to indicate charging. When blinking stops led light disappears, it is fully charged and ready to use.
Remember: Do not use your laptop while it is plugged in to save your battery life. When at home, remove the battery while it is fully charged and plug the AC adaptor directly to the wall outlet. It will still work without the battery as long as it is plugged directly to the wall socket.
Feb 23, 2010 | Computers & Internet
Select Jazzy Used Electric Wheelchair Logo
78 people viewed this question
Top Select Health & Beauty Experts
wcdoc1953
wcdoc1953
Scooter Doctor
Scooter Doctor
gnshome
Level 1 Expert
Are you a Select Health and Beauty Expert? Answer questions, earn points and help others
