Question about Whirlpool Centralpark 25.6 Cu. Ft. Side-by-Side Refrigerator w/Thru-the-Door Ice and Water - Stainless-Steel
The freezer keeps defrosting and re-freezing again
I have a whirlpool (c-pentane?) tall side by side black fridge and freezer with an ice dispenser and i keep hearing the warning sound and the freezer bit keeps flashing and although it sounds as if it is still on when i open the freezer door my food is defrosting so i mute the warning sound and sometimes if you switch it off then on again the beeping goes off but some times when you switch it off and back on it still beeps. The fridge reads "ok" still inside but the things in it dont feel that cold? I have taken the grill off the front at the bottom near the floor and cleaned away the dust near what seems to be the fan but it has not made any difference. It has digital thermometer readings that you can set on the outside and they are set at -18 and 3. Thx for your time, hope you can help, steve.
    An expert who has answered 20 or more questions within one hour.
  • 67 Answers
First you need to remove plastic cover inside freezer compartment back wall at the bottom and check for build up of frost in the freezing unit if so your defrost system is faulty
Posted on May 02, 2017
  • 410 Answers
SOURCE: Whirlpool GD5RHAXNT00 Side By Side Refrigerator
your  problem on this is the main control in the compressor compartment. unplug your refrig then remove this control unplug all connectors and reconnect. this will probably get you working temporarily In almost every case I've seen we ended up replacing the control board. thx peyton
Posted on Feb 07, 2009
  • 1462 Answers
SOURCE: got an american whirlpool fridge
may be a indication only but on many fridge-freezers, 2 flashing lines ,means power interuption
Posted on Sep 17, 2008
  • 1462 Answers
SOURCE: Whirlpool side by side Refrigerator not cooling, two -- where -18 temp used to be.
the fact the bowl was filled with water and that you said the inside of the freezer was coated with ice, indicates a failure of the defrost system.
now the ice has gone, reset the temps and wait to see what happens
Posted on Oct 15, 2008
  • 1462 Answers
SOURCE: Whirlpool side by side refrigerator not defrosting.
take back panel off inside freezer. check continuity thro heater and thermal fuse in series with heater
Posted on Nov 17, 2008
  • 1902 Answers
SOURCE: freezer not freezing food and fridge not staying cold enough
Check the compressor with a volt meter, if the compressor is getting proper voltage then check the relay. But this sounds like a problem with the compressor
Posted on Feb 12, 2009
Fridge portion doesn't get cold
The defrost circuit is not working, there are usually 3 things that normally go bad, defrost timer, defrost heater, and thermal switch. Would have serviceman check it out as cooling fins on coils will cut you like a razor.
Jul 24, 2017 | Whirlpool Centralpark 25.6 Cu. Ft....
My GE Side by Side GSS25XSRSS keeps freezing up (bottom of each side only) with top portion of compartments much warmer (freezer side is too warm on top, all veggies are frozen on bottom of fridge side). ...
The evaporator fan is not working. You will have to open the front inside panels on the freezer side to get access to the fan, which is just below the ice maker. It may just require a little servicing, or the fan motor is bad or the controller at the back supplying electricity is bad.
Jan 10, 2011 | GE GSS25XSRSS 36" 25.4 Cu. Ft....
Model GSS25XSRB has cooling problem as well
Yes you have a defrost problem for sure. You will have to access the condensor coil in the back of the freezer compartment to get to the components. You will see a defrost thermostat(round thingy)wired to a heater element either solid black or encased in glass tube. Tubes are easy to see a burnout. You need to turn on defrost timer by rotating the crew slot clockwise until you hear a loud click. You are now in defrost. If heaters do not work then jump out the defrost thermostat and if they come on then thermostat is the culprit. Hope this helps.
Jul 25, 2009 | GE GSS25XSRSS 36" 25.4 Cu. Ft....
Water dispenser not working, keeps shutting off.
Often if you experience a freeze up it will take less time to refreeze because the tubing never got clear during the defrost originally. Try the defrost again and this time run at least a gallon of water through the water dispenser.
And although you say keep the vent open I have to offer the opposite solution close the vent. Too much cold air from the freezer is getting into the bottom of the fridge. closing the vent should allow the temp to rise. Assuming yours is a manual vent. If it is thermostatically controlled the controls may be at fault or the vent door may be warped or blocked open by ice.
If this helps you reach the next level of solving your problem please rate me as high as you can and thank you for using fixya.
May 27, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Freezer and icemaker freezes, jams.
I have run into this before and found it very helpful to re-level the refrigerator. By leaning the fridge back toward the wall about an inch helped keep the water and ice in the tray. Remember to remove items that block air flow in the freezer. Remove the ice bin and clean it then start over with the fridge leaning back a little. Hope this helps.
May 01, 2009 | KitchenAid Superba KSRG25FK Side by Side...
Whirlpool side by side fridge freezer alarm keeps bleeping and freezer has defrosted
whirlpool side by side fridge freezer alarm keeps bleeping and freezer has defrosted. the temp display on freezer shows - - flashing
May 16, 2008 | Whirlpool 25.6 cu. ft. Side-by-Side...
Water Dispenser Freezing Up
I would suggest that you turn the fridge temp up so that you are not cooling the fridge too much. However I suspect that you have a problem with your freezer section and the airflow is going in at the bottom of the fridge and not feeding in from the top. If you are competent I would suggest removing the back panel (lower internal) on the freezer section and checking that the evaporator coil (finned aluminium) is clear of ice. If you see an ice formation then you probably have a defrost heater out. If you defrost the unit then it will temporarily sort out the problem but I would suggest getting a fridge guy if your wife is getting mad already.
Hope this is of some if limited help.
Mar 13, 2008 | GE GSH25JSRSS Stainless Steel Side by Side...
Whirlpool Centralpark 25.6 Cu. Ft. Side-by-Side Refrigerator w/Thru-the-Door Ice and Water - Stainless-Steel Logo
229 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
