Question about Microsoft Xbox 360 Console
3 red lights
I have an xbox 360 and there are 3 red lights flashing.. whats going in on with it??? plz help!!!!!!!!!
  • 20 Answers
Try this.
Posted on Apr 19, 2008
Has 3 red blinking lights
Red Ring of Death: Red Flashing XBOX 360 Lights Explained Common Xbox 360 Red Ring Errors The XBOX has a reported 54.2% failure rate which makes the XBOX 360 gaming consoles' worst "lemon" to date. If you find yourself with the red flashing lights error, --> lg.php?category_id=15&content_type=article&content_type_id=2663399&key_page=682482001924178892&site_id=1&bannerid=11791&campaignid=3153&zoneid=23&loc=1&referer=http%3a%2f%2fwww.associatedcontent.com%2farticle%2f2663399%2fred_ring_of_death_red_flashing_xbox.html%3fcontent_type%3darticle%26content_type_id%3d2663399&cb=8da55f49a0 follow this guide to try and pinpoint the problem with your XBOX 360.
1 Red Ring = Serious Hardware Failure
I f your XBOX 360 has a 1 red flashing light error, you're more than likely in big trouble. The 1 flashing red ring of light can be due to GPU or CPU failure, RAM overheating, a DVD drive error, or some serious problem with your Xbox 360's internal components. The most common 1 flashing red ring lights error is the E74 error. The E74 error is no easy fix for the Xbox 360 and usually has to be repaired by the manufacturer [though some have managed to repair it with the heat gun trick - but be careful]
2 Red Rings = Overheating
Mostly all red flashing lights on the Xbox 360 rings are due to overheating in some way or other, but the 2 red rings singles out overheating as the main issue. When doing the X-Clamp fix the 2 red rings are required to fix the Xbox 360 by overheating the CPU. If you get this Xbox 360 error without doing the X-Clamp fix, you probably just need to let your Xbox 360 cool down for a few hours. Make sure that all vents aren't blocked off and that your Xbox fans are working properly in order to repair this problem.
3 Red Rings = Basic Hardware Failure
The most common error on the Xbox 360 is the 3 red rings - also known as the Red Rings of Death (RRoD). This flashing lights problem is the main cause of Xbox 360's 54.2% failure rate. The 3 red flashing lights can be due to lots of different errors but is mainly due to the X-Clamps in your Xbox 360 and overheating. Fortunately, lots of people were able to fix this issue using the X-Clamp and heat gun fix. Follow this list of error codes to find out the real issue with the 3 red rings because there are quite a few of them.
Jan 07, 2011 | Microsoft Xbox 360 Console
I have redone the thermal paste on my 360 and i have turned it on but it just flashes 3 red lights it heats up but wont go to the 2 lights and just keeps flashing the 3 lights even when it has over heated...
Red light problem can be fixed! there is a XBOX 360 repair guide available that covers this problem and also all other common XBOX problems. You can get your copy XBOX 360 Repair Guide, you can download it and get help to fix your console.
Click here to download repair guide
Dec 14, 2010 | Microsoft Xbox 360 Console
I turn on my xbox 360 and it says go to
how many lights is it? 2 lights- http://support.microsoft.com/kb/907533?sd=xbox 3 lights- http://support.microsoft.com/kb/907534?sd=xbox 4 lights- http://support.microsoft.com/kb/906652?sd=xbox
Hope this helps!!
Jun 28, 2010 | Microsoft Xbox 360 Console
2 red lights start flashing
Two red lights flashing on the Xbox 360 means that the system is encountering overheating issues. What you can do is to let your console cooldown for about half an hour and you are ready to go. Also, if you are connected to a Hi-definition output and running on 1080p, you might want to downscale it to 720p as the console generates less heat in lower resolution. Hope this helps..
May 12, 2010 | Microsoft Xbox 360 Console
My xbox 360 want turn on HELP ME PLZ
by orange light do you mean 3 red flashing lights on the front? if so you have the red ring of death which is unfixable by someone with no experience, and they should replace that for free as it is a hardware crash which is there fault all the first xbox 360s got it at some stage
Jun 24, 2009 | Microsoft Xbox 360 Console
Three flashing red lights on xbox 360 console
Wow, 4th? That's horrible! Hopefully the following helps you out! SYMPTOMS loadTOCNode(1, 'symptoms'); Three lights flash red on the Ring of Light (RoL) on the front of your Xbox 360 console. The upper-right quadrant light is the only light that does not flash red. CAUSE loadTOCNode(1, 'cause'); The three flashing red lights may indicate that there is a hardware problem with your Xbox 360 console. MORE INFORMATION loadTOCNode(1, 'moreinformation'); If you are experiencing this problem, you can submit a console-repair request online. However, before you submit your request, first try the following two steps to verify the problem: 1. When you turn on the console, look at the light on the power supply. The power supply light should illuminate green even if the three lights on the Ring of Light flash red. If the power supply light is not green, please follow the steps in one of the following Microsoft Knowledge Base articles: 906101 (http://support.microsoft.com/kb/906101/) Troubleshooting your Xbox 360 Power Supply when the light is red 906102 (http://support.microsoft.com/kb/906102/) Troubleshooting your Xbox 360 Power Supply when the light is orange 906103 (http://support.microsoft.com/kb/906103/) Troubleshooting your Xbox 360 Power Supply when the light is not illuminated 2. Turn off the console. Wait 10 seconds, and then turn on the console again to see whether the problem re-occurs.If your console continues to display three flashing red lights, your console may have to be repaired. If none of these help, pease contact Xbox support at http://xbox.agent.asahost.com/ to talk to a live agent.
Sep 05, 2008 | Microsoft Xbox 360 Console
RED lights flashing
This is going to sound like a very strange solution, but it worked for me, twice. My xbox 360 gave me the red ring of death once, and in my despair I asked a few friends about anything they can think of, and one suggested letting it run for 10 minutes while wrapped in a towel, or blanket. By that point I was desperate enough to try it (I had bought a refurbished one, so it wasn't under warranty anymore), and lo and behold, my xbox 360 is as good as new. Basically what you're doing is shocking the system into working via overheating... I know that doesn't make much sense, but, like I said before, it worked twice for me. Hope this helps!
Jul 27, 2008 | Microsoft Xbox 360 Console
Flashing 3 red lights
The 3 flashing lights suggests that it's a hardware problem and you'll have to send your 360 to Microsoft for repair. Go on xbox.com and there is a link for repairs.
May 26, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
63 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
