-   Impossible to find the System/Preferences area to enter a code, because Audio is the first choice, and there is nowhere under Preferences to enter a number except for parental control passwords. This solution does not work, but seems to be posted all over the internet.
-   Guest
Aug 15, 2008
-   Hi I have a Philips DVP3110K (Region 4) and am looking for the code to unlock.
-   Rougelocks
1. Turn on the unit 2. Open the loading tray 3. Press the "Setup" button on the remote 4. Navigate to the "Preferences" page using the right arrow key 5. Enter 138931 6. You will now see the current region code displayed 7. Use the Up/Down arrow keys to select the region required or "0" for all regions 8. Press the "Play" button on the remote
DVP 5106k
1 - Make sure there is no disk in the player 2 - Press EJECT on the remote or on the player. The eject icon has to be visible on screen for the hack to work!!! 3 - Press MENU (System) on the remote 4 - Press the RIGHT button on the remote until you get to the PREFERENCES screen 5 - Now enter the sequence 135566 with the remote control 6 - Now "Region Code" should appear 7 - Select the 0 (multiregion) 8 - Press MENU (System) on the remote to exit the setup screen 9 - Press the power button on the remote to set the player on standby, this saves the new setting.
DVP-5140 GIVES "NO DISK" FOR ALL DISKS. LASER CLEANING DID NOT HELP. LASER IS LIGHTING,...
(More)
DVP-5140 GIVES "NO DISK" FOR ALL DISKS. LASER CLEANING DID NOT HELP. LASER IS LIGHTING, MOVING AND TRAY TO FIND FOCUS. MOTORS LOOKS LIKE GOOD. FLAT CABLE, CONNECTORS AND SOLDERING WHERE CHECKED. WHAT CAN I DO ELSE? I DON'T LIKE BAY OTHER PLAYER.
I just watched a movie and it was fine, I put in another one and it is requesting a passcode. I...
(More)
I just watched a movie and it was fine, I put in another one and it is requesting a passcode. I found the one on this site of 136900 and it didn't give me the invalid password error again, but it doesn't do anything after that either. Any suggestions?
Hy there. I have a Power Problem with Philips DVP5990/37: when I turned on, the display shows...
(More)
Hy there. I have a Power Problem with Philips DVP5990/37: when I turned on, the display shows "PHILIPS", and no action can be applied after that: I can't play cd, dvd or nothing else,and turned off is not possible too. Could you please give me some help about that?
