Question about Goodman CLQ36AR49 Air Conditioner
What power go to the breaker inside air handler
  • 456 Answers
If it is a electric air handler and you see a double pole breaker switch it is most likely 220/240v
Posted on Jul 09, 2010
My air handler fan does not come on, the outside unit turns on fine. Is their a way to reset the fan?
Check for fan operation by turning the fan control at the thermostat to "on". If the fan blows, it works. If not, check a circuit breaker or fuse.
If the fan blows when forcing it on with the thermostat but not in automatic, check the fan control circuit in the air handler. Danger: high voltage, beware! There should be a system wiring diagram inside the air handler somewhere.
Mar 30, 2014 | Rheem 4 Ton Air Handler - RHLLHM4821JA
How do I find the fuse for central air type is a heil
There's a small 3 amp fuse in the air handler (indoor) that protects the control transformer (there should also be internal circuit breakers and a disconnect outside). The condensing unit (outdoor) is protected by an outside disconnect and circuit breaker.Be sure to shut the power before messing around in the air handler.
Aug 21, 2013 | Heating & Cooling
BRYANT MODEL 561CJ060-H THERMOSTAT NO POWER TO IT BUT POWER TO A/C UNIT
You may have a problem with the transformer inside the air Handler. You may need to check your breaker to the unit if it is a gas furnace make sure it is plugged in to the wall outlet. If it is electric you will be on a breaker inside your breaker panel. The transformer is a 120 volt primary to a 24 Volt secondary. I hope this helps.
Jul 29, 2011 | Heating & Cooling
A/c will not work freon is to specs fuses are good relal is new
Sorry, but not enough information.
Required information:
Is the inside unit running, if yes is the contactor pulled in outside. If no try locating float switch on emergency drain pan ( could have a clogged emergency pan drain line)
Any further information you could provide could be useful in diagnosing your problem
Refrigerant type
Refrigerant Standing Pressure
Power at Disconnects for A/C units and if so whats the voltage
Breakers in Electrical Breaker Box (Any Tripped or in the off Position)
Water present in emergency pan underneath Air Handler
What pieces of the A/C Equipment or running if any ( Air Handler, Condenser Fan Motor, Compressor)
etc
Jul 05, 2011 | Heating & Cooling
Have power to the unit ,no power out to the inside unit
Check breakers in the main panel and the furnace, some have fuses, most all AC units get there control 24 volt power from the air handler (furnace),
Jul 03, 2011 | Heating & Cooling
I want to find the transformer for the 36 volt inside unit. Is it in the inside unit or outside unit .I have no power to the inside unit however the outside unit has power,and the inside unit appears to be...
It's a 24v transformer. Your indoor unit houses the transformer for the outdoor unit. The outdoor has a low voltage (24v) supply running to it to push in the contactor for the outdoor unit to run. If your air handler inside has no power then it will kill your LOW VOLTAGE power to the outdoor unit. You will still have the high voltage power to the outdoor unit. You may have a fuse on the switch for your air handler blown if there is one. On the disconnect switch mounted to your air handler, you will have a door to open and a fuse in there. If not, check your main breaker at the panel. If you don't know what a transformer looks like, you may want to have someone familiar with electrical of HVAC help you. To check the transformer for power, you first need power to your air handler, which you don't have. I would say that is not your problem. I would assume your air conditioner is not running outside, correct? Your problem is the power (HIGH VOLTAGE) to your air handler. Loose wires, blown fuse, tripped breaker etc...
Aug 06, 2009 | Comfort-Aire HMC36AT-1 Air Conditioner
Why is my air handler fan motor tripping the 20
sounds like fan motor is going bad - replace
Jun 15, 2009 | Heating & Cooling
Condensor fan wont come on
check you breaker for a/c seperate from air handler and check the contactor could have coil blown for low voltage not calling in the compressor
May 16, 2009 | Heating & Cooling
Resettable fuse/breaker for TZ-4
The power to your zone panel is from the furnace or air handler. There is a 3 or 5 amp fuse on the circuit board inside the furnace or air handler. I hope this helps. Please don't forget to give me a Fixya rating.
Mar 13, 2009 | Honeywell Heating & Cooling
Goodman CLQ36AR49 Air Conditioner Logo
41 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
