Question about Black & Decker Black&Decker Home Cafe Single Serve Coffee Maker
Oily film no matter how many times i have cleaned out my coffee pot with vinegar and water, there is an oily film in it. i only use spring water to fill it so it cant be my water.
  • 487 Answers
Ok descale your coffee pot ( machine) with vinegar.
If it still does it it will be your coffee or the temp of the brewer is too low.
I am a coffee junk and have had this problem. If your water is too cold it sometimes happens but coffee brands do this too. Some brands roast thei coffee too long and that releases the coffees' natural oils.
No problem if the taste is good
Posted on Apr 19, 2008
I think my bunn-o-matic VPR needs cleaning and I do not have a manual for this machine. Can you advise on how to do this?
To clean the vpr you will need to take the lid off the machine. Be sure to unplug while doing this. First clean the water tray. You can unscrew the nut holding this tray and clean the tray in your sink. Put the tray back in and put the lid back on. Plug coffee maker in. Fill one coffee pot with vinegar and pour it in machine. After the water finishes coming out let the coffee maker sit overnight. Before you start filling the maker with water at least 6 times, be sure to clean the spray head. Make sure the 5 or 6 holes are free and clear of any build up. Then start with fresh water. Fill the coffee pot with fresh clean water and pour into machine. Let it finish and do this at least 6 times. If you can still taste or smell the vinegar repeat until you cant.
Mar 19, 2013 | Bunn Pour-O-Matic VPR
How do I use vinegar to clean my coffee pot? I heard it was a good method but have no idea what to do with it.
For a 12 cup coffee maker. Fill the coffee pot (the part that holds the water) with 6 cups of vinegar and then top up with water until you reach the line. Now turn it on as if you were making regular coffee. Once the hot vinegar has come through, pour it into the water cavity and run the cycle again.
Now you can tip the vinegar out and clean out the coffee pot with soapy water. Run another cycle but with plain water this time and after that you should be able to use your machine without any leftover residue from the vinegar.
Feb 25, 2013 | Home
How do you clean this product using vinegar?
Put a small amount of vinegar in the coffee pot, fill with water "12 cups" add contents to main unit and turn on, when finished! empty pot in sink and refill coffee pot with water only and cycle it through three to four times to make sure the vinegar is flushed out of the lines, adding fresh water each cycle.
May 19, 2011 | Mr. Coffee 12-Cup Programmable Coffeemaker
How to clean
mcdevito75 here, Start with a new paper filter or claen the perminant one, you"ll need enough WHITE VINEGAT to fill the pot itself 3/4 full of this WHITE VINEGAR, NOW pour the pot of 3/4 full of WHITE VINEGAR into the resovoir, replace pot in the coffeee maker and cycle thru the vinegar 3 times, each time letting the mavhine cool a bit for easy handleing, on the 3 rd cycle stop 1/2 thru the brew cycle, let machine cool for 30 Minutes, then complete that cycle. Now repeat with fresh water to reove all the vinegar from the machine. Your coffee maker should now be good as new.
Jun 22, 2010 | Cuisinart Brew Central 12-cup Coffee Maker
I have a Mr. Coffee model JHX33 coffee maker, and have lost the owners manual I need cleaning instructions. Can you possibly help me?\r\n Thanks Eddie Thatcher
mcdevito75 here, I too have a Mr. Coffee, coffee maker 4 cup. The instuctions shold be just about the same for both our Mr. Coffee mavhines, ------ With a new or clean filter in the machine fill the pot 3/4 way full of White Vinegaar the pour that into the resovior, place thepot back in place on the machine and start the machine up, let the vinegar cycle thru, when done the vinegar is now in the pot, empty the pot back into the resovoir, and cycle again, this time 1/2 way thru the cycle or pot half full stop the cycle for 30 mins. this will keep the vinegar in the machine and claen all the little ports. After 30 mins, complete the cycle. repaet this 2 more times. Then repaet once the machine is cool but this time use plain water, repaeat plain water cycle 3--4 times to clean out all the vinegar, Mr. Coofee needs claening when you notice coffee brewing has slowed down or maCHINE STEAMS TOO MUCH DURING BREWING CYCLE.
