Question about Broan-NuTone WHV20 Fan
I need the replacement Control switch, Model CFVS-1
2 Suggested Answers
SOURCE: Need to replace switch but can't find replacement
An update: Grainger has several fan controls with the same 10A capacity as the one you're looking to replace: http://www.grainger.com/Grainger/categories/hvacr/controls/fan-speed-control
Posted on Aug 24, 2008
Hunter ceiling fan, replacing speed switch, what wire goes to the L, 1, 2, and 3?
I can only guess since I don't know what model or what color wires you have. Here's wiring for single stack switch on some Hunters;
L- black
1 - grey
2 - brown
3 - green
Hope this helps.
Feb 06, 2016 | Hunter Ceiling Fan Control Switch
Push turn on switch
Since no model number was given, a few things could be at fault, 1: the door switch, 2: a thermal fuse, 3: if there is a black control relay behind the control panel where you replaced the start switch. Pleazer Appliance...
Apr 08, 2014 | Kenmore Dryers
E1 F5 error message on my kenmore range
This is a door lock error
1. If door latched:
  1. Disconnect power from unit.
  2. Check wires and connectors from control to door switch, then from door switch to control. If no damage to wires and all connectors okay, proceed to step C.
  3. Replace door switch.
  4. Re-apply power.
  5. Press and hold any key down for 1 minute to clear F5 failure code from memory. F2 will appear. Press CANCEL and observe for 1 minute to ensure operation is correct. What is the model number?
Dec 07, 2012 | Kitchen Ranges
KITCHENAID OVEN MODEL KEMS 308 SELF CLEANING
Hi David.
The error is F5E1 and means door latch problem detected. This happened in consequence of the power cut while the unit was in self clean.
Try pressing and holding down the cancel button for one minute.
Try disconnecting power from circuit breaker for ten minutes, that will reset the control board.
If that does not work the door latch, wiring and control module must be tested and the defective part replaced.
Here full troubleshooting from Kitchenaid service papers:
1. If the door lock is latched:
  1. Disconnect power.
  2. Check wiring and connectors from control module to door switch, then from door switch to control (do a continuity test). If no damage to wires and all connectors okay, proceed to step 3.
  3. Replace the door switch.
  4. Re-apply power.
  5. Press and hold down any key down for 1 minute to clear the F5 failure code from memory. F2 will appear. Press CANCEL and wait one minute.
2. If door not latched:
  2. Check wires and connectors from control to latch switch, then from latch switch to control. If no damage to wires and all connectors okay, proceed to step C.
  3. Repeat steps 1 and 2 for the door switch.
3. Measure door switch (door open =switch open - Ohms infinity/small low voltage terminals depending on test done- Ohms reading is done with power off). Replace switch if defective.
4. Measure latch switch (unlatch = switch open, CAUTION - oven light contacts are closed). Replace switch if defective.
5. If corrections are made in any step, reconnect power to control. Press and hold any key for 1 minute to clear R failure code from memory. F2 will appear. Press CANCEL and observe for 1 minute to ensure operation is correct.
6. If the problem remains, disconnect power and replace control module.
Regards.
Ginko
Jan 01, 2012 | Ovens
Whirlpool TXFE366LVQ. When I turn selfclean after few minutes it shuts itself off and displays code F5E2
An F5 error code indicates that you need to check the oven door or the latching switch. The switch is used when cleaning the oven, for safe closure. If you find that the door or the latch switch do not function, you may need to replace them
F5-E2 means latch during clean error; the door and latch switch need checking and possible replacement.
1. If door latched:
  4. Re-apply power.
  3. Repeat steps A and B for door switch.
3. Measure door switch (door open = switch open small low voltage terminals). Replace switch if defective.
6. If failure remains, disconnect power and replace control.
Hope helps.
Jul 14, 2011 | Ovens
How to replace a neutral safety switch in a 2004 Pontiac Aztek. Key turns but absolutely nothing happens. Battery is fine. It is like the car won't recognize it is in park.
Fig. Automatic Transmission Shift Lock Control Switch (1) Steering Column Mounted
Fig. Showing Shift lock control switch (3); with floor shifter on Regal model. (1); Performance shift switch (2); transmission control position indicator bulb
Feb 04, 2011 | Pontiac Aztek Cars & Trucks
I have a Kenmore Range 95802000 and when I go to self clean it gives me an error E1 F5 .. What do I do.. IT wont lock or start cleaning. Thanks - Toni
Check the door switch and latch switch for continuity as described. If you need diagrams or illustrations of your specific model try this link
Replacing oven ERC
There is also a link to show you how to use a multi meter
Oct 15, 2010 | Kenmore Kitchen Ranges
A/c heater won't blow... Blower works even replaced with new blower but still won't blow... Is there a relay to replace? The fuse for a/c is good
did you check to see if the a/c belt is still on the a/c puller ? if so then try a flush of all hoses.
Oct 25, 2009 | 1998 GMC Blazer
Range with Error Code F5 E0
HI.The Door switches do not agree (condition exists when door switch is closed indicating an open door, and latch switch is closed indicating a locked door)
1. If door latched:
  4. Re-apply power.
Jul 18, 2009 | Kitchen Ranges
Aug 13, 2008 | Broan-NuTone WHV20 Fan
Broan-NuTone WHV20 Fan Logo
142 people viewed this question
Top Broan-NuTone Dryers Experts
Mike Squire
maddyveggie
Level 1 Expert
Are you a Broan-NuTone Dryer Expert? Answer questions, earn points and help others
