Question about Whirlpool Kitchen Ranges
Whirlpool range super capacity gas 465 turn on any burner right rear ignitor fires continus. other buners lite.
  • 3,230 Answers
Well first of all you can check that flame requires a mixture of both gas and air in order to burn efficiently. When the burner is set to run on high, the flame should be bright blue and steady. If the burner is not getting enough air, the flame will be blue, yellow and white and leave soot on your pans. Now is the time to adjust the pilot. With the top of the stove raised, look behind the control knobs until you see a filter valve that has a screw. Locate this screw and turn it with a screwdriver until it is a blue flame with little or no yellow or white flame.
further you can also check gas range temperature controls removing  the range floor and pull out the broiler drawer. If the pilot flame is burning but the oven burner refuses to light, the pilot could be set too low. On the thermostat there is a pilot-adjustment screw that you will need to turn to increase the flame. If doing this does not increase the flame, chances are your thermostat is bad and will need replacement.
Good Luck!!
Thanks
Posted on Jul 08, 2010
The Whirlpool Gas Stove Super Capacity 465 sound like the Gas is on but the click click click that it makes when I turn on the burners is gone. The oven has no fire either...sound and smells the gas
Had a problem like this with mine..turned out to be electrical. The ignitors, that produce your clicking are controlled by electricity and circuit breaker (in power box) controlling the outlets on that area of kitchen was tripped. Hopefully your answer is this simple. Good luck!
Dec 10, 2014 | Whirlpool Kitchen Ranges
I JUST MOVED INTO A HOUSE WITH A WHIRLPOOL SUPER CAPACITY 465. IT DIDN'T COME WITH A MANUEL AND WE DON'T KNOW HOW TO BAKE. WHEN WE PREHEAT IT DOES NOTHING. THE SELFCLEAN AND BROILER WORKS THOUGH
Remove the bottom tray in oven compartment...... usually 2 screws at the rear... Turn it on to bake and see if ignitor glows if not test ignitor for 120v if you have 120v replace the ignitor. If it glows and still does not light burner after a few seconds the ignitor is weak replace it. (The gas safety valve has to receive a certain amount of power that must flow through the ignitor for the burner to ignite a weak ignitor will not allow enough power to flow through it). If you are not getting 120v trace the circuit.
Nov 04, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
Whirlpool super capacity 465 - Oven won't light
This is your gas valve that is bad on this unit. Please contact us at:
http://www.fixya.com/repair/d499389-accurate_appliance_repair_service
with your complete model number and we will get the correct part out to you asap.
We are available from 7 AM until 9 PM CST Monday through Saturday.
Nov 10, 2009 | Whirlpool GS460 Gas Kitchen Range
WHIRLPOOL Sup Cap 465 oven turns on for 3 sec, then shuts off
The flame sensor is dirty or bad.
When the unit does not sense flame after ignition, the gas valve shuts down the system.
They can become corroded or dirty, but usually just need to be replaced.
Contact whirlpool for warranty info. If the unit is under warranty, they should send you the parts for free. If not, they can direct you in how to order the part.
http://www.whirlpool.com/custserv/email_form.jsp
Sep 26, 2009 | Amana AGDS902 Gas Kitchen Range
Whirlpool Accubake Super Capacity 465 gas range. Oven won't light
I just had my ignitor replaced. The ignitor glowed but it must pull a certain amount of amps before it will allow the gas valve to open. Once the ignitor starts glowing the gas should come on within 30 seconds. Now that I saw it done I realize it was something I could have done myself. Be sure the tech does not try to slip you a used ignitor as mine tried.
May 23, 2009 | Kitchen Ranges
Whirlpool Super Capacity 465 the oven/broiler does not come on.
More than likely a bad ignitor
Here is how to tell If the ignitor is glowing it should be VERY bright, if it is dim orange it is weak and bad.
Jan 08, 2009 | Whirlpool SF357 Gas Kitchen Range
Overn won't lite
change the oven ignitor, that's the electric pilot nest to the oven burner.
Dec 08, 2008 | Whirlpool GS460 Gas Kitchen Range
i dont know want is wrong with it when i turn the oven on it keeps saying e2 and f3 i dont know what that mean please help me one on .... :(
Dec 05, 2008 | Whirlpool SF357 Gas Kitchen Range
Converted to LP Gas,How to adjust top & bottom flames in oven?
Open the air vent to the burner, you may have a small delate when it goes on , make sure the burner is clean buy the ignition, or the ignitor it's goin bad, you will know that when the oven takes more then a minute to ignite.
Nov 19, 2008 | Whirlpool GR465LXLS Electric Kitchen Range
Whirlpool super capacity 465 gas range model# sf377pegq5
I have the same problem intermittently on my Super Cap 465. After reading the following quote from another site, "There have been cases where radio waves, electronic signals and sometimes something as strange as dimmers in lights have caused some weird problems with some computer panels in stoves like these", I tried turning off lights that might be on the same circuit and wouldn't you know it, the oven igniter circuit worked.
Aug 20, 2008 | Whirlpool GS460 Gas Kitchen Range
Kitchen Ranges Logo
74 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
