Question about KitchenAid KEBC107 Electric Single Oven
I had to take the oven door apart to clean it. I need a diagram of how to put it back together. Can you help? Can you tell me where I can find one if you cannot. Thanks.
5 Suggested Answers
  • 2501 Answers
SOURCE: I have a MOdel No.
I suggest you try the makers advice line. Call 1-800-422-1230 (free) and they should be able to give you advice.
Posted on Feb 13, 2010
  • 327 Answers
SOURCE: Took apart glass oven door on a whirlpool. Where
Hello, bd_lft_up.gif bd_top_bg.gif bd_rt_top.gif bd_lft_bg.gif OVEN DOOR bd_rt_bg.gif bd_wpl_oven_door1.gif bd_wpl_oven_door2.gif clear.gif bd_lft_btm.gif bd_btm_bg.gif bd_rt_btm.gif Oven Door
#1 -- Oven door liner
#2 -- Oven inner glass
#3 -- Oven door hinge
#4 -- Retainer, glass
#5 -- Bracket, handle
#6 -- Door glass seal, top
#7 -- Door glass seal, side
#8 -- Oven outer door glass
#9 -- Door handle
#10
Read more: http://www.appliancepartspros.com/bd_whirpool_oven_parts.aspx#ixzz0pj5Z78oi
http://www.appliancepartspros.com .
Hope this helps.
Thanks
Posted on Jun 02, 2010
daryl441918
  • 1280 Answers
SOURCE: We have a Kitchen Aid
Most oven doors are held together by phillips head screws. If you look around the edges of your doors you should see them. Once they are removed your door should separate and you will be able to clean the glass. The pieces can be heavy so you may want to get someone to help you do this so that as it come apart one of you can hold the pieces while the other one cleans the glass.
Posted on Feb 28, 2011
  • 239 Answers
SOURCE: instruction manual for door assemly
try this http://www.kitchenaid.com/assets/pdfs/product/ZINSTALL/KEBS107SSS_Installation%20Instruction_EN.pdf
Posted on Sep 15, 2012
How can i clean the glass between my oven door,i noticed streaks and it makes the oven look dirty
Whirlpool door are a bit difficult to remove from the stove. the owners manual may tell you what you need to do to remove it. Once you have it off then the door can be taken apart by removing tye screws that hold it together. This should be done on a flat surface and taking a lot of care. Remember how it comes apart and reverse the procedure when putting it back together. If you break a glass they are expensive to replace if available.
May 30, 2015 | Whirlpool 30" Self-Cleaning Freestanding...
How to clean between glass oven doors on whirlpool oven?
You need to remove the inner door panel, Usually a few screws holding it on. On some models the handle screws also need to be removed. Do it slowly and carefully as the door may want to swing up quickly, once the weight on it is removed. Pay close attention to each step so all screws etc go back in the same place. Make a diagram as you take them out to be sure.
Aug 10, 2014 | Whirlpool RBD305PD Electric Double Oven
I purchase the Whirlpool electric double oven range GGE350 almost a year ago. The problem I have is with the oven door. There is evidently spillage or something between the glass pane. How is cleaning...
Hello, Thank You for using FixYa. I will be helping you today.I would recommend paying for a service call to have a tech take the door apart for you. There are four pieces of glass in the door and lots of screws. It really is a pain to take doors apart we as techs get this call all the time. Believe me you will thank me you paid someone to do it. If it were easy i would tell you. Most people take them apart then end up paying because they cant put it back together.
Thank You and please rate my answer if it was helpful..
Jun 10, 2011 | Whirlpool RBD305PD Electric Double Oven
Really how do you get to the inner glass, it has a disgusting line of **** inside i would like to clean thanks
IF YOU OPEN THE OVEN DOOR THERE SHOULD BE SOME SCREWS YOU CAN REMOVE LOOK AROUND THE DOOR EDGES FOR SCREWS ALSO REMOVE THESE AND YOU SHOULD BE ABLE TO PULL THE INNER DOOR OFF LOOK MAT THE GLASS CAREFULLY IF THE GLASS IS SEALED TOGETHER WITH ADHEISIVE DO NOT PULL GLASS APART, IF IT HAS A GASKET FINE SEPPERATE THE GLASSES AND CLEAN AND PUT BACK TOGETHER
Feb 05, 2011 | Ovens
#9 -- Door handle
#10
Hope this helps.
Thanks
May 30, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
I own a Kenmore stove model #639539J2. The glass
yes. open the oven door to the first "click". it kind of stops about a quarter of the way open. most ovens you grab both sides of the oven door and pull up. some models have a couple of screws you have to take out before you can remove the oven door. then lay it down with the insie of the door facing up and take out all the screws holding the oven door together. some may be on the sides or the top and bottom of the door. when apart, clean first with easy off, then clean several times with windex till streaks are gone. assemble door in reverse and put back on stove.
Oct 10, 2009 | Kenmore Ovens
KitchenAid KEBC107 Electric Single Oven Logo
76 people viewed this question
Top KitchenAid Ovens Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
ashburton
Are you a KitchenAid Oven Expert? Answer questions, earn points and help others
