Question about LG TROMM WM2688H 4.0 cu.ft. Front Loading SteamWasher
My LG TROMM dle5977w dispenser assembly is stuck and will not pull out. Any ideas?
dutchman05
  • 487 Answers
SOURCE: Soap dispenser stuck on LG WM2277HW
here is your SERVICE MANUAL
Posted on Jun 23, 2008
Great advice. I used a portion of you plan. Pulled off the top, but since the softener cup is on the right, I only uncliped the 3 clips on that side of the assembly. With those loose, I could pry gently up on the back portion of the assembly lid, and the drawer pulled out.
I also see no need for the cover, other than a measuring device. So removed the screws at the front, pushed the assembly back into the washer, and unclipped the rest of the lid. Once the lid of the tray assembly was off, it was easy to remove the softener cover. The only challenging part was getting the re-closed assembly to go back into the cut-out in the face metal. I got caught a couple times, but getting my hand up under the assemble allowed be to push evenly up on both sides as I pushed it forward into place.
Now the door works fine again. Seems to be a significant design flaw by LG.
Hope the helps other.
Posted on May 17, 2009
Dissolu
  • 221 Answers
SOURCE: Lg tromm front loading washing machine has
Yes the system is cloghed. Pull the detergent drawer out and clean the drawers housing. try using some bleach. It allways helps.
BE ADVICED: after using bleach run quick wash cycle on without any load, it's just to get rid of all bleech remains and not to damage your clothes
Update me about your progress
Posted on Jul 25, 2009
  • 574 Answers
SOURCE: my dispenser is jammed Lg Tromm wm2277hb
you will have to raise the top if its top loading and disconnect the hose connected to it,if its the detergent dispenser and if it's the fabric softener one with the bleach dispenser with it there will be two hose connected to it and possibly some clips holding it in not sure all machines are different.
Posted on Aug 24, 2009
SOURCE: LG Tromm Not Dispensing Bleach
i will figure it out mine is doing the same - sherman@all-waste,com
Posted on Jul 25, 2010
Water remaining in detergent dispenser on LG Tromm front load washer?
The water usually drains from the drawers just by gravity. Have you checked that your machine is level?
Nov 19, 2014 | LG Tromm Front Load Washer And Dryer Set
Detergent dispenser is stuck and cannot open on LG Tromm washing machine
There is a small tab that one has to press down to unlock the retainer clip.
Press this down while pulling the tray outward.
Aug 06, 2014 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
My Lg tromm dle5977w is knocking
broken, worn drum roller? there are four of them.
Jul 06, 2014 | LG DLE5977 Electric Dryer
My lg tromm dle5977w dryer check filter light stays on and drum wont turn just makes humming noise
If the drum will not rotate then the drive belt is broken and should be replaced
May 26, 2014 | Dryers
Washer WM2075CW -The dispenser is stuck, only pulls out aprox 1/2
Yes you are correct, fabric softener dispenser is culprit. Search on this site for solutions. Issues and solutions have been posted often.
May 04, 2017 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
LG TROMM WM2277HB Washer will not dispense Bleach from the Bleach compartment. Thank you.
Pull out the dispenser drawer far enough to be able to just see the tray with the bleach in it, select the (final?) rinse and check that water is entering the tray. If it isn't there is a fault with the water distribution and an engineer call is required ;-0(
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Jun 19, 2011 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Doesn`t dispense soap right. soap left in dispensor
Hi
Try and disassemble the dispenser & check the wiring to the dispenser housing--
1. Disassemble the top plate assembly(Unscrew 2 screws on the back of the top plate).
2. Pull out the drawer.
3. Push out the DISPENSER ASSEMBLY after unscrew 2 screws.
4. Unscrew the nut at the lower part of the dispenser.
5. Disassemble the 4 connectors from the valves--
Wire Color
Blue Housing (OR-BK)
White Housing (WH-BK)
Blue Housing (GY-BK)
Red Housing (BL-BK)
6. Unscrew 2 screws from the back of the cabinet.
Hope this helps... Please post back if you need more information.
Daniel
Feb 17, 2011 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
LG TROMM WM2277HW Problem: cannot pull open the soap/bleach/softner dispenser drawer. Have a solution?
Hi
Wire Color
Red Housing (BL-BK)
Daniel
Jan 26, 2011 | LG WM-2277HW Front Load Washer
Jul 20, 2009 | Washing Machines
Dispenser door stuck
The dispenser assembly has warped and needs to be accessed from the top.  Remove the top panel to gain access to the dispenser.  The top part of the dispenser can be pried off so you could remove the drawer.
Jul 24, 2008 | LG WM2688HWM TROMM SteamWasher
Washing Machines Logo
55 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
