Question about Whirlpool Duet GHW9150P Front Load Washer
Machine passed through all cycles until the drain cycle, then stops. No kinked drain or water hoses and no frozen pipes in Miami. Unplugged, tried drain and spin again with no results. Unplugged, started at beginning cycle with same results, no drain. Unit spins okay. There does seem to be an electronic hum now but not in the beginning or during other cycles. Water Pump? Thanks for the help.
  • aerodrome Jul 09, 2010
    It did help, thanks. There is a filter container behind the front panel and I found a sock, but the pump motor is binding so I think I'll need to replace that tomorrow. Thanks again.
  • 259 Answers
You will want to check your drain pump filter on this machine.
You can access the filter by removing the three screws located at the very bottom of the front panel and pull it out slightly to allow it to drop off the washer.
With the cover removed you will see the drain pump in the front of the base of the machine. The pump is equipped with a pre-filter that can be removed by unscrewing it and pulling it forwards.
Be aware that any water left in the tub is going to come out to greet you, so be prepared. I often tip the machine back to limit the amount that can come out when doing this.
After removing the filter and cleaning whatever treasures you may find from it, be sure to inspect the opening that it slides into before re-installing it. Look way in the back of the opening for any change and pay close attention to the opening on the right as well for anything caught there.
If for some reason you do not find anything in this clean out you may have a defective pump on your hands or an issue with where the washer drains out. I have found many a laundry tub with a restricted drain that allows the water to be siphoned right back into the washer after the washer stops pumping.
Good luck with this!!
Posted on Jul 08, 2010
Testimonial: "Thanks so much. You were right on. Found a sock blocking the flow. There was some other stuff too, dime, screws and cloth materials. That was too easy. But the pump was also binding up so off to get one tomorrow. Thanks again, this was a big help. "
  • Whirlpool Expert
  • 414 Answers
Sounds like you may have something stuck in the pump, coin etc. Have tried to find the manual online without success. If you have your user manual check to see if there is a filter you can check. Normally it would be at the front of the w/m behind a flap or removeable plinth. Hope this helps.
What does E20 mean
The E20 error code indicates a problem with water drainage. Inspect the drainage hose for kinks that could impede the drainage flow. This frequently occurs when the machine is pushed up against the wall without allowing room for the hoses. If there are no kinks, the hose is probably clogged. Carefully detach the hose from the machine, and use a garden hose to force water through it. If the water doesn't pass through, use a plumber's snake to clear the clog. If there is no clog, inspect the drain pump for clogs. Unplug the machine, and open the small rectangular door towards the bottom of the front of the machine. Drain the pump through the emptying hose into a container until the water flow stops, and rotate the pump impeller to clear any foreign objects. Close the pump and restart the cycle. If the problem persists, contact a service center.
May 18, 2012 | Zanussi ZWF1430W Front Load Washer
Ld signal won't drain
For the LD error please check for the following:
  • Check for kinked or clogged Drain Hose: Remove any obstructions in the drain hose / stand pipe / utility sink. Straighten the hose to remove any kinks. If the washer is unable to drain due to a kinked or restricted drain hose, the washer may not spin.
  • Check for Standpipe higher than 8 feet above the floor:The pump is not powerful enough to pump water to heights greater than 8ft. The water will remain in the basket.
  • Check for excessive suds in the washer: Drain pumps cannot drain suds out of the washer.
To clear the suds condition: Check the drain hose and make sure the hose is not plugged or kinked Press pause/cancel twice to clear the display Run the machine through a Rinse/Spin cycle using cold water, then a Normal cycle using cold water.
Note: Do NOT add any additional detergent. This will remove much of the remaining detergent held in the fabric. This step may have to be repeated to remove all the detergent.
Jan 16, 2011 | Maytag Bravos MTW6600T Top Load Washer
Goes partly through cycle-then gives code ld
Hello there:
To clear the suds condition: Check the drain hose and make sure the hose is not plugged or kinked Press pause/cancel twice to clear the display Run the machine through a Rinse/Spin cycle using cold water, then a Normal cycle using cold water.Note: Do NOT add any additional detergent. This will remove much of the remaining detergent held in the fabric. This step may have to be repeated to remove all the detergent. If the appliance does not accept inputs from the control panel, follow the Hard Reset steps below to reset the control:
  • Unplug or turn the circuit breaker off for 30 seconds.
  • Plug the power cord into the wall outlet or turn the breaker back on and wait 30 seconds.
  • Press the Pause / Cancel / Stop button twice to clear the display.
  • Start a short cycle, to check operation of the appliance, by selecting a cycle and pressing and holding the start button until the appliance starts.
Note: If the Hard Reset does not work, there may be an internal failure with the appliance, that requires service.The SD error code is caused by using the wrong detergent or excessive amounts of detergent.
