Question about Dell Inspiron 5100 System Board ( Motherboard ) - N0933 CD-ROM Drive
When inserting a disk, the CD ROM spins but does not read the disk nor does it show up in "My Computer". Under Device Manager, it shows up with an exclamation mark. I've uninstalled and re-installed it to no avail. The disk spins but can't be read. I obviously can't reload the drivers from the CD ROM, is there a location from where I can download the drivers? Thanks
  • geoffmichael Jul 08, 2010
    Thanks but the link doesn't contain any information. The page reads "Your CD or DVD drive cannot read or write media". That's the extent of the information.
  • geoffmichael Jul 09, 2010
    The second link did open with copy and the MS Fix It button. Perhaps the first link did not open correctly due to the Safari browser?
    Thanks much, I'll let FixYa Tips know the results.
    Sergeant:
  • 195 Answers
Please try running the Microsoft Fix It from the link below. It should resolve the issue for you.
http://support.microsoft.com/gp/cd_dvd_drive_problems
Robert from Blitware
Posted on Jul 08, 2010
  • Robert Jul 08, 2010
    On the right hand side of the screen there should be a Run now button that will run MS Fix It
    Also here is a similar link that does have the information and the Fix It on it as well.
    http://support.microsoft.com/kb/982116
DVD will not read any type of disk.
If there is an EXCLAMATION Mark for the DVD, the device could just be failing on you.
Mar 05, 2014 | OEM Systems Dell Xps 15 L502x L501x Blu...
When I insert a disk nothing happens, it makes really loud noises asif its about to take off. This carrys on and my computer does not recognise there has been a disk inserted.
The driver for your CD-ROM needs to be UPDATED. click start, then control panel, click performance and maintenance, then click system, click the hardware tab, then click DEVICE MANAGER.under the CD/DVD ROM DRIVES, your CD-ROM should be listed. It may have a "?" mark or "!" to show the driver is out of date. If so, then right click on the device, click the "driver" tab, and click update driver. If the driver is updated, but the CD-ROM is still not functioning, follow the same steps, however; when you right click the device and enter the properties, instead of entering driver, click the "PROPERTIES TAB: and UN-CHECK the box in the DIGITAL CD PLAYBACK. If that does not work, then search online for a driver that is compatable with your windows system,
Nov 22, 2010 | Compaq (120192-B21) CD-ROM Drive
CD ROM
The drive has NOT been able to read the directory of the disk you put in.
Possible causes:
Disk may be a DVD which your drive may not be able to read.
Disk may be a DL DVD (double layer) whcih your drive may not be able to read.
The disk might be a BluRay which your drive may not be able to read.
Your drive may be defective or have a dirty read head.
May 03, 2010 | Compaq (120192-B21) CD-ROM Drive
When i put a disk in the cd rom keep getting message please insert disk
Try known good disk. Other than that the unit has probably failed. Make sure disks can be read on a buddys computer?
Jul 28, 2009 | Dell XPS 400 PC Desktop
Not recognising dvd player/not playing dvds
Sounds like the laser pick-up is not reading the disc, or the spindle motor is not spinning so the dvd can be read.
Jan 25, 2009 | NEC ND-3540A DVD RW Dual Layer Burner
CD ROM drive not seen in "device manager"
i think you are going to have to boot into bios and where it shows the boot configuration look to see if there is a cdrom there if not change it so the computer will have the cd rom in there along with the harddrive and the a drive then save it and exit and reboot then the cd rom should be back into the device manager and also under my computer
Aug 17, 2008 | Samsung TS-H492 (TSH492AWRBH)...
Cd -ROM does not recognize any disc that is inserted into it.
hi
Okay first does "any disk" mean ANY disk, or any disk in the same pack of blanks ? Some cheap media has this problem.
If not, then you probably have a hardware problem.
Try checking Device Manager for flags. Report them here.
someone will know more .
If none, your optical drive may be bad.
I'm assuming "delete the drive and reboot" means uninstall the drivers Device Manager. Did they have any flags before ?
Make sure to enable "show hidden devices". You might have a non-plug & play device driver in conflict, and they are hidden.
What software are you using to burn disks ? There may be a problem with that. If there are no flags in device manager, uninstall the software (if it's Nero, Roxio or something). You can reinstall the software later.
riz.
Mar 04, 2008 | Gateway (5500778) Internal 32x CD-ROM...
Need help
Computer CD-ROM drive help and technical information. DVD-RAM - ReWritable drive type that uses a phase-change technology like the CD-RW drives. ... CH000031, CD-ROM receiving power but does not work.
Computer DVD Support The Divix player is more expensive than a standard DVD drive and current DVD drives do not ... CH000327, Will a scratch cause a CD or DVD to not work?
CD or other disc tray does not close or opens by itself. A CD-ROM or other disc drive tray that does not close or remain in the drive ... If the above recommendations do not work, the drive tray does not push all.
Computer CD-R help and technical information The CD-R drive does not actually create pits on the CD, instead the burner ... There were issues with reading CD-R disks in the first revision of DVD.
Device Manager information and help Later versions of Microsoft Windows renamed this category to DVD/CD-ROM drives .... If the device does not work correctly, use Device Manager to remove the.
Computer Cleaning Information CD / DVD cleaning Floppy drive cleaning Hard Disk Drive cleaning .... If a keyboard does not work after trying it again later it is recommended that it be .
Good Luck, Read & follow instructions/Please dont for get to Vote/Thank You.
Dec 22, 2007 | HP Pavilion dv4000 Notebook
Computers & Internet Logo
217 people viewed this question
Alun Cox
