Question about Lexmark X5495 Printer
Paper goes down crooked and won't print - Lexmark X5495 Printer
  • 748 Answers
Hi
Depending on where you live this may be 1 of 2 different problems. If you live in the part of the country that is now experiencing all this humidity then that is probably the problem. The paper has absorbed a lot of water. This happens to mine all the time. I keep the paper separate from the printer on these humid days. If not then the paper feed tire may be dirty or actually need replacing. To clean, take all the paper out of the machine, take a single piece of paper and pour a little rubbing alcohol on the end. Enough to cover about two inches of the leading edge. Allow most of the liquid to evaporate. Now put the piece of paper in the paper slot. Send any small print job to the printer. When the piece of paper begins to enter the printer, hold on to it to prevent its entry. The printer will error after a couple seconds, but the cleaning process should be complete. Take the paper out completely and discard. Reset the printer and fill the printer with fresh, dry paper. Printing should now be OK. If not the printer roller itself needs replacing. Good luck
Posted on Jul 08, 2010
Paper going in crooked
Adjust the side guides in the paper tray up against the paper snugly. If it still feeds crokked try feeding paper through the hand feed tray.
Dec 27, 2012 | Office Equipment & Supplies
Paper goes in crooked and won't go down into the printer to print. This is a Cannon bjc-2100.
In most cases there is an obstruction in the paper path causing this. Sometimes by lifting the printer upside down and shaking it can remove the obstruction. If this does,nt work get a torch and look down into the paper path and see if you can see anything foreign.
I have also dislodged the objet by using a A4 cardboard ( folio ) and feeding it back in from the inside of the printer to where the paper usually sits.
I have found hundreds of varied objects that have dropped into printers.
Jul 17, 2011 | Office Equipment & Supplies
My HP Officejet Pro K8600 prints crooked, how do I fix that?
is the paper going thrugh crooked?
make sure the paper is in the tray and the guides are night and straight.
if that is ok, look for something that makes the paper turn crooked by hitting it, such as a lost scrap of paper or a paperclip where it does not belong.
Dec 29, 2010 | HP OfficeJet Pro K8600 Printer
When trying to print a document, the paper goes in crooked. Then my printer says there's no paper. Of course, there is plenty of paper and it's straight before headed to the printer.
If it goes in crooked, there could be a slight paper jam. Take the top off or open it up anyways and check the feed roller to make sure it is not sticky or jammed.
Nov 10, 2010 | Office Equipment & Supplies
Ricoh ap610n prints crooked. It's about 4 years old. Has been a great work horse but now prints come out crooked.
99% of the time its paper loaded with the side guides of th paper drawer open too wide. -Carl
May 13, 2010 | Ricoh Aficio AP610N Laser Printer
Hi it goes to print and the paper catches and goes down crookedly. What am i doing wrong i line it up straight. Am i using the wrong size paper?
I would get a can of air and blow out the whole printer. It is likely that a small piece of paper is jammed in the path and is causing the paper to mis-feed. The only other issue could be a problem with one of the path wheels but a small piece of paper is likely the problem.
Oct 19, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Paper i feeding wrong, it starts then backs up a
Generally whenever paper goes "crooked" it's because something is partially obstructing the paper path.
It could be a small piece of plastic, or paper from a previous jam that tore off and stuck.
I would suggest looking at the paper path (use a flashlight) to see if there are any obstructions and then carefully remove any found.
I've also seen where the side plastic has become broken, or has a sharp edge sticking out that will cause the paper to misalign.
Hope this helps!
Sep 01, 2009 | Epson Office Equipment & Supplies
Paper goes crooked the jams
both wheels are not grabbing , they need to be cleaned
Oct 15, 2008 | Lexmark X1150 All-In-One InkJet Printer
Paper Jam Error
Just clean and observe yaar , I dont have more knowledge , In my knowledge i am telling , just clean your printer and see yaar ,
Aug 28, 2007 | Canon PIXMA iP1600 Printer
Lexmark X5495 Printer Logo
313 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Roopesh S
Roopesh S
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
