Question about Brother Office Equipment & Supplies
I have a brother MFC 1850MC. It only copies the right side of the paper not the whole page. Thanks!
Have same one, check to see if thermal paper is rolling correctly and that the "carbon" is not somehow awry
Posted on May 18, 2008
How can i make double sided copies on a brother mfc 7420 printer???
The manual doesn't say it will do double sided copies. it will copy two pages to one sheet of paper or 4 pages to one sheet of paper. you will probably have to make a copy of the document and then reload the paper back into the tray. experiment with it like put it in face down or face up then which is the top of the page. you can use a marker on a blank sheet of paper to see how it prints out.
hope this helps
Jan 28, 2011 | Brother MFC 7420 All-In-One Laser Printer
Tip
How to make duplex copies with a Brother MFC-240C printer
The Brother MFC-240C is a well-performing multifunction color printer. There is a lot that it can do, but one limitation it has is the inability to make double-sided copies. If you need to make a duplex copy of something, you can do it manually by re-feeding the paper once you've copied the first side.
After the first side of the page has been printed, let the paper sit for a minute or so to make sure the ink has dried. Then, put it back into the paper tray on the top of the stack. Make sure the back side of the page (the side that has not been printed on yet) is facing down, and the lead edge of the page (the edge that was fed out of the printer first) is facing toward the inside of the printer, rather than toward you.
Once the paper is set, push the tray back in and print the document or image that you want to appear on the back of the page. If you are printing multiple pages, position the paper so that the page you want printed on first is on the top of the stack.
The MFC-240C was not designed for duplex printing, so you may run into some issues with it, especially when you are using very thick or very thin paper. With very thin paper, the ink may bleed through to the other side of the page. With very thick paper, you may have to let the paper sit for a longer time after the first side is printed, because the ink could take longer to set and dry.
on Jul 06, 2010 | Brother MFC 240C All-In-One InkJet Printer
Mfc 6490cw everyone paper jam errror ! please help me.. Thanks.
Hi enesuysal
I have done some research into your problem firstly you can obtain a copy of the manual for your model printer here from this link i have provided...
http://www.retrevo.com/support/Brother-MFC-6490CW-Multifunction-Printers-manual/id/20693ag613/t/2/
You will find the information you need on page 160 Pull the paper trays out of the machine.nikkiallisto.jpg
Cheers nikki
Please rate my answer.Thanks for using FixYa.
Jan 16, 2011 | Brother MFC 6490CW InkJet Printer
Right side of every page has pink strip down page
Either your magenta cartridge is leaking out of the right corner or you have a defective magenta drum.
(maybe it got scratched when changing the cartridge?) If it's the magenta drum, you have to replace all the drums since they come in one unit. OEM part only.
Nov 20, 2009 | Brother MFC-9840CDW Laser Printer
Prints only right side of paper
most likely problem is one of your blue latches that hold thermal printhead down onto your film, is cracked. common problem on these and sometimes its hard to see the crack, but i'm sure thats the problem.
hth,
razors
Apr 02, 2009 | Brother Office Equipment & Supplies
Mfc-7420 Black Line horizontal across paper in 3 places
try moving the small blue slider on top of the drum cartridge side to side 10 times.
Mar 10, 2009 | Brother MFC 7420 All-In-One Laser Printer
Printing problems
If it is approx 3-4 smudges down the page. Replace the drum cartridge.
Oct 30, 2008 | Brother MFC-8460N Laser Printer
New cartridge installed but will not print
hi, first take a printer self test to check if the cartridge is installed properly,as sometimes we forget to remove the protection tape on the nozzel of the new cartridge.. let me know
Dec 16, 2007 | Brother MFC 1850MC Thermal Printer
Fax machine prints only on left side of page
One of the blue levers that hold the the top of the imaging unit to the printer has cracked. If you look carefully on the side that is not printing and flex the lever you will see a hairline crack. You can buy the levers at an office equipment repair store. You can also try gluing or taping a screw to hold the unit to the frame. What is happening is that the imaging unit is not close enough to the film to transfer the image onto the page. Happens all the time on these units.
Originally solved by Sue O: www.fixyourownprinter.com
Oct 07, 2006 | Brother MFC 1850MC Thermal Printer
Mark on page
First try to clean the head: Open the top cover and print head, Moisen a small piece of soft, lint-free cloth with alchol and keep wiping the edge of the print head... second, This could also be caused by excess lubricant on the tonercartridge . Print or feed up to 10 sheets of paper through the printer to eliminate the marks. If the problem continues please contact Brother Customer Service at 1-800-284-4329 Monday through Friday, 9:00am - 7:00pm EST, excluding holidays.
Nov 29, 2005 | Brother MFC 1950MC Printer
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
