Question about Goodman Heating & Cooling
My Goodman CKH36-1B runs great until about now in the
My Goodmman CKH36-1B runs great until about now in the summer ( Phoenix ) and then it suddenly makes loud noises as though the blades are grinding
against something. Is there some maintenance I should be doing? I can't seem to convince my absentee landlord that something needs to be done. We also have a CKH30-1B that never makes a sound. I'm
willing to take the cover off and lube it or whatever I can do without having to have an expensive repair that my landlord won't pay for.
  • 36 Answers
SOURCE: Compressor noise
Anything bought from a retailer you have 90 days (unless otherwise posted) to exchange according to the Uniform Commercial Code of the United States. There are other state laws that vary from state to state. The air conditioner may fall under electronics, which usually have a 30 day return. After that period you have to warranty thru the mfg. If you have a receipt exchange it, if not your out of luck. Haier is garbage BTW. At least by the chinese made unit rebranded to look American. Hack
Posted on Jul 12, 2007
koolbreezes
  • 540 Answers
SOURCE: AC make loud noise on power off.
Is this a wndow unit or central air system? if this is a window unit , your problem is it only needs cleanning (dirt dbber nest-- trash around the back blades-- or the unt is twisted and rubbing the fan shroud. Last but not least, the slinger ring around the back blades (a ring around the end of the blades thats picks up water in the bottom of the unit and sling it on the coils to help cool the hot gases....Thank-you Thank you Thank you very much!
Posted on Jun 03, 2008
koolbreezes
  • 540 Answers
SOURCE: Goodman ac condenser, Loud and wet
Over charged with refrigerant>
Posted on Sep 12, 2008
  • 46 Answers
SOURCE: OUTSIDE UNIT OPERATES BUT FAN DOESN'T TURN AND UNIT DOESN'T COOL.
the motor could just be locked in place from sitting...take a stick or something and try to see if it spins be sure of rotation! you can also give it a little nudge while it is on and it will take off! if this happens then you have a bad start compacitor but no there are no fuses that only protect the motor!
Posted on May 25, 2009
Ed Phillips
  • 11 Answers
SOURCE: loud rumbling noise in mastercool a/c
This type of cooler has "pillow bearings" where the squirrel cage fan rests in the frame. They must be lubricated with oil at least yearly. If they go dry the bearings can wear out and cause the noise. Oil them first to see if the noise is less and maybe you can get by without replacing them. If the noise is still there you may need a bearing replacement. Always turn off the power to the unit before you work on it.
Posted on Jun 20, 2009
Goodman gmh95 furnace wont ignite
try the pressure switch you may be able to jump it out and see if it lights
Oct 01, 2016 | Goodman Heating & Cooling
Goodman furnace fan cylcing
The fan switch is set to turn on at approximately 125 degrees and run until the heat exchanger temp drops to around 105 degrees. With age the sensitivity of this switch varies and summer heat can cause the switch to turn on if the outside temp is over 100 degrees. Only the fan is running, not the burner but you can shut off the power to the unit if this is an issue.
Aug 27, 2012 | Heating & Cooling
My AC worked great until last year and then after a power steering hose leak was discovered, the ac until stopped blowing cold air. I took it and paid 75.00 to have it recharged with coolant and it worked...
My air conditioner started blowing hot air last summer. I put coolant in it and didn't run it until the beginning of summer this year (2011). All of a sudden it started working again. Sometimes it blows hot but if I keep it running full blast the coolness comes back. I don't know why this happened.
Jun 26, 2011 | 2004 Kia Optima
This is our first summer to use our Goodman central air conditioning unit and we are having alot of condensation on our windows and doors. We need to know if our service tech installed a unit too small for...
Your issue may be just the opposite of what you suspect. If the unit is too small, it will run continuously, but may do a better job of de-humidifying the space because the A/C unit has more time to pull humidity out of the air.
Conversely, if the unit is too large for the application, it may run for only a brief time, make the space cold, but may not provide effective dehumidification, resulting in the problem you describe.
Condensation occurs when hot humid air condenses out on a cooler surface, which in this case may be your windows and doors.
Keep your eye on this issue as excessive condensation or moisture build up can result in mildew or mold.
Aug 20, 2010 | Goodman Heating & Cooling
Induction Motor continues to run.
pull the rubber hose off the pressure switch. and blow into the Induced draft motor housing if you cant you can pull the hose off the IDM and try to clear it with a small paper clip. reconnect and try again. you can also get the flash code off the board while the unit is running but not working.
Dec 11, 2008 | Goodman GMS90703BXA Heater
Heating & Cooling Logo
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
paulcarew
Brandon Berry
Brandon Berry
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
