Question about Miranda Kaleido-Alto-A Virtual Video Wall Processor KALEIDOALTOA
My Miranda Kaleido Atlo display is always distorted after boot up. But is usually fixed after 1 hour or so maybe after the system's heated up. Is there any way to fix this? thanks
Screen is orange and pink where it should be white
Try updating graphic drivers from the HP website.
HP has a lotta tools inside, maybe one lets you run an updater HP Pavilion dv6405us Notebook PC Drivers Download
Feb 28, 2014 | HP Pavilion DV6405US Laptop
My IBM Thinkpad T30 2367 has distorted display(bios are up to date)whats the solution?
if the distortion is always constant from boot, it could be your display hardware (LCD) has problem, have it checked by service center
Oct 19, 2009 | IBM ThinkPad T30 2366 Notebook
Fossil Kaleido Watch LI22248 replacement batteries???
Depending on the age of the watch it could have a ECR series battery over the top of the 377 powering the movement or it could have 2 377's in the circuit board over 1 377 in the movement.
I always recommend taking Fossil watches to a certified repair shop that can re-seal the watch so you dont void your 12 year warranty and the watch remains water resistant and resistant to small particles.
Sep 01, 2009 | Fossil Sport Auburn University LI2248...
Amazing Boot problem !!
stick another card , agp pci or whatever you can get easiest in a slot . if it works....hmm bad onboard video. if not could be mb , motherboard , over heating or cpu. are fans spinning full speed ? reboot then go into bios, usually del key. and check motherboard temp. after failure.
Jan 18, 2009 | Computers & Internet
Distortion of images on my laptop screen
i may be due to over heating of components like heat sink. or the problem with the connecting display cable. check it out
Jan 08, 2009 | Compaq Presario Notebook
My acer aspire 4530 has always be given a distorted display can someone help me resolve this problem?
For, distorted display problem there are 2 possibilities
1> your display drivers are not installed properly so try to remove or uninstall driver from device manager and add & remove program and than install proper drivers
2> if the distorted display is from boot screen than its definately a RAM problem so kindly remove it and refit it properly and if still problem continues than kindly replace it.
Dec 19, 2008 | Computers & Internet
Miramda video wall
Sounds like a setting got changed. Static maybe? you might want to call a professional to help with this one.
May 25, 2008 | Miranda Kaleido-Alto-A Virtual Video Wall...
Problem with display
It sounds Heat related. As the monitor heats up, it begins going crazy. Maybe unplug and blow out with compressed air.
Hope this gives you some ideas.
Oct 04, 2017 | Samsung SyncMaster 1701MP (Silver) 17 in....
Televison & Video Logo
43 people viewed this question
Top Miranda Televison & Video Experts
Are you a Miranda Televison and Video Expert? Answer questions, earn points and help others
