Question about Toshiba 43A10 43" Rear Projection Television
Hi i have a toshiba 43v7da television which ive inherited it is quite a clear picture but seems the red is taking over giving odd colours. Also unless you are looking straight on it gets dark and hard to see is this normal? any help greatly appreciated cheers Boe
premtech
  • 934 Answers
SOURCE: Toshiba 52hm84
It's either signal board or light engine and unless you're really pretty good at electronics neither one is something you should tackle. I do have the service manual for this unit and I would be glad to send it.. Just drop me an email premtech@willapabay.org and make sure you include the model number as well as what it is you need.. I get almost 650 emails a day so it's really hard to remember who's email goes with what problem. :) Good Luck Bill
Posted on Jun 11, 2007
ginko
  • 19396 Answers
SOURCE: Toshiba 52HMX95 DLP has weird gray think line
DLP TVs work projecting light throught a tube covered with mirrors, called the light tunnel.
The gray shadow it is something in the middle of the light tunnel, probably a mirror that has gone out of place when you moved the TV.
Posted on Sep 02, 2008
  • 12 Answers
SOURCE: the tv seems really dark.57in theatrewide hd toshiba
Go into the tv menu and select the Preferences menu and set your picutre preference from Theater to Normal. The TV is currently in Theater mode, wich is for viewing with no lights on in the room. Switching it to normal lightens the pictue a lot.
Posted on Jun 13, 2009
Ecollier2012
  • 3459 Answers
SOURCE: My Toshiba 50H82 Television takes about 30 minutes to clear up.
Projection TV sets have two very common problems listed below.
Problem #1) Convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Posted on May 07, 2010
SOURCE: hi there ive got a toshiba 43vj13p very blue picture
Hello, you can then buy a replacement lamp or lamps Toshiba 43VJ13P? Thank you
The picture is blue on every channel, but still has sound and picture
Hi
Hope is might help , if the others colours red and green are showing on the screen then resetting the grey scale as per service manual might clear the problem , but if one colour is missing then voltage cheek,s of the cathode voltage on the tube might give a clue to the fault a possibity might be a fault in the tube. regards Derrick.
Jan 30, 2011 | JVC Televison & Video
I purchased 42" LG Plasma TV and i need to know
There is quite a lot you can do. Go to menu, picture settings and select user 1. From here you can adjust everything from colour to contrast to warmth to sharpness. The best thing to do is to switch to XD manual adjustment and make sure the mpeg noise reduction is set to max. This removes artifacts and gives a better picture. Oddly, connecting via SCART rather than HDMI will give a more watchable picture if the HD broadcast is't at a very high bit-rate.
Dec 29, 2010 | LG 42LC2D 42 in. LCD HDTV
Hi there ive got a toshiba 43vj13p very blue picture
Dec 21, 2009 | Toshiba 53H71 53 in. Rear Projection...
Lines running vertical that appear to be red
hi
it is colour wheel problem,,,check it
please rate it..
thank u....
Jul 04, 2009 | Televison & Video
Picture appears "red" where digital pixels should be black
Call Associated Electronics @ 414.281.1000 and tell them what you need.
Mar 23, 2009 | Toshiba Regza 32LV67U 32 in. LCD HDTV
TOSHIBA 65H82
you need to replace your 2-convergence ic's #STK392-110 you need to replace both ,,they are attached to 2 big heat sinks and identified as q-751 & q-752 you can get the ic's you need plus free tec support and installation instructions including pictures at the link I gave you.
http://servicemanuals.vstore.ca/
Apr 12, 2008 | Toshiba 65H82 65" Rear Projection...
Colour problems
try to go in menu do factory reset ok
Feb 03, 2008 | Sampo PME-42S6 42 in. HD-Ready Plasma...
Lg 37in the picture cquality in hd is sometimes fuzzy
There is quite a lot you can do. Go to menu, picture settings and select user 1. From here you can adjust everything from colour to contrast to warmth to sharpness. The best thing to do is to swith to XD manual adjustment and make sure the mpeg noise reduction is set to max. This removes artifacts and gives a better picture. Oddly, connecting via SCART rather than HDMI will give a more watchable picture if the HD broadcast is't at a very high bit-rate. I hope that helps :o)
Jan 15, 2008 | LG 42LC2D 42 in. LCD HDTV
Toshiba 43D9UXA
This unit has not only problems with the convergence amps but the digital convergence board as well - this is one I would clearly recommend you take in for servicing as opposed to trying the repair yourself... It could be either that's faulty and some elaborate testing with a scope will confirm the failure.
Also, let the tech know that the correct part number for that digital convergence board is: 23786715 (Pd0078d) and to refer to Toshiba's technical bulletins Tv200301 and Tv200301 for further info. This will save them some grief if it does turn out to be the dc board because the part number in the service manual is not correct.
Bill
Dec 07, 2007 | Toshiba 42H81 42" Rear Projection...
Toshiba projection tv
there is no pink in resister codes
red or orange i think it's orange
32 X 8 or 5 32000 32K? most are low resistance
3.9 ohms and below.
Dec 06, 2007 | Toshiba 43HX70 43" Rear Projection...
Toshiba 43A10 43" Rear Projection Television Logo
91 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
