Question about Haier Heating & Cooling
I bought a used Haier portable air conditioner. It is blowing out the hot air and the fan is working but it is not cooling well enough. Just a slight bit of cooling air comes out.
  • 6,826 Answers
The Haier portable air conditioner is a good unit, but a little bit fragile, as the instructions say not to transport on its side.
Take the unit to a certified air conditoner service center and have the system checked for sufficient charge. They will be able to add the proper amount of refrigerant o make it work right.
Good luck.
Posted on Jul 08, 2010
Amcor is on but not blowing out any air
I just bought a used Amcor 1000 BTU Portable Air Conditioner APC2000E that does blow out cool air for about 20 mins before letting out way too much heat from the back. After a while you can't even notice the cool air because of all the hot air blowing from the back. Could there be a problem with this or is this just normal?
Jul 08, 2013 | Heating & Cooling
Haier esa410ke manual
my haier air conditioner won't blow cool air just took it out the window like last 5 months ago it was blowing cool air now i put it back in the window now don't blow cool air just hot air.
Jul 14, 2012 | Haier ESA410K 10,000 btu ECO-Friendly...
Haier air conditioner won't cool the room anymore
i bought the air conditionor new and it will not cool what can i do
Jul 05, 2012 | Haier ESA406K 6,000 btu ECO-Friendly...
The Exhaust fan is not working, the unit still cools air then cuts out.
the unit is blowing cold air then tripping out, is it blowing hot air out the back? im sure you mean exhaust air as in hot air so the reason your unit is tripping out is that its overheating and the pressures in the rerigeration system are to high, so the safety trip cuts the unit off.
replace the motor
all the best
Jul 05, 2010 | Haier CPRD12XC7 Air Conditioner
Air conditioner not working
have you tried turning off and on power from the plug ?
Aug 17, 2009 | Haier HWR08XC7 Air Conditioner
Heater not blowing hot air display says lo
when the coils freeze up , from intake of outside air, when using the heat pump mode, the unit will try to defrost the coils before going back to heat mode. mine did this alot. does it kick back to heat after a few mins? also after 2 years , mine started having issues with the exhaust blower control and would go into warp mode and bang noise.seems like common issues for this unit.whether the amana, or haier version.
Dec 13, 2008 | Amana Haier AP125HD Air Conditioner
Not cooling just feels like the fan is on.
HEY, sounds like it time for a full clean-up. Take the cover off and clean the drain ports, the filter in the front of the unit, the back inside coils, oil the fan motor, wash the front coils, ,, The water blowing out could be because its not leanning back enough, & the coils or filter is plugged and trying to **** air anywhere it can ,even thru the drainnage system! Thank-you-very-much!
Aug 30, 2008 | Haier hwr10xc6 Air Conditioner
I bought a haier electronic control air conditioner model HWR10XC6 on 6/30/08. I installed it. When I try to use the cool mode the air conditioner will only blow out cold air for about 5 - 10 minutes and...
It sounds as if the compressor (that provides the cooling) is cutting out due to either a faulty thermostat or is itself overheating.
Obviously check the thermostat is able to move between it's minimum and maximum levels, anthat this corresponds to the compressor cutting in and out.
With maximum cooling selected, the compressor should not cut out untill the thermostat says it's cool enough. If it does, there is a fault, and you have every right to a refund or a free repair/ replacement.
The fault is usually centered around the compressor electrical components if it is not under any warranty, but it should be. Even if the store does not want to know, the manufacturer should back it for 1 year.
Thanks for using Fixya!
If you need to attempt repair - ask again.
Jul 06, 2008 | Haier Heating & Cooling
Heating & Cooling Logo
63 people viewed this question
Top Haier Heating & Cooling Experts
Tom Chichester
Matt
Matt
Level 1 Expert
Vincent Schnittert
Vincent Schnittert
Level 1 Expert
Are you a Haier Heating and Cooling Expert? Answer questions, earn points and help others
