Question about Nikon Photography
Removing Nikon FM2N top plate
I am trying to remove the top plate on my Nikon FM2N camera. In particular, I do not know how to remove the rewind crank but help in removing the wind-on lever and shutter speed knob would also be appreciated.
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Nikon Master
  • 102,366 Answers
Unscrew the rewind knob and remove a circlip under it (You may need to grind the tips of a pair of round-nose pliers for this). Remove the disk and pull the rewind shaft stop off the hub (a spring and flat plate). Remove the two screws. You'll need a special tool to remove the little stud the shaft stop was pivoting on. Take a 1/8 inch screwdriver and grind a slot in the blade. Use this tool to remove the stud, then remove the three screws from the plastic cover ring.
Do not remove the center screw from the shutter speed dial. Remove three screws from the side of the dial and pull off the grip ring.
Posted on Jul 08, 2010
  • kakima Jul 08, 2010
    I forgot to say: You can order a service/parts manual for the FM2N fromhttp://uscamera.com/fm2.htm
I have the same problem. An N70 with the err message. If the rewind buttons are pressed (without any film in the camera) the camera tries to rewind but will only stop if the back is opened. I tried...
The Err message alone indicates that a malfunction has been detected, and the manual recommends to fire the shutter and check for the message to clear. If it does not, to contact a Nikon Service Rep.
If it is Err + E, the film did not advance properly and needs to be reloaded.
May 03, 2011 | Nikon N70 35mm SLR Camera
My shutter mirror keeps closing on my nikon fm2. when i press the button to snap the picture, the shutter mirror should go back to the down position. It closes and stays closed until I have to take the...
Hi jandklandry, Sounds as though the cushion the mirror hits on the up swing is tacky thus holding the mirror up. Maybe you can yourself fix it however, I would suggest sending it to Nikon for a complete CLA (Clean Lube Adjust). You have a nice camera allow Nikon to do it proud.
Aug 20, 2010 | Nikon FM2N 35mm SLR Camera
My nikon fm2n shutter speeds are not working!all the speeds stay the same is it costly to get fixed?
Sorry, yes. To replace a shutter unit in that camera is quite expensive. $175+ since the part is very rare and expensive alone
Nov 03, 2009 | Nikon FM2N 35mm SLR Camera
Don't know how to open door latch on nikon 35mm SLR camera
You haven't stated which model you have, but generally most SLR's open by pulling upwards on the film rewind crank (the knob on the left side of the top-plate as viewed from behind). If this doesn't work then add the exact model as a comment to my answer and I'll try to give you specific instructions for your model.
Jun 15, 2009 | Nikon N70 35mm SLR Camera
Don't know how to rewind film
Hi there.
The film should auto rewind when it reaches the last picture and its been taken.
Take a look in the camera's menu.
Good luck and thanks for using FixYa!!
May 21, 2009 | Nikon N80 35mm SLR Camera
Nikon FA top plate removal
After unscrewing the rewind knob, remove the circlip under it. Remove the disk and pull the rewind shaft stop off the hub (a spring and flat plate). Remove the two screws. You'll need a special tool to remove the little stud the shaft stop was pivoting on. Take a 1/8 inch screwdriver and grind a slot in the blade. Use this tool to remove the stud, then remove the three screws from the plastic cover ring.
Mar 22, 2009 | Nikon FA 35mm SLR Camera
My Minolta 7000 camera's rewind switch won't budge.
I have seen this on several of these, a small bit of plastic breaks off on the top cover and jams the rewind switch assembly.
To repair this you would have to take the top cover off and then remove the rewind swtich assembly from the top cover remove the bit of plastic and hey presto. You will find after removing the bit of plastic you will have to hold the lever to keep the camera rewinding, the lever will no longer stay in place as it used to (the bit of plastic held it in place)
Post back re Palmyman if you want to attempt this
Oct 12, 2008 | Minolta Maxxum 7000 35mm SLR Camera
Want to remove top plate of nikon fe
It's not very easy- you have to remove the rewind knob and dials at the left end of the cover and the speed dial and winder arm at the right side. Then the 5 small screws around the cover.
It is a delicate task because under the cover there are some very sensitive electronics. If you are determined to go ahead with it then your best bet might be to get a service manual.
Nov 16, 2007 | Photography
Nikon N50 SLR film
Hi: You may want to try changing the aperature setting,or removing the lens,then re-installing the lens. Good luck.
May 29, 2007 | Nikon N50 35mm SLR Camera
Photography Logo
434 people viewed this question
Top Nikon Photography Experts
Ric Donato
Bart Pulverman
Are you a Nikon Photography Expert? Answer questions, earn points and help others
