Question about Sanyo DP50747 50 in. Plasma TV
Flashing screen on Sanyo 50 inch Plasma 720P
I'm having a problem with my 50 inch Plasma 720P TV. If theTV has been left off for more than a few hours, whenever it is powered back on it flashes and shows a faint ghost imageof the last channel it was on.
The only way to get it to stop flashing is to unplug the TV or cycle through the inputs at a quick rate until the flashing stops. If this isn't done the TV powers itself off. If you continue to try and turn the tv back on without cycling or unplugging first, the TV will shut itself off and not turn back on at all unless you unplug it.
It's not "burn-in" as the image isn't constantly there like it would be if you left it on the same channel all day everyday. I've tried resetting everything to the factorysettings and running the built-in burn-in fix and neither corrects the problem.
SOURCE: My Sanyo Tv (model dp327460 is Busted
You should try and download the users manual if you do not have one...I remeber seeing in it that after hooking every thing up, you have to do the channel search twice before the unit will work properly..This is highlited in the manual with correct hookup diagrahm..
Posted on Aug 10, 2007
SOURCE: Sanyo plasma 42 TV Turn off for no reason
Product of Japan is good
but made in Japan sucks
Posted on Jul 25, 2008
freetek
  • 5568 Answers
SOURCE: White screen only on Sanyo DP26648
Your reported symptoms are odd in that most failures are related to the primary power supply but that takes down both audio and video.
The backlight is obviously working (white screen) but it is no longer receiving any video information and this points to a failure of the logic (or the output of the power supply that services logic) used to control pixels on the screen.  Some screens have the majority of the control ICs actually mounted on the LCD assembly and because of very close pin distances used on dense ICs, they are often not replaceable by hand since they were installed by robotics.
I would first suspect (and hope for) the logic voltage output of the power supply to be the culprit.
If any of you posters have had a repair done and received any kind of a detailed report (you should), would you be kind enough to post it back as a comment to this original message?
Posted on Jan 16, 2009
  • 92 Answers
SOURCE: 50 inch Sanyo Vizon Plasma TV. Has sound but no
This set has LG insides, it will have failed on either the Y-Sustain PCB or the Z-Sustain PCB.
Quite common.
Repair estimates should be $250 - £350 depending on which has failed.
Stick it on eBay, it will fetch good money faulty.
Posted on Sep 06, 2009
Testimonial: "Thank you for your response. We were driving ourselves nuts - fuzes checked out fine and not other guess where to turn. We appreciate your help!"
rylee_smith
  • 8619 Answers
SOURCE: I have a Sanyo 50"
Hi
Thanks for using FixYa. From what you have described it seems to be the issue with Y-main however, buffer and the logic board should also be checked. These boards are located on the right side of the unit and to check them you’ll have to open the back of the unit. Once you have opened the back also check for any blown/bulged capacitors.
All this is only recommended if you have electrical expertise & know how to solder/re-solder components as these units contain high voltages even when in off position. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Aug 29, 2010
PN50C490B3DXZA 50" plasma TV, has vertical lines on the left side of the screen after warm up. And lines appear on any input and screen test. So do I need the main logic board?
If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size..
Nov 21, 2016 | Samsung pn50c490b3dxza 50 inch Widescreen...
Fix vertical lines on plasma tv
May 28, 2016 | Samsung PN50C450B1DXZA 50-inch Class...
On a plasma 50 inch tv Sanyo model number DP50749 it got black line coming down the front of the tv, what is the problem
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to Plasma screen are given with illustrations. You can get an idea about the fault to an extent.
Dec 04, 2014 | Sanyo DP50749 50 in. Plasma TV
Why is my 50 inch sanyo plasma power up with no picture then shutting down after a few seconds
A component in the TV is failing and is not receiving correct voltage, which is causing the TV to enter " protection mode" and shut off. Could be any part of the TV but I would start with the power supply and go from there.
For more info post the model number of your TV
Here is some basic info on testing the power supply.
TV Power supply general info
Jun 07, 2012 | Sanyo DP50747 50 in. Plasma TV
50" plasma panasonic 720p tv has several colored
Flashing error codes could be the Direct tv box itself.Because tvs have problems within itself don't flashes error codes on the tv screen,the problems,just show up.Tries tv and Direct tv satellite box unplug,replug it back like about an hour later.By letting the tv resetting itself back to the factory setting and the Direct tv box updates it softwares data's.The problems should be solved,if have the same problems,first call Direct tv for a replacement box,see how it work out.Than turn ur attention to the tv.
Feb 08, 2011 | Panasonic TC-P50X1 50 in. Plasma HDTV
Tv keeps turning on and off
You probably have blown capacitors on the PSB-power supply board. Recaping with new UF caps works 90% of the time. The set turns itself of into a fault protection to keep from damaging more components internally. A few bucks a soldering iron some solder should do the trick.
Jun 29, 2010 | Sanyo DP50747 50 in. Plasma TV
Ysus board number for a sanyo 50'' plasma model dp50747
This is a Sanyo Vizon 50" plasma the model number is DP50747 .. hope this helps the website for this product is www.sanyoctv.com and the phone number is 1-800-877-5032
Mar 16, 2009 | Sanyo DP50747 50 in. Plasma TV
Sanyo DP50747 50 in. Plasma TV Logo
190 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Jerry Greenberg
Jerry Greenberg
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
