Question about JVC KD-AVX1 Car DVD Player
Dvd player it will read the dvd but wont play it and after a few minutes it kicks the dvd out
    Genius:
  • JVC Master
  • 1,689 Answers
There may be dirt on the laser lens. Maybe there is something mechanicaly worn that is causing the laser to not properly track the DVD information on the disk.
How to clean a DVD lense from eHow:
http://www.ehow.com/how_2036275_clean-lens-dvd.html
After cleaning the DVD lens, if the problem still exists, then the DVD player will require proper service. If it is a low to medium cost unit, or if it is more than about 3 to 4 years old, then it may not be worth to service.
Jerry G.
Posted on Apr 19, 2008
Player won't load a blank DVD-RW disc
because there is nothing to read in blank cd rw , because dvd operating system is not meant to write cd ,but only to read the disk
Jan 31, 2013 | Samsung DVDR120 DVD Recorder
Wont play a disc. It will stay in Loading mode for minutes and then read "No Disc"
Try to play a music on cd instead of playing dvd. It it plays keep playing until playey got hot and drive off moisture on circuit. Let it cool down then try play dvd. If it can play severy dvd in sequence, then your unit is repaired. Keep using it to avoid condensation inside the dvd player.
Nov 15, 2010 | TruTech LMD-5702RT Portable DVD Player
I HAVE MY DVD PLAYER FOR ONE YEAR WITH NO PROBLEMS. NOW SOME DISCS WONT LOAD, AND THOSE THAT DO LOAD ONLY PLAY FOR A FEW MINUTES THEN STOP.
You may need to clean the DVD player's lens because it hardly reads the discs that is why you are experiencing that problem. If you have a disc cleaner, try playing it; having it spin for like 30 seconds will clean the lens. If this does not work, then you may have to manually clean the lens by opening the DVD's casing and unscrewing the plastic cover that protects the lens inside. Get a q tip or a cotton bud and damp it in an alcohol. Gently wipe the surface of your lens and let it dry for a few seconds. The return everything back and play those DVDs again.
Good luck and hope this helps.
Dec 12, 2009 | Sony SLV-D380P DVD Player/VCR
Dvds read bad
Get a laser cleaning disk and let it run in the dvd player for a few minutes then try playing a dvd. Its probably playing bad because the laser is dirty
Sep 21, 2009 | Toshiba SD-3980 DVD Player
DVD player no longer plays DVD's that I KNOW played on it before.
yes, Lazer wont aline to read, they get progressively worse, sometimes intermittent, if that is the case then you will need a whole new internal cradle. maybe time to get another one. the Yeti
May 20, 2009 | Televison & Video
DVD player turns on; but apperently will NOT play the movie after we put it in... HELP!!!
I had the same issue and could have kicked myself in the ***! Make sure the AV slide switch is in the out position or it will not play at all. As soon as you switch from IN to OUT it will work properly.
May 02, 2009 | Memorex MVDP1088 Portable DVD Player with...
Plays a few minutes then stops, and will not play any dvd
ITS THE MOTOR ITS FREEZING ON YOU NEEDS TO BE REPLACED
Jul 01, 2008 | Fusion DVD-811 DVD Player
Cant play anything on it
I had the same problem, After googling for a few minutes I found the reset procedure for this player.
1. Turn it on.
2. Eject any disk you have in there and close the tray.
3. Hold down the "STOP" button on the player (not remote) until the green light flashes red and the system reboots.
4. Insert disk and enjoy.
This worked for me... mileage may vary.
Aug 29, 2007 | Cyberhome CH-DVD 300 DVD Player
Reads all but DVD-Help PLEASE
When you say it won?t read are you trying to play commercial DVD movies or read DVD data disks? If you're trying to play movies then you need a couple of things the first being some type of player program. Real player works as does Windows media player but usually DVD drives come with a striped down version of PowerDVD or WinDVD. If you in fact have a player installed and when a DVD is inserted in your drive it doesn't play it may not be configured to automatically play DVDs. Try opening your player program and trying to manually play your DVD. Let us know if you have any success or if you need more assisted. If you do let us know what player program and operating system you have and any error messages that may appear.
Jan 01, 2007 | LG GCC 4320B CD-RW/DVD-ROM Burner
JVC KD-AVX1 Car DVD Player Logo
177 people viewed this question
Top JVC Car Audio & Video Experts
xxxxxx xxx
Tygh Duval
Tygh Duval
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
