Question about Toshiba 55H70 55" Rear Projection Television
Power light bliking - Toshiba 55H70 55" Rear Projection Television
  • 62 Answers
Common on these models is open fuses and convergance. the blinks give a code to the issue. need to know the blinks , count the blinks please.
Posted on Jul 08, 2010
2000 Mazda MPV, does not start and the transmision panel is bliking some time
If you have an alarm system it may be faulty, and cutting off power to prevent theft. Also; check neutral safety switch, and if service engine light is on then check for codes.
Apr 11, 2014 | 2000 Mazda MPV
Error bliking green light an not printing
If only the power green light is blinking, you could try a printer reset that may correct the problem.
1. With the printer on, disconnect the plug from the electrical outlet.
2. Wait at least 3 minutes
3. Plug back into the outlet.
Dec 27, 2013 | HP Deskjet 2050 All-in-One Printer
Bliking red power light
Check the fan door and the lamp door as the micro switch which is the protection must be latched/closed.If so the lamp must be rechecked, check the power, you will need to use a working projector to test lamp, if so the main board and also the power section must be checked.
Dec 14, 2011 | Mitsubishi PROJECTORS RPLMNT LAMP FOR...
Orange light bliking
press and hold power button until the machine shuts down completely then wait a few seconds and press the power button again it should power up normally if not there could be a problem with your power source, processor or RAM.
Jul 06, 2010 | Dell Optiplex GX280 (99301) Motherboard
BLINKING GREEN LIGHT
You have shorted out transistors in the backlight inverter circuits.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed DELL monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Replacement bd: www.lcdrepair.us
http://www.electronicrepairguide.com/dell-E153Fpc-lcd-monitor-repair.html
May 30, 2010 | Dell E153FP 15" LCD Monitor
Screenblinking blinking
yes replace ac adapter. light on ac adapter does not blink
Mar 07, 2010 | Dell Inspiron 1525 (dndppa1_3) Intel Core...
Power light bliking off and on
Power board ic inverter is dead.
U need a new one.
Aug 20, 2009 | Televison & Video
Canon BJC 85 printer
PRINTER BEEPS (5) TIMES, ERRORS
Nov 29, 2007 | Canon BJC-85 InkJet Printer
Click and light on front flashes!
This showing the tv have power. Maybe when you pushed the power button it clicks and shuts down then show the red light bliking showing one code. Some shurt on horizontal board or loose some voltage from power supply. This is not easy if you don't have experience with electronic. I'm sorry still tring
Sep 07, 2007 | Sony KV-35S66 35" TV
Toshiba 55H70 55" Rear Projection Television Logo
160 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
