Question about Honeywell Electronic Programmable Heat/Cool Thermostat - CT3300A100 Heater
I AM TRYING TO GET THE AIR CONDITIONER TO WORK BUT THE TEMPETURE KEEPS GOING UP WHAT DO I DO
  • 149 Answers
Is hot air blowing out of discharge usually top of unit is large line suction cold if so compressor is probablly running. should be sweating on a hot humid day if not may need charged is cold air blowing out of registers if running too long may ice up and restrict airflow is filter clean important. if compressor is not running it could be several reasons too many to get into detail may have to call remember a old or out of adjustment unit will cost alot ie electric bill good luck hope this helps
Posted on Jul 09, 2010
Pilot light keeps going out after thermostat has reached desired tempeture?
Have never seen an air conditioner that had a pilot light.
Jan 29, 2016 | Heating & Cooling
How or what setting do you turn on to get cold air
Make sure the thermostat is turned to below what the room tempeture is. Make sure that the unit is in the cooling and not just the fan.
Good luck,
Marty
Jun 20, 2014 | Arcticpro Ypc-07c Faac7 Portable Air...
Air conditioner will not come on. The tempeture gage is reading -40. The sensor is not reading properly.
Hi ruswashingto,
The air conditioner may not work properly if your ambient temp is reading -40. The a/c control unit monitors ambient temp so that it does not operate at too low outside temps. I would recommend fixing the ambient temp sensor and rechecking your a/c operation.
Aug 22, 2011 | 2008 BMW 528i Sedan
Our A/c doesnot hold the tempeture set. If I set it for 78 as the day gets hotter it slowly climbs to up to 81. It will eventualy come back down to 78 after a hard day of work. If there is rainy day it...
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool...
AirConditioner Trouble - Review the Possibilities
heatman101
Aug 14, 2011 | Heating & Cooling
The tempeture controll will not respond to reducing the tempeture. It will respond to increases but not decreases
Sadly the company is out of business and parts are unavailable. If you are handy with electronics you may be able to remove the button panel and unstick the affected button, or replace it with a new microswitch.
Apr 06, 2011 | Windchaser PAC9 Air Conditioner
What is the appropriate pressure during operation of the Freon
Lowside psi. should about 60-68 highside about 225-250. This is aproximent pressures as indoor and outdoor tempetures play a big part in determining propper charge.
Sep 05, 2010 | Samsung AP500PF Air Conditioner
Does not heat air
What is the Tempeture outside?
May 27, 2010 | Sharp AFR120FX Air Conditioner
My a/c is not cooling , the cool air stops and the fan start
check your thermostat bulb it may be touching the coil of the unit
May 03, 2010 | LG LB1200ER Air Conditioner
Air conditioning is blowing hot air, system fully charged compressor is woring
The problem is the venting door. There are vent doors that are used to switch between AC and heat. Some vehicles use a cable that opens and closes the vent doors, other cars use vacuum and some are electric.
Whatever the case may be, if you feel the cold on the tubes, then the AC is likely working, you have to get the vent door working
May 01, 2009 | Heating & Cooling
Heating & Cooling Logo
172 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
paulcarew
Brandon Berry
Brandon Berry
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
