Question about Samsung SCX-4100 All-In-One Laser Printer
No paper When I try and print it says "PC print pending" then flashes " [no paper} add paper ". The tray has paper in it. I have tried one sheet to several sheets. I can feed through manually (but it grabs and feeds through on an angle).
  • Tracoi Apr 19, 2008
    I have pulled out the tray and tried to locate the plastic flags - but cannot see anything sticking up. I had a look through the printer and found one plastic tab (tooth shaped) that is moving freely. I have had a look in Printers and Faxes and no job is pending. It seems to be in the printers memory now.
  • Anonymous Apr 20, 2008
    I have the same problem. This only happens if I leave the printer on for awhile. If I turn off the printer, and turn it on ONLY when I need to print then it works. If its been idling for a couple hours, the "NO PAPER" message will keep flashing even though there is paper in the tray. Seems like an overheating problem for me. Very frusterating...
I had this problem on Win XP Pro. The machine would scan, local copy and manual feed. Contacted Samsung and they instructed me to download and reinstall the latest driver from their website. The problem now appears to fixed. Their view was that the driver got screwed. That the wonders of Windows! Liam
Posted on May 21, 2008
  • 61 Answers
If you have turned off the printer, with a job pending, and you turn on again, the job is partially lost, and the first part of a print job have the initial commands for formatting the print, so some printers just print loose characters, other react like yours, and keep waiting. What you can do, is: first: turn off the printer; second: cancel the job (wait several minutes till the cancelling is complete, and the printer window in your pc is completely empty, so turn on the printer again, and try to prnt.
Posted on Apr 19, 2008
  • Antonio Cirio Apr 19, 2008
    In the printer memory does not remains anything after you turn off and tur on the printer again. Maybe you have a problem in the logical board of the printer. In this case you´ll have to call a technician.
    President:
  • 2,351 Answers
Tracoi, first you need to clear pending prints. If your using WinXP, click the start button slide up to & left click on Printer and Faxes. Click on your printer & clear/end prints pending. Power off your printer & look in the printer where the paper path is. As the paper passes through the printer, it pushes against little black sticks that wobble back and forth to trip the different sensors. These little 'flags' usually kind of stick up in the middle of the plastic along the paper path. Look over the whole paper path and find all the little flags and make sure they're all moving freely. Sometime they get knocked out of place. You only need one to mess up the printer function.
Luck!
If this did not help just let me know & we'll try something else.
Mike
Every time I try to print to my Dell 3110cn printer, a message pops up stating "Load Tray 1 024965 Executive" Paper tray is full and inserted correctly...what do I need to do to make it print?
I would try two steps:
1) Check the "pending documents" for your printer and make sure the printer queue is empty - delete any pending document.
2) Check the printer settings and make sure the default paper type is not set to "Executive". You may also check this in the paper properties of the document that you want to print.
Apr 29, 2014 | Dell 3110cn Laser Printer
SCX-4216 "No Paper" message
Check this link it has a step by step solution that you can try http://www.fixya.com/support/t216317-no_paper_error
Hope that helps..........
Aug 07, 2008 | Samsung SCX-4100 All-In-One Laser Printer
I tried to print a document from my computer and the printer says( No paper) Add paper. The tray is full. It then says PC Print Pending. Can you tell me what to do to clear this problem. I have a AC205..
Your problem may be a simple as paper dust.
Take all the covers off get a can of canned air and blow out everywhere you can reach especially in the areas where there are or my be sensors. Be careful not to spay to much in one place or you'll end up with condensation and then condensation problems.
Jun 14, 2010 | Ricoh AC205 All-In-One Laser Printer
Media is not picked up from the media tray
save the document to your desktop or copy and paste into word or notepad..
tell ya printer settings to clean nozzles.
remove paper.
place paper into tray area but not a whole lot....15-20 sheets...
now print...hows that..:-)
Sep 15, 2009 | HP Officejet Pro L7590 All-in-One InkJet...
The printer keeps printing the same page then come up withcheck paper size then flashes change paper size, I have turned everything off and turned it back on again and it just prints the same page and...
Hi..
I think your there is a pending command to print, even if you have turned your printer on and off, it will print already because the pending printed papers in your computer is automatically printed, you need to check the printer status in your computer. just click start then all programs, then click printers and fax, now you can see now the printer icon just double click that, if you can see a pending printed, just right click and cancel, if you can not see the pending you printed document, you need to restart your computer so that all the pending command will turn out.
Good luck
Regards
PCmania
Jul 09, 2009 | Canon PRINTER/COPIER/SCANNER All-In-One...
Usually won't print from upper tray
These printer have a problem grabing the paper from the upper tray it might look like it was ready to print but they usally miss grabing the second sheet of paper from the upper tray.
Jun 27, 2009 | Brother HL 2140 Laser Printer
I have a Dell 946 printer and Im trying to print Avery 8871 business card sheets. When I press print the printer will not feed the sheet through and it says there is no paper. I tried to adjust the...
I looked up the user guide at Dell's website and looked up printing cards.
  • The print side of the cards faces down.
  • The cards are centered on the paper exit tray.
  • You select Automatic, Normal, or Photo print quality.
  • Apparently you need to feed the card stock one page at a time into the printer on TOP of the paper exit try (The card stock will feed in from above the normal paper load try [remove paper from the paper tray] and once printed come back to the same spot.
    Jan 26, 2009 | Computers & Internet
    Control panel flashing F
    It may be some pending job showing, please reboot your pc, power off printer and then resume back and check if everything goes straight.
    Let me know the operating system and other detail so help you further..
    Jan 19, 2009 | Sharp AR-161 Laser Printer
    When printing paper continues to jam.
    1. Take out paper tray 1.
    2. Remove any jammed sheets of paper you find there.
    3. Once you have done this, reinstall the paper tray and try printing again.
      Note: You may receive a message informing you that another sheet of paper is jammed elsewhere in the printer. If so, please open the front door and remove the toner cartridge. Also open the rear door of the printer (and the duplex option if a duplex unit is installed). Remove any and all jammed sheets of paper you find. Then try printing again.
    4. If the printer jams again with a 241 Paper Jam error message, look to see if it has tried to feed a sheet of paper out of the tray.
    Dec 16, 2008 | Office Equipment & Supplies
    Not printing
    There is probably a paper jam in the tray feed path. The other situation is that the tray paper pick up roller has become hardened/polished, or the paper tray paper is greasy. First step, take the paper from the tray, and fan it out, so each sheet is separated from the next. try it with jut a dozen or so sheets, change the paper.
    Thoroughly check the paper feed path.
    If not working, then check/clean the rollers.
    Jan 20, 2008 | Kyocera FS-720 Laser Printer
    Samsung SCX-4100 All-In-One Laser Printer Logo
    451 people viewed this question
    Top Samsung Office Equipment & Supplies Experts
    mukhtar21 shaikh
    mukhtar21 shaikh
    HEMANT GROVER
    CheckitRight
    CheckitRight
    Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
