Question about Powerware Series 9 9150 UPS System
9150 need to extend the full load run time to 60 minutes what do I need and how much
  • t support
    t support Jul 16, 2010
    First, how old are the batteries, extending an older battery with new ones will lead to shortened battery life for the new ones, so before you start you need to know the age of the existing batteries.
  • 45 Answers
Here is the documentation page for the 9150: http://powerquality.eaton.com/Products-services/legacy/9150-info.asp
The 9150 had a couple of different Extended Battery Cabinets for longer runtimes but the 9150 was discontinued so I suggest you reach out to Eaton's service department.
1 800 843 9433
E-mail: LargeUPSTS@Eaton.com
Posted on Nov 09, 2010
Ge adora dhdvh66ghobb stops heating after 8 minutes
bad thermostat possibly, which will do that
May 05, 2014 | GE DHDVH52GFWW Gas Dryer
It will not run 2 110 units at once, with full power. It has only been started twice, to exerise it. Is there a way to to get full power that I'm not doing?
. we found in approximately 2006 389 of this unit has improper wiring behind the control panel. have your unit check out fri-st. buy applying and load and over load test buy a pro. also after running for a shot time what we call a brake in time rune's out of sink. needs to be recalibrated. We have set them to 3645 to 3698 rpms to achieve 60 hz 125 vol /250 vol no load in order to maintain 120\240 full load. we use a gen set test station calibration unit to set all units. the unit is set at factory 3600 rpm 60hz 125 to 130\250 no load. good luck
Oct 10, 2009 | McCulloch 13HP 338 Cc Portable Generator #...
APC UPS 1500 w/full load forces immediate reboot at pwr failure
With a 980watt load the run time is only 7 minutes on a brand new battery. If you have the system on full load your run time will be much less and it has likely damaged the battery. here is the APC web site page for your model. If you are running that much equipment I think you need either a bigger UPS or another 1500 and spread the load out.
Buddy
Corporate Computer
Jul 24, 2009 | APC Smart-UPS 1000VA UPS System
Frigidaire Gallery Dryer Needs Two Cycles to Dry Clothes
A dryer needs to exhaust properly in order to dry no matter where it's situated. Insure that the venting is not crushed at the back and that it has a good strong air flow outside
Jun 21, 2009 | Dryers
HiMy name is Ray and i would like to increase the drying time on a maytag commercial dyer model lde19cs
i just got off the phone with Maytag Commercial Laundry customer service, because i needed to know how to adjust the run times on this dryer model. here is what i learned:
there are slots in the timing cam into which fit a white pin for adjusting the run time. the letter settings on the cam are set at 12 minutes apart:
E = 12 minutes
D = 24 minutes
C = 36 minutes
B = 48 minutes
A = 60 minutes
if your dryer is running 48 minutes, that pin is likely in the 'B' slot. remove the pin. the built-in stop at the 'A' position is for 60 minutes.
May 28, 2009 | Maytag Dryers
Dryer #69501 taking long time to dry.
All you need for proper dry times are good airflow and correct heat. As long as you're satisfied with the airflow, pull the venting off the back of the dryer and with a glass bulb thermometer, measure the exhaust temps at the back of the dryer, for most models, the high heat setting should reach roughly 160F +/- 10% before cycling the heat off....check this at the beginning of the cycle, and again after it has been running for 20-30 minutes. If that checks ok, just remember the industry standard for a normal size load of clothing is 60 minutes. If not, please let me know with a re-post, and please include a full model number (should begin either 417 or 110).
Apr 19, 2009 | Kenmore Dryers
Husky 455 dies out at full throttle or under load
Your carb may be the issue but your ignition coil could be the culprit. Once they start going bad, they can act up intermittently or give various symptoms from day to day. The fact that your saw dies at full load or under load, probably means that when your saw gets hot or requires more spark, your coil is not able to provide it. Your carb is easy enough to clean out, you can take it all apart and clean all screens, etc....
I just replaced my coil due to the exact same symptoms and now my saw runs great. $60 off ebay and you can put it on in 15 minutes yourself. Check your carb first though
Apr 13, 2009 | Husqvarna , No.455 Rancher, 20" Gas -...
Dryer stops after a few minutes of a full load.
You will have to replace the moisture sensor. The heat from the small fire may have damaged it. It's not that hard to do, but the part costs @$60.
Dec 16, 2008 | Kenmore Elite HE4 Electric Dryer
One minute left
be sure water is draining out before spin starts if necessary remove bottom panel and clean pump out and ck hoses to pump be sure there are no excess suds ..wash only full loads small loads or loads with 1 heavy item will cause washer to sense off balance and try to balance load this will extend cycle time
Nov 09, 2008 | Whirlpool GHW9400 Front Load Washer
Powerware Series 9 9150 UPS System Logo
193 people viewed this question
Top Powerware Computers & Internet Experts
Vassilis Chamaidis
Level 1 Expert
Are you a Powerware Computer and Internet Expert? Answer questions, earn points and help others
