Question about Motorola Mobility RAZR V3
Charger problem Okay, so. I own a Motorola RAZR V3. My Charger wasn't working since the last 4 months. [My cell phone is low batt for 4 months] So, I decide to buy a new one here in Abu Dhabi. We went to a mobile shop, and ask for a Motorola Charger, and he recommended me a Blackberry Charger which is not the same brand with my cell phone. And then we argued, He said "This charger is a multi-purpose. It can be use in Blackberry and Motorola" And then, I gave my cell phone to him. And then, He tested it. After 5-10 minutes, my Cell phone turns ON. I thought, my cell phone is charging already. And he also did. And then, DONE. I already purchased it. When I arrived at my home, I immediately rushed into my bedroom and tested my new charger. And put my sim card on. And yes, its turns ON, but when I remove my charger my cell phone suddenly turns OFF. And then, I put it on again, and I saw a sign ?UNABLE TO CHARGE? Like OMG?! :[ My cell phone is not charging, and I can?t even see the BATTERY METER. So, my point is, WHICH ONE IS BROKEN, MY CELL PHONE OR THE CHARGER IS NOT COMPATIBLE WITH MY CELL PHONE? Thank you!
    Novelist:
  • 178 Answers
Let it charge for a good 6 hours before reaching any conclusions.
If it does not work for real, you are stuck since you are now without a charger and unable to identify if it is the phone itself. sorry to say this. i think you will have to buy another charger, the fact that it fits another phone should not be a problem. Is it making full contact with your phone when plugged in? that connection there might be the problem.
Posted on Aug 04, 2010
My motorolla razor v3 is locked when powered up
take out batt hold * & # place batt on and power up once logo comes up release * n # and it will take u to service screen then follow command or just turn off
May 31, 2010 | Motorola Mobility FOR MOTOROLA RAZR RAZOR...
Motorola RAZR V3M phone won't recharge
first check the charger it must be faulty or if the charger is fine then u need to replace the charging connector
Aug 17, 2009 | Motorola Mobility RAZR V3
New battery is installed but won't charge back after it is empty
your phone should have a hardwadre solution..... replace the 6 pin transistor near USB port
Sep 03, 2008 | Motorola Mobility RAZR V3
Rafzr v3
the main-board is dead the best bet would be to take it back to your carrier and explain the problem and have them fix it for you or hopefully replaced it if it is a manufacturer's fault.
Jun 09, 2008 | Motorola Mobility RAZR V3xx Cellular Phone
Motorola razr v3 display went out
Either your flex cable is broken or came loose. Is the top left hinge button still intact? Is it loose at the hinge? You will need a Torx 4 screwdriver to take the LCD screen apart to check the flex cable inside.
May 30, 2008 | Motorola Mobility RAZR V3
Motorola razr v3 won't charge
have you tried measuring the output voltage on the charger?? if not... use a multimeter to check if there is a voltage coming out on the charger.. if there is... you doomed.... the charging module (charging IC) on your phone is fckd..
Jan 11, 2008 | Motorola Mobility RAZR V3
Razr troubleshooting
none of the keys work and key pad is not locked. Recieved phone last night worked fine. Today I can only answer calls and only by flipping phone open.
Nov 22, 2007 | Motorola Mobility RAZR V3
Razr v3 unlocking code for another service
USE YOUR LAST 4 DIGHTS AND IT WELL UNLOCK
Nov 20, 2007 | Motorola Mobility RAZR V3
V3 Razr is dead, wont charge
take it to a local cell phone dealer and see what they say. most likley bad charger or bad connections.
Jul 08, 2007 | Motorola Mobility RAZR V3
Motorola RAZR won't charge
that happens mostly with third party chargers..you may want to explore the option of charging your phone using the PC and a USB cable...you may be required to download a software or driver for it ..along with eh motorola phone tool
Apr 30, 2007 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3 Logo
142 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
