Question about John Deere 420,1020,2010,2020,2510,2520 Tractor Float
Ride on lawnmower lr35 just clicking and wont start
    Problem Solver:
  • 10 Answers
Check battery and starter cables for tightness and corrosion. also battery voltage.
Posted on Jul 25, 2010
Lawnflite 630 ride on mower. Key to turn how do we start the engine?
hi,
did you lose your key? here is a link to buy one, they are generic so you might be able to go to a local lawnmower shop for that. if it wont start with the key check your safety switches at the blade control lever under the panel and under the seat. riding lawnmowers that sit out get rusted all over, look for rust and bad connections under the service panel and battery compartment, sand connections with sandpaper..
https://www.partstree.com/parts/mtd/mowers-lawn-garden-tractor/136-630-331-lawnflite-lawn-tractor-1986-forest-city/electrical-without-headlights
Jul 31, 2017 | Garden
HOW TO FIX LAWNMOWER
I will need a few more details about your no start condition. Does the engine just click or does it turn over and just won't start? What are your battery amps? Did you check for spark? Do you have fuel?
Jul 16, 2014 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
MY RIDING LAWNMOWER STARTER JUST CLICKS.I BOUGHT A NEW STARTER AND IT DOES THE SAME THING.
didnt specify type of rider but can b 1 of a few different problems-the clicking is the relay to the starter-- 1st check that motor turns if motor bound or seized starter wont turn it over -check that starter gear and flywheel mesh correctly if not might have to shim or adjust ,next check battery {full charge}and connections ,wiring ,and the fuses for corrosion and or damage.check the safety switches next the seat ,brake,and blade on, these switches will not let motor start if damaged ,activated,or bad wire.
Sep 20, 2012 | Ariens Garden
I have a briggs & stratton riding lawnmower it cuts for about 30min, then cuts off and wont start untilit cools off
Slacken off the filler cap when it starts to die, if it picks up again then it could be a blocked tank breather, it could also be an ignition coil breaking down with the heat
Apr 13, 2012 | Craftsman Garden
I have a riding lawnmower. Troy-Bilt Bronco. It
check the battery i.e. load test it they dont last long,most of 2 seasons,then if this is o.k. clean all terminals as any corrosion will cause this also and make sure all connections are tight,it doesn't hurt even if theres no corrosion to loosen and re-tighten all connections
Apr 09, 2010 | Garden
Riding lawnmower wont start
yeah i do... you need to remove the cables and hook them up the right way.. the red cable to positive post ( + ) and the black cable to the negitive post ( - )..good luck
Apr 03, 2010 | Craftsman 20 hp 42 in. Deck Yard Tractor
Ride on lawnmower isnt starting.
You may have a bad starter - the solinoid is "clicking" but not engaging. Remove the starter and clean it up and connect it to 12 volts to check if can turn. If not then buy a new starter and replace it out.
Aug 03, 2009 | Garden
Ranch kind 16.5 horsepower riding lawnmower
A dead battery would be top of the list by far, followed by solenoid, keyswitch, wiring, starter in that order.
May 29, 2009 | Garden
Illustrated parts list for john deere 102 riding lawnmower
Go online to www.johndeere.com click on residenial tractors,then click on services and support. You should be able to get an answer there. Otherwise contact them through email.
Apr 08, 2009 | Garden
John Deere 420,1020,2010,2020,2510,2520 Tractor Float Logo
98 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
