Question about Poulan 42-Inch Steel Deck 17.5 HP Briggs & Stratton I/C Engine With 6 Speed
17.5 Craftman ohv 42 deck
I strip down the carbreator and put new gakets, new gas line, and clean the tank. But the mower starts fine and only runs for 2 minutes and shuts off..... What to do
    Problem Solver:
  • 10 Answers
Try spark plugs. they will do that.
Posted on Jul 25, 2010
Craftsman 917.270514 not starting?
check to see if your getting power to the solenoid on the bottom of the carb a bad safety switch will shut it off they also stick closed from old fuel
Jun 04, 2012 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftman riding mower quit, ran one side of deck into a dirt bank. No power, the fuse is behind dash, my gas tank is there. Do i remove it?
I unhooked my wiring harness from frame so you can get to the fuse. The gas tank shouldn't be that to remove. 4 bolts and the gas line.
Jul 02, 2011 | Craftsman 21 Hp 42" Lawn Tractor Riding...
I have a 15.5 HP, Craftman lawn tractor. I'm having problem with it staying running. It will run just find for 20-30 minutes and then stop abruptly. I have changed the spark plug, oil, cleaned the air...
Check the Blade Safety Switch. Also check if the Carburettor requires a good cleaning and overhaul or not. After that check if there is any air leak or air in the fuel line.
Please accept the solution if it's helpful. Do get back to us for any further query.
Thanks for contacting fixya.com
Sep 29, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Should the fuel filter have gas in it while running - Craftman lawn tractor - 917.271024
Yes, fuel system is gravity fed. If there is fuel in the tank, there should be fuel in the filter.
Aug 29, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
I have a craftsman gt 6000 with kohler 18 hp magnum today it started fine and ran goodd for over an hour i put gas in it and ti would not stay runing it stated surging and popping and cuts off
Your carb is full of trash. you also probaly need to clean out the bottom of your fuel tank, blow out your lines and replace the fuel filter. I have 2 mowers with kohler engines and clean out the fuel tanks fuel lines and carbs 1 time a year. There is also a fuel shut solenoid on the carb this is normally problem if the engine does not run. but I am certain your problem is a simple fix, all you have to do is clean everything out in the fuel system.
Sep 13, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftman 11 lawn mower...wont start have checked the plugs and it has spark and the carb works fine but still does not run...please help
Hi..my name is Keith..and if you have sparkand it wont start..i would suspect old gas..lawn mowers are very sensitive to gasoline..and it likes fresh gas..but if you do have gas in it that is more than a month old..it needs to be drained and not mixed with fresh gas..but im just going on what you are saying about having spark and the carb is working fine..i hope this has helped..if not please write me back
Jul 04, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Won't stay running
Try cleaning out the fuel tank and replacing the fuel filter. What happens is it has enuf gas to run but not enuf to run when it demans more power. You might find earwigs int he tank clogging the fuel hole at the bottom (common problem)
good luck
May 17, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
WILL NOT CHARGE /CRAFTMAN LT 1000 17.5 OHV
You can jump off a off truck ,just dont have the truck running the
altnator can be to strong for the diodes in the tractors charging system (rectiforer).
Feb 21, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Poulan 42-Inch Steel Deck 17.5 HP Briggs & Stratton I/C Engine With 6 Speed Logo
146 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
