I have just installed a new computer with Windows Vista. I am getting an advisory that there are compatability problems with Vista and the Canon iP1700 printer. C an you advise?
  • 487 Answers
There are several things you can try if you have a device that is not working correctly:.
Please check this link. You will find the driver for vista
DRIVER
• Check if updated drivers are available through Windows Update. When you check Windows Update, click View available updates to determine if an updated driver is available for your device. For more information, see Install Windows updates.
• Make sure that the hardware device is compatible with your computer and with your version of Windows. If the device is not compatible, you will need to find the correct driver. Check the information that came with your device. You can also search for the device on the Windows Vista Hardware Compatibility List (HCL) website. This website contains a comprehensive list of computers and devices that have been tested to work with Windows Vista.
• Many devices require special drivers to work properly. Be sure that you have installed any software discs that came with the device.
• Restart the computer. Restarting might be necessary if the driver requires it or if the driver did not install correctly.
• If the device is a universal serial bus (USB) device, disconnect it and then plug it in to a different USB port. Windows should detect the device and install the drivers, and will notify you if the device drivers did not install properly.
If this does not work please come back to me
Posted on Apr 19, 2008
My printer Canon LBP 2900 won't work on my new computer windows 7
There are none and I am sorry but there probably never will be, See this is the major problem with Win 7 anything over a year old generally just isn't supported.
Here is how to Install them so they work. Download your XP driver you wish to install. If it's in a zip/rar file then extract it to your desktop. You should have a simple .exe file sitting on your desktop to install the drivers, as normal for XP. Right click the .exe file and select "Properties". Then select the tab called "Compatibility" Now check the box next to "Run this program in compatibility mode for:" Make sure "Windows XP Service Pack 2" is highlighted. Now apply the settings and run the installer. This should work for most drivers, but not all Install and run as Administrator.
Mar 07, 2010 | Canon LASER SHOT LBP-2900 Printer
Need drivers
there is no driver yet for windows 7.but download scan gear and scan gear toolbox from here:http://software.canon-europe.com/products/0000473.asp  open properties,compatibility and run it in compatibility mode for xp sp2
Feb 28, 2010 | Canon CanoScan N650U Flatbed Scanner
Vista compatibility with canon i960 printer
Here is a link to the updated drivers for Vista. You will see in the first section where you can select your operating system (OS). Click the down arrow and select Vista. Now in the box called "Drivers" click on the red .exe file. It will display a new page. Scroll down to the bottom and click on the "I agree" Button. This will start the download process. Click Run, wait for it to download and click run again. This will start the install process. This should fix your problems.
Jun 27, 2009 | Canon I960 InkJet Photo Printer
I am considering buying a new computer. I have a
The good news is that your Canon iP8500 printer is Windows Vista compatible. Driver page for them is here:
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=357&modelid=10440
More good news, the Epson Perfection 1650 scanner is also compatible with Windows Vista.
It would also appear that your HP Laser Jet 5mp printer is compatible with Windows Vista:
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareDescription.jsp?lang=en&cc=us&prodTypeId=18972&prodSeriesId=25481&prodNameId=15013&swEnvOID=2093&swLang=8&mode=2&taskId=135&swItem=lj-44462-1
Whether or not to get a Dell or HP is a preference thing. The biggest thing you have to ask yourself is, how much are you wanting to spend on a new system? Both vendors are fairly comparable as far as hardware and support. The biggest thing I should mention is that, ensure that when you buy your system, to tell whomever you are buying it from that you need Windows Vista 32 bit. Not all of your components were compatible with Vista 64 bit.
Best of Luck and hope you have lots of fun with your new system!
Apr 24, 2009 | Microsoft Windows Vista Ultimate Edition
Need to downoad CD to new computer with Windows VistaSP1
Download the VISTA driver from the CANON website and install it. If you still have problems download service pack two and irnstall it first.Then instal the printer driver. DO not install VISTA service pack three with out installing two first.
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=334&modelid=9722#DownloadDetailAct
Dec 11, 2008 | Canon MultiPASS MP390 All-In-One InkJet...
Distorted photos with Canon Scanner & ArcSoft Photo Studio
I'm assuming that this is only occurring in ArcSoft PhotoStudio? You may need to install an application that is more up today and compatible with Vista. I don't know if that version of PhotoStudio is compatible. You should check with ArcSoft. There is a patch for the 2000 version of PhotoStudio...but again, I don't know if PhotoStudio 2000 is Vista Compatible.
http://arcsoft.com/public/software_title.asp?ProductID=141&dyContent=LANG_PATCH
Oct 25, 2008 | Office Equipment & Supplies
Problem associated with windows Vista
you could try the canon web site here Canon Australia - PIXMA MP160
see if the download can be got for vista .
riz.
Apr 02, 2008 | Canon PIXMA MP160 All-In-One Printer
Canon MP180
go to the part of the program that deals with compatibility of programs. I never liked vista so I never installed it. anyway in the compatibility box choose windows xp and run it. worse comes to worse go to www dot downloads dot com and download the drivers for your printer FOR vista.
Sep 10, 2007 | Canon PIXMA MP180 All-In-One InkJet...
Multipass c555
Your cd probably only holds drivers for win98 and XP, i think your printer is not compatable with Vista, as i am unable to find yoiyr model no. on the canon website for vista drivers.
Mar 11, 2007 | Canon MultiPASS C555 InkJet Printer
108 people viewed this question
jasbo
jasbo
