Question about VinoTemp VT32TEDS2Z (3 cu ft) Wine Cooler
We purchased the Vino Temp VT32TEDS2Z about 15 months ago, and we've had nothing but problems with it. First, both fans went out and were replaced. Now the refrigerator has quit cooling. One side cools to 82 degrees, the white wine side is stuck at 68 degrees. Do you know if this problem is fixable? If so, how? If it's not fixable, please recommend a reliable, quiet wine refrigerator and approximate price range.
  • 4 more comments
  • SusieQ1010 Jul 14, 2010
    Not particularly. It appears there is no solution to this problem. It confirmed that we have a "lemon" and that we'll have to pursue this with Vino-Temp.
  • Anonymous Mar 11, 2014
    reset service lights on porsche 3l tdi cayenne
    Hi, I have a Technogym crosstrainer with touch screen and built in TV/Radio tuner. The (+) & (-) symbols on the bottom are getting harder and harder to initiate for tension adjustment. if I press hard and move my thum in a circular motion they will work but i'm afraid of damaging the screen, can anyone please advise me if cleaning or a hard reset will sort this? if it will does anyone know where I can find out how to hard reset as this came with no instruction manual. thanks in advance. Iain
    the centrol locking on the passager side dont work is it simple to fix.
    many thanks
    how to replace tail lights
    George Hoover wet cleaner won't work
  • 677 Answers
Hi,you can use this link to see testimonies of the products you will like to buy.
(wize.com/refrigerators/brand/vinotemp).
Take care.
Posted on Jul 08, 2010
  • 3 more comments
  • ikechukwu joshua
    ikechukwu joshua Jul 08, 2010
    (compactappliance.com/VT32TEDS2Z-Vinotemp-32-Bottle-Dual-Zone-Wine-Cooler/VT32TEDS2Z,default,pd.html)
    You can also use this too.
    Replace the ADC board. That is the problem i had.
    Take care.
  • SusieQ1010 Jul 08, 2010
    What is the ADC board, and how much does it cost? Also, how do you install it?
    I really appreciate your help!!!
    Susan
  • ikechukwu joshua
    Hi,it's almost to the price of a new one, ADC board in inside the wine cooler.
    I would advice you go for a new one to save you further stress and more expenses,
    Take care.
  • SusieQ1010 Jul 09, 2010
    We've placed the wine refrigerator in an enclosed space (3 sides) under our wet bar. We pulled the refrigerator out several inches from the wall to allow warm air from the fan to circulate. Is this enough room for the air, or do we need to place it in an area open on 3 sides to allow the refrigerator to exhaust warm air from the cooling unit?
  • SusieQ1010 Jul 12, 2010
    Hi, Kachi,
    Can you please look at my July 9 question re: the placement of the refrigerator.
    Thanks very much. If I've outstayed my welcome, please let me know.
    Susan
The engine Temp gauge got real close to "H"but went down soon as i got rolling.Also engine cooling fans not coming on. even when i engaged AC. the fans are electric. . .?
The reason that you drive and engine cools down is that cool wind is blowing in the grille in front of the car and when you stop, that natural wind stops cooling it down.
First check the fan fuse. If it is OK check the fan itself: just apply wires on the connector of the fan and attache it to the battery (dont mix "+" and "-") If fan will not start, replace the fan motor. If it starts check for the Fan Motor Relay
Oct 27, 2015 | 2008 Ford Escape
1999 grand cherokee laredo overheating when idling for 15 min. or so. Not when driving, everything ok. radiator replaced about 8-9 months ago, water pump pretty new, and extra electric fan worked on about...
Chanches are it is probably the fan. Anything over 15 miles an hour the fan is no longer needed. I would get a cheap hydrometer and make sure your antifreeze is still good.
Oct 18, 2012 | 1999 Jeep Grand Cherokee
Brand New Heat Pump Compressor fan turns on then off after only seconds.
What is the model number of the outdoor unit?
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Jun 09, 2017 | Heating & Cooling
Vivitar camera not turning on
Unfortunately, these VINO (Vivitar In Name Only) cameras are cheap no-name cameras. The original Vivitar company went out of business decades ago and the name was sold to a manufacturer of crummy hardware. If you just recently purchased this camera, take it back for a refund. If you have had it for a while, then you've gotten your money's worth out of it and it's time to buy a new camera. I would suggest spending a little more and buying a Canon or Nikon camera.
Nov 27, 2011 | Cameras
I have a all in one or complete unit the fan motr
hopefully you replaced motor with the same Rpm HP Volts and made sure the rotation of fan was correct.. Might have a bad/defective motor I would take it back to whomever you purchased it from as the should exchange it. Good Luck
Jul 21, 2010 | Heating & Cooling
I have a 96 honda accord and the fan runs after I turn off the car for 15 minutes. I just replaced the thermostat
That is normal but on the "long side" of normal. If the engine temp is good while driving, the temp sensor may be slightly out of range, but if its either very hot outside or the engine is running hotter than normal that can influence it as well. That part, you have to consider as I can't see what is going on there.
Sep 25, 2009 | 1996 Honda Accord
I have a RCA HD50LPW42, Rear Projection tv and my bulb went out after two years is that a good amount of time for the bulb to last. also I want to know about the fan. Does the fan only come on when the tv...
2 years is normal, I`ve seen some fail in 12-15 months, fans run when cabinet interior is hot, they are controlled by temp sensors located inside the set, video-tek
Jun 04, 2009 | RCA HD50LPW42 50" Rear Projection HDTV
VinoTemp VT32TEDS2Z (3 cu ft) Wine Cooler Logo
198 people viewed this question
Top VinoTemp Refrigerators Experts
Vernon Taylor
Ilia Bichin
Are you a VinoTemp Refrigerator Expert? Answer questions, earn points and help others