To correct the issue: Make sure to use HE detergent. Note: Using Non - HE Detergent will cause oversudsing and can damage the washer. Do not use too much detergent.
Note: If using HE 2x - 5x concentrate detergent, reduce the amount being used. The washer will try to run a mini-clean out cycle using cold water and a 5 minute pause to clear the suds. If this cycle does not clear the display and complete the cycle the clothing may need to be rinsed by hand and then rewashed without detergent.
I have included a list of all the error codes and what they indicate below this includes the F50 error code. I recommend scheduling a service repair so a technician can properly diagnose and repair your washe
Dec 30, 2010 | Washing Machines
Error code HF
Washer displaying code message and tone sounds S "HF" 0Nater Inlet Problem--no water or insufficient water supply) Select PAUSE/CANCEL twice to cancel the cycle. Unplug washer or disconnect power. Check the following: Are water faucets completely turned on? Are screens at inlet hose connection to washer clogged? Are water inlet hoses kinked? Are water inlet hoses frozen? Plug in washer or reconnect power. Re-select cycle and press START. If the problem remains, call for service. "F02" (Drain Problem) Select PAUSE/CANCEL twice to cancel the cycle, Unplug washer or disconnect power. Cl_eck the following: Is the drain hose kinked? ts the drain hose frozen? Is the drain hose clogged? Is the drain hose more than 96 in. (2.4 m) above the floor? = "SUD" (Suds Routine) When excessive suds are detected, a suds routine
Sep 23, 2010 | Kenmore Elite 45986 Front Load Washer
Code F 02 draining problem. pipe not kinked or plugged
you may need to check the drain hoses that lead to the drain pump and look for any kind of restrictions,or some thing stopping the impellar wheel from turning in order to drain the water
Jun 05, 2010 | Maytag EPIC MFW9600S
Have the Indesit Moon washing machine and it will not finnish the wash cycle and go into spin mode. Is there anything I can do? Thanks
A washing machine won't spin if the water can't drain. Check hoses for any kinks or clogs that may prevent the water from draining. If a hose has kinks, try to straighten out the kinked hose. If it can't be straighten sufficiently, replace the hose. If hoses are not kinked, check for clogged hoses. This can be done by using the screwdrivers to remove the hoses and looking for clogs or running a water hose through the clogged hose to remove the clog. Use the rags and bucket to clean up the water that comes out of the hoses when they are disconnected. Once the clog is cleared, put the drain hose back into place. The washer should drain and spin now if a clogged or kinked hose was the problem.
If the washer still won't drain or spin, check to see if the lid is not closing all the way or if the lid switch is not clicking into place. Close the lid and make sure that it closes all the way down. When the lid closes, the lid switch should click. If there is no clicking sound, then the switch may need to be replaced.
Another possibility for a washing machine to not spin or drain is the pump. With the back panel still off the washer, check the pump with the voltmeter to ensure that the pump is getting power.
Please donot forget to rate and accept my answer...
Apr 14, 2010 | Indesit W 123 Front Load Washer
Bosch dishwasher shx55m with bottom tub full of water
The dishwasher really shouldn't pass any particles near large enough to clog the drain hose. It sounds more like a mechanical issue. Check the circuit breaker to make sure it's not tripped. See if you can hit a cancel button or something to make it drain. Try to run another cycle. If the computer is stuck or acting funny, trying cutting the power for a while, holding down a stop/reset/cancel button, or running a cycle that you don't usually run. I had this kitchenaid that would randomly refuse the normal wash cycle, but would run fine when you ran rinse only or something, then regular wash and everything would be fine again too. If the line somehow is clogged, there's a good chance it's right where the hose connects to the disposal or drain pipe.
Feb 18, 2010 | Bosch Integra® 500 SHX55M05UC Built-in...
Washer stops after aggatating and wont drain
My Kenmore 70Series washer goes through the wash cycle then just stops when it is to drain and then spin.
Jun 10, 2009 | Whirlpool Washing Machines
Flashing F2
“F02” (Drain Problem)
Is the drain hose frozen?
Is the drain hose more than 96" (2.4 m) above the floor?
After running this check list, plug back up and try a complete cycle using cold water and no detergent. Sudding can mimic a drainage issue as well. make sure you are using the correct HE detergent to prevent over sudding.
Feb 22, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washer fills up than starts draining while in wash cycle
Hello , here is the fix-your drain hose is placed to low in the drain line in the wall, it can not be placed in water or it will siphon the water out of your washer into the drain pipe and it wont stop until it hits air. try pulling your drain hose up and out of the drain and get a zip tie or cable and tie it to one of the water valves by the drain pipe placing the end of the drain hose about 5-6 inches inside the drain pipe. Let me know if you have any other questions and good luck it will work.
Phil
Jan 28, 2009 | Frigidaire FLEB8200DS Top Load Stacked...
Whirlpool Duet GHW9150P Front Load Washer Logo
657 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
