Im trying to connect my linksys-g to my dell computer. for some reason my computer can't find the connection. am i doing something wrong??
  • markail Apr 22, 2008
    that wasn't the problem but it put me on the right track to finding it. thanks alot very helpful :)
    Sergeant:
  • 221 Answers
Your linksys router may have the SSID Broadcast disabled in setup. If the SSID Broadcast is disabled, wireless will not work.
You must log into the router to change the wireless settings. If you have the manual that came with the router, there should be a step by step for logging in. If not let me know.
Posted on Apr 19, 2008
I was doing something with my dell latitude d610 laptop key board and i lost the linksys wifi connection...although i came to know through my friend to press fn+f2 key,wifi LED comes on but no wireless...
Most likely configuration problem,Im afraid youll have to get the settings adjusted yourself most netbooks will auto configure unless you manually or by error change the settings.
Good luck
Davey Snake!
Jul 20, 2011 | Dell Latitude D610 Laptop Computer -...
Cannot connect my laptop to internet through router wrt54g v8
Make sure you have ipx and spx protocol installed, and a home network setup through windows. Also if the first try don't work make sure you firewall setting is not blocking your router.
Dec 03, 2009 | Linksys Wireless-G WRT54G Router
My disk driver is not reading any disks ,but the computer is saying that it is working ,im very confused
You might have to replace your disk drive because there may be something wrong with the laser that reads the disk even Tho the computer registers the device as normal that only registering the device drivers and the connection between the device in your computer it does not register it is something wrong inside the device other then the connection this sounds are there something wrong with the laser light on the disk drive hope this helps
Oct 24, 2009 | Dell Latitude ATG D630 Laptop
Dell Latitiude D 610 unable to connect to internet
When the network-cable from your computer is connected to the Cisco LinkSys router, click START -> RUN -> 'cmd'
and press ENTER.
Enter 'ipconfig' and press ENTER.
Look for a line like:
Default Gateway . . . . . . . . . : 10.20.30.40
Open Internet Explorer, and enter: http://10.20.30.40
to connect to the web-server "inside" the Linksys router.
Enter the router's password (probably still 'admin'),
and you can then configure the "wireless" settings inside the router.
Once configured, you can disconnect the network-cable,
and start using the wireless-adapter _inside_ your computer.
May 21, 2009 | Dell Latitude D610 Notebook
I just reformatted my dell 8400 and lost my Linksys g router conn
After reformatting your dell 8400, did you reinstall all drivers of your devices? The linksys router won't be affected by the reformat. Your computer should still get connection from your router. This is a dell issue. If you have another computer connected and working with the router, that means the router is still functioning. Call Dell or linksys technical support. If they cannot help try this http://technicalsupport.blog.friendster.com
Feb 22, 2009 | Linksys Wireless-G WRT54G Router
Dell pc will not work with linksys router
HI Boston
I believe the wireless card that you have in your laptop is a dell wireless card.
Here are the instructions on how to get your wireless working
Start-All programs-dell wireless-dell wireless wlan card utility-open the window and on the uncheck let this tool manage your wireless.
Please make sure that Enable radio is checked otherwise no wireless networks will be detected by the computer.
Once that is done go to start control panel in the left hand side make sure classic view is what is there. Go to network connection and you would see wireless network connection. Right click and click on view available wireless networks.
click on refresh network list if any of the networks are not seen.
Still no go try to enable the radio of your wireless card by pressing fn+F2 and then try.
if your getting limited or connectivity right click on wireless network connection go to properties, select on the top the tab wireless networks and remove your network from the preferred networks click on ok.
now get back to view available networks and try to connect to your wireless network.
make sure if there is a security on ur network you are aware of the ntework key and its case senstiive as well. otherwise ask linksys to give it to u.
if your wireless says connected check the ip address and post it here . for finding ip address start-run-cmd-click on ok
in the command window type ipconfig and post the ip address here.
alternatively also try updating the wirless card from the site
http://support.dell.com
thank you do post your results and feedbacks if any
rakesh
Dell Laptop Expert
Jan 09, 2009 | Dell Inspiron 6000 Notebook
Dell Dimension DE051:Wireless Internet Problem (Can't Load Sites)
contact Comcast and have them reset your IP address. also have them ping your modem after they reset IP.
Also, see Linksys website for LELA (easylink advisor) to add devices to network. Uses a good bit of memory so don't allow to run automatically at start up.
Dec 30, 2008 | Dell Dimension 5100 (D51L1) PC Desktop
WRT150N looses wireless connectivity
filasian, there is a strong possibility that the switch part of your router is defective because there is no light on number 2 even if there is a computer plugged into it, this can be the factor that affects the wireless operation of the unit.
the best move you may do at this point is to contact Linksys to perform a firmware flash on your router or discuss the warranty of the unit.
their toll free number is 1-800-326-7114
or refer to the site below to to see the contacts for linksys.
Linksys- Contact Us.
good luck
Jul 29, 2008 | Linksys Wireless-N WRT150N Router
Im trying to connect to xboxlive.im connected to the internet,my xbox 360 keeps failing to update
It depends how you are connected to the internet an easy way that i did it with is by connecting it through my ethernet connection in the back of my computer then connecting through the internet with the blue USB cord that comes with your internet connection if you bought DSL. but if you have broadband there are a few ways if you have a linksys and your internet is traveling through there then you can just plug in the ethernet cable to one of the connection areas still available in the back of the linksys. Now trying to connect wireless to xbox live can be a little different and depending on the reason xbox live gives you for not being able to connect it could possibly be a problem with your computer but i can still help you with that so just post something else about it and tell me how it goes also if you get it working you should send me a friend request or tell me your name because i usually have around the max of a hundred friends so a friend request wont work.
Mar 07, 2008 | Video Game Consoles & Games
Computers & Internet Logo
49 people viewed this question
David Payne
David Payne
