Question about GE Refrigerators
Warning message "C1" appearing on info pannel - food not properly frozen or chilled GE Profile American Fridge Freeaer
  • carson_gilly Jul 09, 2010
    thank you - very helpful
  • 6,784 Answers
HI. I will need your entire model number before we can continue. This will help me identify with your model. Please post the much needed information, asap.
Posted on Jul 08, 2010
  • 3 more comments
    The Fridge freezer is GE Profile ... the following is also on it :tfg28zfc .. it was bought in the UK.
    Hope this helps.
  • Michael Masters
    Michael Masters Jul 09, 2010
    If you are not hearing the compressor cycle on and off in intervals and there is no air flow present inside the unit, this will confirm that there has been a severe malfunction within the units assembly. You will need to check the following areas for faults:
    1. Compressor- Make sure this unit is functioning. if it is not cycling as designed, this will be the culprit. If it is cycling but very hot to the touch when operating, check the condenser coils for debris and clean them if necessary.
    2. Compressor start relay - This is the main on/off switch that is attached to the side of the compressor. This relay, when energized by the main control board, starts the compressor. if the relay has failed, it will not start the compressor, thus, rendering the unit inoperable. Pull the relay off and shack it. If it rattles, replace it.
    3. Evaporator fan - This is a very important part of the evaporator core. This is the principal air mover of the unit. If this fan fails, the inside freezer and refrigerator will not cool, at all. You will need to remove all the freezer shelves and content to access this unit. It is concealed behind a panel inside the back section of the freezer compartment. Once the concealment panel is removed, you will expose the core and fan. the fan can be tested with a multimeter for proper continuity. You can also jump the terminals with a jumper wire to see if it is still in working order. An external power source will be needed for this test. if the fan fails the test, replace the fan motor.
    4. Condenser fan - This is also a very important fan. This fan is mounted near the condenser coils and can fail. You can test it in the same manner as the evaporator fan. replace the condenser fan if it proves to be damaged.
    5. Main PCB(Printed Circuit Board)- This is basically your main power controller. This board routes power to all the fans and compressor unit located in the assembly. it also routes power to the lights and ice maker/dispenser, as well. This will be the most expensive repair, in this case. If all the above areas prove to be functional, the main PCB will be the culprit. You can easily locate this board. It is usually mounted on a bracket, near the compressor platform, or behind a concealment panel on the rear of the unit. Once you have gained access, visibly, inspect the board for burn markings at the relay mounts and jumpers. check the entire circuit board for discolorations like brown marks or black burn marks at the plug-in connectors. If this refrigerator is totally dead, this will be the cause.
    6. Monitoring thermostats - These are located in each compartment. Replace each thermostat if all above checks out ok.
    You will find the culprit in one or all of the areas stated above.
    Standing by..
  • Michael Masters
    By the way; I noticed that your model number was slightly incomplete. There are three characters missing from the ID tag. Please post the entire model number, if possible.
    Thanks..
  • Michael Masters
    • Another additional check point that I forgot to post will be the Condenser coils. These coils may be rear mount or floor mount. In either case, they should be inspected for a filmy coat of lint or debris. If this is present on the coils assembly, they should be cleaned with a brush or long wand vacuum, if possible. It is very important for these coils to be clean, in order to allow them to dissipate heat. A dirty set of condenser coils will not allow for a proper functioning unit of this nature.
  • Michael Masters
    • Be sure to unplug the unit when cleaning the coils
Why does my GE Profile Arctica model #PS123SGMABS ice maker not work?
water hose is frozen up, leave door open for a while, but first put frozen food into fridge section.
Sep 08, 2014 | GE Refrigerators
Fridge won't get to 37 degrees, Fridge is freezing my food.
if freezing food it must be 32 deg or lower . if you need to get fresh food side warmer the adjust tempt . if it will not adjust then the control must be frozen in the open pos and will not close . so replace the cold control . or if more info is needed then i need model # to help mm .. hope this helps .
Sep 22, 2010 | GE Refrigerators
My fridge keeps freezing my food
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Oct 07, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Same problem
could be the thermostat is it on ? compressor could be out u need service find some coolers to save the frozen food. Tom
Jun 17, 2009 | GE Profile PSW26P Stainless Steel Side by...
Our GE Profile Model PS123NG/PS123NS came brand
probably a loose thermister. The thermister being not attached to the evap coils tight might not be relaying back the proper resistances info for the control board to make a propper defrost determination.
May 15, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Ge profile side by side 'fridge
Evaporator fan motor and main Pcb , the fan motor goes faulty and then burns out a resistor on the main pcb at the back.
Aug 12, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Fridge not chilling
check the temperature setting recommended by the mfg. you will find all the info. in the use & care guide.
is it just the fridge or is the freezer acting up as well?
Apr 05, 2008 | Frigidaire 24 in. FDB1050REC Stainless...
Refrigerators Logo
65 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
