I have 3 Email units and i need to find out there capacity Model : RM301 RM401 RM501
How to calculate the capacity for the unit using LRA
You don't. Obviously the higher the locked rotor amps the larger the compressor the larger the unit. What's the model number?
Aug 20, 2017 | Heating & Cooling
Capacity of the unit above in kw please
WE ARE NOT MIND READERS,IF YOU DON'T INCLUDE,MAKE,MODEL,YEAR AND PRECISE PROBLEM,THEN YOUR QUESTION WILL BE SKIPPED OVER IN ORDER TO HELP THE PEOPLE THAT DO INCLUDE ALL NEEDED INFORMATION AND IF YOU POST MORE THAN ONCE THE DUPLICATES WILL BE REMOVED AS SPAM.THANK YOU...
Jun 16, 2015 | Heating & Cooling
York model number ( H2DB024806A ) FOR THE ABOVE MODEL NUMBER I NEED THE TONNAGE ,BTU,SENSIBLE & TOTAL CAPACITY. As soon as possible. Earliest reply will be highly appreciated. Thanks In...
unit is 2 ton totla capacity 2 tons when mathced with proper equipment. BTU 24,000. Sensible heat only dervied from enthalpy chart once unit is installed. You will need a nate certified technician to assit you with the sensible and latent heat calculations for unit.
May 02, 2011 | Heating & Cooling
My model is AEV05KB and recently I see water on the cooling pipes sometimes it drips and sometimes it forms snowlike formations and also if I put the cover on the snow completely coveres the parts inside...
It sounds like the unit is too small for the area being cooled. You should figure the square footage of the area and use this th figure what you need.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Using the square footage and the chart below, determine the correct cooling capacity. Cooling capacity is measured in British thermal units (BTUs) per hour.Area To Be Cooled (square feet) Capacity Needed (BTUs per hour)
100 up to 150 5,000
150 up to 250 6,000
250 up to 300 7,000
300 up to 350 8,000
350 up to 400 9,000
400 up to 450 10,000
450 up to 550 12,000
550 up to 700 14,000
700 up to 1,000 18,000
1,000 up to 1,200 21,000
1,200 up to 1,400 23,000
1,400 up to 1,500 24,000
1,500 up to 2,000 30,000
2,000 up to 2,500 34,000
Make any adjustments for the following circumstances:
If the room is heavily shaded, reduce capacity by 10 percent.
If the room is very sunny, increase capacity by 10 percent.
If more than two people regularly occupy the room, add 600 BTUs for each additional person.
If the unit is used in a kitchen, increase capacity by 4,000 BTUs.
Consider where you install the unit. If you are mounting an air conditioner near the corner of a room, look for a unit that can send the airflow in the right direction.
Jun 17, 2010 | Heating & Cooling
Identify unit capacity.
The nameplate will provide a large amount of information, including the the manufacturer's name, model, serial, electrical requirements and the BTU rating or capacity that I believe you are looking for. Like the 120 volt sisters, the 240 volt unit should also have a nameplate. If unable to locate it on the chassis or frame of the unit in a similar location as the 120 volt, you'll have to look elsewhere. A www.google.com search on model number you provided (XHD183D) for this question indicates that it is a 17,900 BTU unit. If this is the correct model, case closed. If not, continue reading.
A good place to locate a nameplate if not plainly visible on the unit as it sits in the window would be on the chassis or frame behind the decorative grille. The grille is likely held in place by several clips and a screw or two. Shut off the AC and unplug it from the power source. Remove the filter as if to clean and carefully check for and remove screws and remove the grille.
I hope this helps!
Jun 07, 2010 | Carrier XHD183D Air Conditioner
Westpoint split air conditoner remote contol unit
1.model no.
2.capacity of yr unit.
3 brand name.
mailme mintex007@yahoo.com
i can send to u
Feb 07, 2008 | Heating & Cooling
Heating & Cooling Logo
97 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
