How much refridgerant to put into my 95 gmc sierra 2500 5.7 ltr 4x4? We tried to charge it but it seems to be ''hunting'' not compressing?
  • 478 Answers
22-24 ounces, If its hunting you need to change the orrifice and sceen. Don't use leak sealant more than once.
Posted on Jul 08, 2010
I have a 1995 Sierra 1500 4x4 and as I was driving it started to slip from 2w to N, so I'd stop and put it back but then do the same thing, then I jus started to hear grinding . I don't know w
I don't really know either, but , I have a 4x4 myself, gmc 2500, maybe together we can see what it is. my gmc has a shift lever on the floor to change 2w, 4w, hi, lo range, n. I'm assuming so so you., is there a switch @ transfer case, that is @ fault ? hope that grinding stopped that you mentioned. seems to me the transfer case is where we should look at first. I'll get back to you
Jan 15, 2013 | Cars & Trucks
My 97 GMC 2500 4x4 transmission went got a 4l80e from 1995 both 5.7 liter will it work
Yes it will bolt up, but the electronic control will be different.
Jul 01, 2017 | 1997 GMC Sierra
What is the engine size on a 1991 gmc sierra 2500 4x4
That year you probably have a 5.7 or 5.0 motor. You can find the engine size by getting your VIN and calling the dealer. They can tell you from either the 8th or 10th number in the VIN
Jan 29, 2012 | 1991 GMC Sierra
SETTING TIMING ON 95 GMC SIERRA 2500
350, 305, 400. Crank shaft gear mark is straight up to the camshaft gear and the camshft gear is straight down to the crank shaft gear. If your looking for the rotor button / distributor. The button should be pointing to the number one cylinder (drivers side front) On the compression stroke. To find the compression stroke pull the number one plug , put you finger over the hole, crank the engine untill the pressure pushes your finger off, then put a stiff wire in the hole and turn the engine by hand (wrench) untill the wire comes up and just starts to drop. Move it back and forth to get top dead center. On the distributor Number one and number eight should be horizontal with the radiator.
Jul 02, 2011 | GMC Sierra 2500 Cars & Trucks
How do i remove the rear brake to replace the pads on my 2002 gmc 2500 4x4?
pull the caliper mounting bolts,hang it from a clothes hanger,compress the piston to make room for the new pads,put every thing back like it was, check brake fluid. (open bleader on caliper when compressing piston.)
Dec 22, 2010 | 2002 GMC Sierra 2500HD
My ignition key is stuck in the tumbler. problem just started.i cannot get it loose what do i do. 1994 gmc 5.7 ltr 4x4 sierra truck
you can try using graphite powder in the ignition switch if you can remove the key,put the powder on the key & push it in & out to work the powder into the switch, don't use any spray type lubricants as this only attracts dust & clogs the switch up even more....hope this helps.....cheers
Jul 13, 2010 | 1994 GMC Sierra
I have a 1991 gmc sierra 2500 reg cab 4x4 with a 350. My question is it a 2 main bolt or 4 main bolt engine ?
Well usually they put the 4 bolt mains in trucks,pick ups,station wagons,full size cars......caprice,Impala. If it's the original motor i would say yes it does.If this helps you let me know !!!
Feb 24, 2010 | 1991 GMC Sierra
2003 gmc sierra duramax 2500
Problem with Diesel Fuel System. Gmc 2002 duramax 2500 HD 4x4 will start
Apr 19, 2009 | 2003 GMC Sierra
Heating & Cooling Logo
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