Jun 19, 2010 | Juicers
DCC-1200 coffeemaker cleaning button flashes constantly after it starts,slowly makes coffee and is strong and lots of steam. I have cleaned twice with vinegar solution. What should I do. The coffee maker...
Make sure that when you do the vinegar solution, you do at least 4 cups of white vinegar, and fill it up the rest of the way (max fill line) with water. The manual says to "fill to capacity with a mixture of 1/3 vinegar and 2/3 water," which lots of people misunderstand, and think it means "1/3 CUP vinegar and 2/3 CUP water," which is not the case. It means 1/3 of your 12 cups (and 1/3 times 12 is 4 cups) of vinegar, and 2/3 of your 12 cups (aka, fill it up the rest of the way) of water.
You might have to let it soak for an hour before you try to brew it--this lets the vinegar work at the calcium buildup a LOT better (kind of like soaking your pots and pans before you try to clean them), but it should definitely work for you. If not, call Cuisinart's tech support (1 800 726 0190) and they might be able to get you a replacement :)
Aug 21, 2009 | Cuisinart DCC-1200 Coffee Maker
Brewing time is too long 20 min for 6cups
You have an obstruction in the feed line to the heating element. I found coffee grounds before the check valve. I had to take the bottom off it which I am sure the manufacture wouldn't approve of but I was at my wits end and ready to toss it. I just brewed a full pot 10 minutes!!!
Aug 18, 2009 | Cuisinart DCC-1200 Coffee Maker
Need to find manual for bunn coffee maker
You can go to Bunn.com and print one out or I think buy one. To clean you need a deliming spring and white vinegar. You put the spring up into the hole where your water comes out of to empty into your carafe. Remove the grounds basket. then remove the spray head by twisting off. Then you are ready to put the spring into the hole. Insert all but a couple of inches into it. If it has been awhile you may have to force it by twisting and pushing. Work the spring up and down and it will eventually go in and out with no problem. Check the holes in the spray head to make sure they are clean and free of any build up. As you know Bunn has a reservoir where water is kept hot. You put in and what is in the reservoir comes out. Pour 1 quart of white vinegar into the pot. Let it sit for two or three hours or longer is OK. After your wait pour water in 8 to 10 times to flush all vinegar or you can unplug the pot and turn upside down over the sink. If you do this while the water is still hot be careful. Most of the water will come out of the hole where you put the deliming spring into. Some will come out of the top possibly. If you do it this way make sure you fill back with water before you turn it back on. Repeat vinegar flushes again if you water isin't running clear yet.
Mar 14, 2009 | Bunn NHB Coffee Maker
Coffe residue inside coffee pot
Add some automatic dishwasher detergent ( maybe 1/4 cup) and fill the rest of the pot up with very hot water. Swirl to combine. Let stand for a few hours. Use a bottle brush to scrub the pot. Or get some denture cleaner tablets and throw them into the pot with hot water. Let stand a few hours or overnight, then scrub with bottle brush. I've tried both methods on my coffee pot and both work great for me.
Jan 15, 2009 | Cuisinart Grind and Brew 10 Cup Coffee...
Err2 message
Suggestion was Descaling the Coffee Maker from KitchenAid Phoebe (I'm guessing customer support)
http://kitchenaidconversations.com/forums/topic.asp?TOPIC_ID=14441&SearchTerms=err+2
Cleaning scale from coffee maker DO NOT USE THAT MUCH VINEGAR! Put a tiny bit of vinegar in the carafe and fill carafe the rest of the way with water. Run that vinegar/water through machine. Using another container, fill machine with plain water and run that through. Repeat until the vinegar taste is gone. If you do not run lots of plain water through the machine after, your coffee will taste like...um...disgusting!
To clean hard water deposits from a coffeemaker use distilled white vinegar. You may need to use as much as a gallon if the scale buildup is really bad. Fill clean coffee pot one half full of vinegar and run through machine as if making coffee. Repeat this process several times using fresh vinager until it comes out clear. Do this once a week and your maker will work much better.
Jun 20, 2008 | KitchenAid KCM511 Coffee Maker
Coffee Makers & Espresso Machines Logo
114 people viewed this question
Top Black & Decker Coffee Makers & Espresso Machines Experts
eyecam
Henry  Thomas
Henry Thomas
Are you a Black & Decker Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
