Question about Dell Dimension 9150 (DIM915MIN) PC Desktop
X300XT BIOS P/N 113-A33437-102
I turn my computer on, I get a black screen with the following X300XT BIOS P/N 113-A33437-102. I am only able to turn it off and on, can't do anything else.
    President:
  • 2,291 Answers
remove the CMOS battery, and power on and switch off then insert the CMOS battery and switch on. that may help u, after this download reginout to fix ur issue
Posted on Aug 31, 2010
    Problem Solver:
  • 11 Answers
Unplug the power cable and then remove the CMOS battery, and power on and switch off then insert the CMOS battery and switch on. now your problem will be solved.
Posted on Jul 09, 2010
  • solka56 Aug 11, 2011
    hey, hope you can still help me, i have the same problem and done that, firstly it worked and the computer told me "floppy diskette seek failure press F1 to continue, F2 for setup settings" i didnt find anything in the settings so switch that off but the computer still worked, not i am getting the same x300xt bios p/n ... message and its not working anymore the battery is new, too
  • johnjkori
    johnjkori Dec 08, 2012
    you have to disable the diskette drive in setup settings
When i turn On my PC this thing shows in the monitor. <300 XT BIOS P/N 113-A33437-102
Open the case, loosen the 2 screws holding the black plastic casingon the cooling tower over the CPU. Carefully remove, or tilt back to reveal cooling tower radiator and coil.
If there is a layer of dust built up (like there was on mine); carefully vacuum clean the radiator, cooling tower unit, fan and all other surrounding areas. Clean any residue from tower-to-CPU contact area.
Vacuum entire PC inside and out. Remove, reseat, vacuum video card. Reseat storage drive cables reseat the memory sticks, close it up and plug it back in start computer.
Jun 05, 2014 | Dell Dimension 5100 (D51L1) PC Desktop
When trying to boot PC all i get is black screen and message:- X300 SE 128MB BIOS P/N 113-A33406-100. Have replaced bios battery on motherboard an checked connections etc but still displays same message....
no problem friend please open your cpu shutter and you can see here a cell like watch's cell plug it out and replace it with the new one and start your computer now your this problem is 100% solve. thanks
Jul 14, 2011 | Dell Dimension 8400 PC Desktop
Black sots on screen.growing everyday. already screen has been replaced once due to the same problem..again spots have appeared..wat to do??
Welcome to FixYa!
It maybe just a simple driver issue. For you to be able to verify it, you ill need to access the BIOS to check if the black spots are still there.Please follow these steps,there are different way od going to BIOS depending on the brand of the laptop.
1 Turn on your computer
2 Hold down F2, this will take you into BIOS. On some computers it might be the DEL key, or F1.
If the black spot is not there, you can go ahead and update the driver of the display...
Hope this will help. Thank you for using FixYa!
Jun 19, 2011 | Lenovo G550 Notebook
Error when starting Dell Dimension 9150 desktop PC: X300XT BIOS P/N 113-A33437-102
go to www.dell.com and check for a bios update if one is not present contact support and tell them your problem
May 31, 2010 | Dell Dimension 9150 (DIM915MIN) PC Desktop
Dell 8400 No Boot, not even POST
It sounds like your bios were improperly flashed or went bad. The X300 SE message is your video card. So your video card works, the system mostly works, but the BIOS isn't starting up. You should contact Dell and tell them the situation.
Apr 19, 2010 | Dell Dimension 8400 PC Desktop
Telephone Dell, and ask for "Parts", and order this part.
Nov 20, 2009 | Dell Dimension 9150 (DIM915MIN) PC Desktop
Acer One pc notebook black screen?!
That is a problem of BIOS. U need to reset your BIOS.
Acer Aspire One BIOS Recovery
The AA1 has a built-in BIOS recovery routine, making it possible to flash the BIOS even if the system doesn't boot anymore. It's only meant for emergencies and may void your warranty, so use at your own risk.
Follow every step carefully!
First format an USB stick with FAT.
Download the latest BIOS, and put both FLASHIT.EXE and the BIOS file in the root directory of the stick. Rename the BIOS file to ZG5IA32.FD, that's important. Do not remove the USB stick.
Turn the AA1 off, make sure both battery and AC adapter are connected. Press Fn+Esc, keep it pressed and press the power button to turn the AA1 on. Release Fn+Esc after a few seconds, the power button will be blinking. Press the power button once. The AA1 will now initiate the BIOS flash, do not interrupt it under any circumstances. After a while the power button will stop blinking, and the AA1 will reboot shortly after. Wait patiently.
The BIOS has been flashed and all settings reset to default.
May 07, 2009 | Acer Aspire One PC Notebook
"Bad Bios checksum P/N 113-PE0600-04
replace the bios battery.... looks like a big watch battery.
Mar 04, 2009 | ASUS P4V800-X (90-M8LBR0-G0EAYZ)...
Dell Dimension 9150 (DIM915MIN) PC Desktop Logo
4,524 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
