Question about Dryers
My Amana dryer LEA30AW does not run. This is what happens, I load the dryer and turn the knob to the desired cycle and it will run and then shut off a couple of minutes later. There does appear to be heat when I open the door after it shuts off. Once this happens I try to position the knob to the start position again and it makes a buzzing noise and will not run, after time goes by I will go back and try it again and it runs for a short time again. What is my problem???? When it does run there is a loud squeeking noise??? Sometimes this noise goes away and then starts???
  • lemondropsmi Jul 17, 2008
    Our Amana dryer will run well for a while, then shut off. It has a moisture sensor. Could this sensor be bad, or could the thermostat be bad? Everything else works well with this dryer. Thanks.
    Tim
    Genius:
  • 1,073 Answers
The motor is bad replace it
Posted on Apr 19, 2008
How do you dry clothes in this machine please
A fairly common problem! The official instructions are
Before using your dryer, wipe the dryer drum with a damp cloth to
remove dust from storing and shipping.
1. Load clothes loosely into the dryer and close the door. Do not
pack the dryer. Allow space for clothes to tumble freely.
2. Turn the Cycle Control knob to the recommended cycle for the type of load being dried. Use the Energy Preferred Automatic Setting (,) to dry most heavyweight and medium weight loads. See "Drying, Cycle, and Temperature Tips."
3. Select a temperature setting on models with a Temp/Fabric selector. The cycle descriptions include temperature setting suggestions.
4. Push the START button.
Stopping and Restarting
You can stop your dryer any time during a cycle.
To stop your dryer
Open the dryer door or turn the Cycle Control knob to OFE
NOTE: The Cycle Control knob should point to an Off area when
the dryer is not in use.
To restart your dryer
1. Close the door.
2. Select a new cycle and temperature (if desired).
3. Press START
Extracted from
http://www.manualslib.com/manual/511763/Whirlpool-Lte5243dq.html?page=10#manual
Nov 14, 2015 | Whirlpool AWZ410 Front Load Washer/Dryer
On the amana LEA30aw which wires go where on the heating element?
There is usually a schematic pasted to the inside service area unless it fell out. Read it & start tracing wires. The power to the element should pass through a fuse, a thermistor(cycles power on and off relative to heat and a safety switch that kills power if it gets too hot. Don't take short cuts.
May 14, 2015 | Amana Dryers
My dryer's cotton/time dry/wrinkle free option know turns freely. Dryer will not start.
Take the other knob from the other switch nd put it in that place. It should turn then . You will be able to turn it on by a pair of pliers until you get a replacement knk.
Feb 22, 2013 | Dryers
I just finished cleaning lint from my dryer put
check the belt tensioner anf the bearing on the roller to it. if bad it will make that noise
Jun 09, 2010 | Amana NDE2330AY Electric Dryer
I just bought a used Amana Dryer LEA30aw and when I turn it on it has a slight burnt smell. What could this be?
sometimes youll smell burning lint or dust.let it run 10-15 mins outlet temp should be no more than 160'.smell should go away after a couple of mins.if temp exceeds 160 may need tstat.please rate my solution
Dec 06, 2009 | Amana Dryers
LEA30AW makes a humming sound when i hit start,
motor is most likely bad shorting out in the windings
Jun 26, 2009 | Amana NDE2335AY Electric Dryer
My Amana dryer LEA30AW makes a loud knocking noise while running and then shuts down. There is heat. It seems to be worse with a larger load. Any ideas??? Thx
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
fo
Jun 08, 2009 | Amana NDE2330AY Electric Dryer
Amana electric dryer model LEA30Aw will not heat
The heating element measures 10 Ohms at 68 degrees farenheit. Usually if the element is bad, it will measure infinity.
Dec 24, 2008 | Amana Dryers
Dryers Logo
407 people viewed this question
Top Dryers Experts
