Question about Sony Cyber-shot DSC-T9 Digital Camera
Memory card sony memory stick duo. my memory card is not showing any pictures.when i take the memory card out of my camera it says plz re nsert. and when i do still no piks. memory stick pro duo.2gb
  • 57 Answers
Try and format the card with the camera. Got to use the menu settings for that.
Posted on May 28, 2008
Camera keeps telling me to reinsert the memory card. I've tried to new cards. When I put the memory card I was replacing because it is full, it goes back into the camera just fine.
As a last resort you could copy the full card to a computer and then delete the pictures on the card and use that again.
Here is the error list from the camera manual.
This is all I can suggest from here.
"Reinsert the Memory Stick Error"
Insert the "Memory Stick Duo" correctly.
The inserted "Memory Stick Duo"cannot be used in your camera
(See below).
The "Memory Stick Duo" is damaged.
The terminal section of the "Memory Stick Duo" is dirty
Compatible cards.
Memory Stick Duo (without MagicGate)
Memory Stick Duo (with MagicGate) *1 *2
MagicGate Memory Stick Duo *1
Memory Stick PRO Duo *1 *2
NOT compatible
Memory Stick (without MagicGate)
Memory Stick (with MagicGate)
Memory Stick PRO
Some Memory Stick Duo have a write protect switch on the back.
You cannot record, edit or delete images if you
slide the write-protect switch to LOCK with a
fine-tipped object
"Memory Stick Duo", "MagicGate Memory
Stick Duo" and "Memory Stick PRO Duo" are
equipped with MagicGate functions.
MagicGate is copyright protection technology
that uses encryption technology. Data
recording/playback th
at requires MagicGate
functions cannot be performed with this
Supports high-speed data transfer using a
parallel interface.
Oct 12, 2014 | Sony Cybershot S650 Digital Camera
My Sony memory stick pro duo magic gate mark 2 is not shows images on pc but in my camera, but the photos are visible on Sony cybershot camera
Some Sony Cybershot camera's have a small amount of memory built into the camera. Double check that the camera is set to put the pictures onto the memory stick.
If the camera is set up correctly, the memory stick may not be formatted correctly for your computer. If at all possible, connect the camera to your computer directly with the USB cable that should have come with it.
May 31, 2011 | Sony 2GB Memory Stick PRO Duo Memory Card
My pc does not read the memory stick PRO duo sony...
my memory pro duo in camera show picture , when it conect with computer ,picture no t can i do?
Dec 30, 2010 | Sony 1GB Memory Stick PRO Duo Memory Card
Plz help me!
sony is for sony, reformat it
Mar 25, 2010 | Sony 4GB Memory Stick PRO Duo Memory Card
Getting an error code c:13:01 on my sony t900 camera
“Memory Stick Duo” is unformatted.
“Memory Stick Duo” is broken.
“Memory Stick Duo” type error
The camera cannot read or write data
on the “Memory Stick Duo”.
Format the “Memory Stick Duo”.
Replace a new “Memory Stick Duo”.
Insert a supported “Memory Stick Duo”.
All above are solution for your quiry
Jan 21, 2010 | Sony Cyber-shot DSC-T900 Digital Camera
I have pictures on the memory stick pro duo 2GB card that show up on my camera but when i insert the card into the computer it says that there are no folders. i know the pictures aren't just in the...
Once it was happened to me, I went in folder options, enabled 'show hidden folder and files' option and got all pictures in memory stick that were hidden in picture folder for some reason. Selected all with CTRL+A, right clicked, clicked propertise and uncheck hidden mark
Try that, might help you.
Nov 08, 2009 | Sony 2GB Memory Stick PRO Duo Memory Card
I have pictures on the card that show up on my
Keep the memory card in your camera....plug your camera into the computer and then turn your camera on...options should start to appear on the screen...follow the questions to get your solution...
After slideshow memory stick is missing photos (not on computer)
If you put the memory stick back into the camera can you see them thru the camera menu? If so your computer's SD card port may be having issues. try using the card in another computer or use the cameras USB cable to transfer the pictures from the camera to the computer if it has one. Do other memory sticks work in the computer ok? If you cannot see them in the camera either then the pictures will be corrupted and probably cannot be recovered. Then the card will need to be formatted to erase any errors on the card. Always use the camera to format a card whenever possible...Hope that helps.
Sep 19, 2009 | Sony Memory Stick PRO Duo (2GB) for PSP
No piks showing
The memory card can't be more then 2gb...the camera won't support more than that. Have you formatted the memory with the camera? If not try that, don't format the card with your computer.
May 05, 2008 | Sony Cyber-shot DSC-T9 Digital Camera
Memory stick duo not showing pictures
It may be that you actually have the pictures stored on the camera's onboard memory and you may have to plug the camera in directly to access the pictures. Or Sony may have a strange way of accessing the files on the device (they have done the same with their MP3 players), so you may be limited to using their software to get the pictures off the camera (or memory stick).
Sep 06, 2007 | Sony Cyber-shot DSC-W50 Digital Camera
Sony Cyber-shot DSC-T9 Digital Camera Logo
60 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
