Question about Air Tools & Compressors
The shaft or pin that drives the nail does not retract on my mastercraft 3 1/2 framing nailer. #58-8434-4
    Problem Solver:
  • 7 Answers
Take the back cap off of the nailer. There is another loose cap in that head, most times that gets stuck. Believe me, I was raised by a carpenter that had nail guns before anybody else did. Also, sometimes that plunger gets bent, just straighten it out. Check for blown o rings. If it is old, take the trigger assembly out and clean it out. Be sure to oil everything well before you put together. We use marvel mystery oil, or nail gun oil.
Posted on Jul 11, 2010
I took mine apart cleaned everything oiled it all up and put it back together. I got about 3 nails in before it did it again. I took out the firing pin and checked it for straight and saw no sign of a bend. I put it back together and it still sucked. I threw it off the roof and have not use dit since. What a POS. My recommended solution involves spending money on a product that is not sold at Canadian Tire.
Posted on Aug 14, 2010
My nail gun was fired and its air flowed through the trigger, but the nails don't shoot out. Why is this? Please assist me.
nail jam remove air, open front of nailer, make sure the shaft goes back up in..also check for incorrect size or type nails
Oct 22, 2010 | Nailers 3 12" Pneumatic Air Round Head...
Driver pin on model FN250A not retracting far enough to drive next nail. Will shoot 2 or 3 nails and miss 6 or so.
I had the same problem with an electric stapler from Craftsman after years of disuse. The solenoid that powers the hammer that is no retracting may require lubing if this is possible.
If not, then if the product is within warranty, you might be able to get a replacement.
Jul 04, 2010 | Porter Cable Air Tools & Compressors
Piston blade won't retract
I've had a similar problem and found a nail had broken and lodged itself in the nail housing causing the driver to get stuck forward.
Apr 22, 2010 | Campbell Hausfeld 3 1/2" Rh Fram Nailer
I have a FC350A FRAMING NAILER, IT IS IN THE
check to make sure that there is not a nail jam , if the driver will not retract then the gun will not cycle . if no nail jam then replace the inner trigger
Feb 02, 2010 | Air Tools & Compressors
F28 ww framinf nailers. 4 relatively new
It sounds like you are using the wring nails. check the recommended nails and the degree of the strips. there is a large variety of degree's available if it is a Bostitch usually 28* is what your looking for. next the gauge of nails need to match and then whether or not they are paper collated or wire. that will cause problems like that all day. hope this helps
Dec 28, 2009 | Stanley Bostitch F21PL Nailer
N100 framing nailer does not retract piston
Try oiling it. That is the most common problem. Also, make sure you are using the correct nails. If they are not genuine Bostich nails, try them.
Nov 28, 2009 | Stanley Bostitch Coil Framing Nailer
Nailer drives one nail but driver pin doesn,t retract back into nailer head
Remove the air hose and open the nailer head section. Look for a foreign object in this are that could be jamming the drive pin. Also, make sure you are using the right size nails.
Jul 11, 2009 | Craftsman Nailer Kit, Palm Air Driver
Craftsman framing nail gun pin wont retract
most likely the pin has a small curve in it causeing it to stay out just replace the pin and never oil the external parts this causes dirt to build up on the pin and other oarts only oil in the inlet nipple! this is also true on any cordless nailer.
Jul 03, 2009 | Air Tools & Compressors
Paslode framing nailer when fired pin stays out wont retract
Check the anvil guide for damage first (ie: burrs, nicks, etc.) Then go to the chamber for the return spring. That is where your problems are.
May 12, 2009 | Craftsman Nailer Kit, Palm Air Driver
Air Tools & Compressors Logo
971 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
