Question about Maytag PAV2300 Top Load Washer
Pav 2300 water over fills even on a mini load past top
Pav 2300 6yo. water over fills past the exceeding level. On all levels mini,med,lg
  • trwrangler May 05, 2008
    My unit only overfills on the rinse cycle. Initial fill works fine. What could this problem be?
  • Anonymous Mar 24, 2014
    just trying to figure out how old this model would be
    Genius:
  • 1,073 Answers
Check the pressure line from the tub to the water level switch and make sure that it does not have a hole or crack in it if the hose is ok then the water level switch is bad
Posted on Apr 19, 2008
Tub fill half way up with water
Possible fault with the water level sensor, since this is a new machineit is best to refer to delearship before you do it yourself as this is under warranty.
Jun 27, 2012 | GE WBSR3140DW Top Load Washer
I have a Kenmore Elite Total Care System Top Load washer, and for the past two days, the water level will not fill past the medium level even if the setting is on Large level.
The water-level switch regulates your washer's fill volume. This switch is usually a diaphragm device with a small, clear tube attached between the switch and the bottom of the washer's outer tub. As the water level in the tub increases, the pressure on the air in the tube increases. When the pressure reaches a certain level, it activates the switch, shuts off the water, and signals the timer to begin the agitate cycle. If the switch is defective, it may prematurely signal the water to shut off. If so, you probably need to replace the water-level switch.
Apr 17, 2011 | Washing Machines
The Maytag PAV 2300 does not spin right if the load is slightly off balance. It bangs on the side and ordinarily lists to the right. On inspection, the washer is on level.
The list to the right should be resolved. Use a level and level the case left and right, and front to back. The final step is to tilt the machine fully on to the front legs, releasing the self leveling rear legs, and set the machine back down. It should be stable on the 4 feet.
usually this will center the drum and it is more forgiving on balance issues, most of which are common. Be sure to use MORE than enough water for more even loads.
Feb 05, 2011 | Maytag PAV2300 Top Load Washer
Maytag Performa Model# PAV 2300 AWW agitator & larger wash load
pull the agit out and look at the side just below the slots there is a small hole there and the lock screw is probably missing . / to pull agit you turn the screw out and to lock it down you turn it in till it stops . if no lock screw the out comes the agit ... could be very bad in spin if it came out . i have heard of this .. so lock it down .. **** hope this helps .
Dec 07, 2009 | Dryers
Kenmore 80 series washer. Agitates immediately and does not fill
it sounds like the water valve is bad,the water valve level(sm. med. lg.)controls the water valce-mike
Jul 17, 2009 | Kenmore 24032\24036 Top Load Washer
Excess water in clothes at end of spin cycle
SOUNDS LIKE THE MOTOR COUPLING TO ME.
May 15, 2009 | Maytag Washing Machines
I HAVE A 6 YR. OLD MAYTAG PERFORMA PAV 2300 TOP LOADING WASHER. UNIT WORKS FINE EXCEPT FOR LOUD CLUNKING NOISE AFTER SPIN CYCLE. NOTE - ALL BRAKE COMPONENTS HAVE BEEN REPLACED.
It sounds like a spn down noise. I would check to see if the brake spring was changed when the brake and stator was. They had some problems with weak springs.
Apr 24, 2008 | Washing Machines
My Maytag Performa PAV 22300AWW washer works eratically at best. The washer keeps filling completely on any water level selection (mini-med-large-oversize) and now the agitator won't work. I'm thinking it...
there is a tube that connects to the water level switch (small med large ) load level, it connects to the outside tub of the washer, inspect it to makes sure that it does not have a hole or crack in it
are you gettting water into the machine woth the power cord unplugged then you have a water valve that is bad , if no water comes into the machine with it unplugged the water valve is ok
if the above two tests are negative then the water pressure switch is bad.
Apr 16, 2008 | Washing Machines
Maytag PAV2300 Top Load Washer Logo
77 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
