Question about EPoX EP-8KRA2+ Motherboard
Computer boots but no display on monitor why?
Hello there,
my computer boots up the lights are showing and the motherboard says FF on it Meaning Fully Functional but when the computer is booting the keyboard lights dont come on and i cant hear the beep that it makes i have already checked the cpu, ram ,power supply and graphics card but i dont know what it is that doesnt let the monitor start.
when it doesnt start i have to turn it off then open the case and take 1 stick of ram out and put it back in then it turns on or sometimes i have too take the sound cable out of the sound card (Built into the motherboard) so now i am running out of ideas. some people are saying on the internet that it is my graphics card and some are saying the whole motherboard is dead but if the whole motherboard was dead then the computer wouldnt even start up or boot or anything.
what could it be
  • 2961 Answers
SOURCE: Problem with starting the computer
remove the ram and check for any dust deposits in the ram slot, if you replaced the same ram stick, it should be alright. If you need to you may need to reset the bios, by way of the JBAT 1 terminal CLRCLK, or CLRCMOS terminals or similair, so refer to your manual. Also remove all peripherals apart from the ram processor and hard drive and try again, if you have 2 ram sticks try one at a time
Posted on Aug 13, 2007
  • 196 Answers
There are many beep codes listed here:
What is "FF"?
Obviously, this sounds like a video problem. Is this a new build? Any previous problems?
Is there a video card?
Posted on Nov 28, 2007
  • 176 Answers
SOURCE: Bios reports incorrect memory speed
try to update the BIOS ! ... it may correct the problem ...
when using only one module at a time, doest it work on the correct speed 800Mhz ?!
the system will be working on the BIOS declared parameters, at 677 !
Also read all the indications in the motherboard user manual, regarding memory (supported brands, speed, slot allocation .... )
thought i hope the BIOS update will do the trick ...tell me if it worked ...
Posted on Jan 25, 2008
  • 98 Answers
SOURCE: my 2themax mpotherboard EP-8KDA3I displays
Most probably yes, if it started happening after you installed new RAM modules. There are to possibilities:
  • one or more of RAM modules is faulty and will need to be replaced or removed
  • the motherboard does not support this layout of the modules which means that you will have to remove 512 MB module
I suggest you remove one of 1 GB memory modules and see if it works. If it does, than put it back and remove the other 1 GB module. If it works again, than motherboard does not support having one 512 MB module and two 1 GB modules at the same time.
Your responses are intended to improve the level of service provided. Please rate your experience.
Posted on Jan 17, 2009
  • 46 Answers
SOURCE: no display , monitor light blinking
it could be you video card or onboard video whichever you use or even the cable! make sure you test with a different cable then if that doesnt work try another video card if you use one
Posted on Jun 29, 2009
When my computer was power on then cpu was run but the monitor doesn't display ...
If the monitor did not display the CMOS messages as computer was booting then there is an issue either with the monitor or the video card/motherboard.
Is there a light on the monitor to show it has power to it?
Is the video cable connected securely at both ends?
If all above is true then suggest looking at video card.
Aug 26, 2013 | MSI PM8M-V Motherboard
I have HCL Ezeebee desktop computer when we boot the system monitor, keyboard, mouse blink for a while and monitor (HCL) show 'no signal' message, and keyboard num lock led not display mouse i
No signal at the monitor indicates (if you know the monitor is working ok) a failure of the graphics chip or graphics card, The lack of indicator light on the num lock LED and the lack of power to the mouse would indicate that there is a major issue with the motherboard.
you can try using another monitor to confirm the problem lies with the graphics, and in the case of the keyboard and mouse, swap them for a usb version, if they work, the Ps2 ports are probably damaged.
I'd be thinking of replacing the motherboard
May 19, 2012 | Computers & Internet
I have this pc HP Presario uWave2 Socket462 Motherboard compaq presario 4000. The problem is that is doens't on, the cpu has the light in green but the monitor doesn't show anything, something if they...
alot of motherboards use shared memory for display meaning that if the memory cards lose connection no video.
take memory cards out of the computer and clean the gold contacts with pencil eraser and try rebooting the computer to see if you get video if not try 1 memory card at a time to see if there is a bad stick of ram causing it not to show video.
Jun 26, 2010 | Compaq Presario 4000 System Board...
On my motherboard the counter shows FF what does it mean, and how can I fix the problem(my monitor doesn't switch on)
The FF on the board just means that the motherboard completed an attempt to boot. That's it. Very vague i know...but in every instance of the ff code the board had to be replaced. Error code 2D may indicate a video problem...ultimately we could never know what to expect with generic codes like that...As an engineer I I would go a step further and try disconnecting the hard drive to see if you get the computer to get to the BIOS which would indicate a failed drive or corrupt OS Otherwise you are probably correct in thinking you might have a video problem which is onboard and would still require a board replacement. But save yourself the trouble and get another computer which doesn't have motherboards in it from shut down companies. I'd be glad to explore your options with you.
Nov 10, 2009 | Soltek SL-K890Pro-939 Motherboard
I have an ep-8kta3+pro m/board. Occasionally it fails to start up and the LEDs are stuck on FF. What does the code FF mean?
FF mean kind for computer geeks Fatal Failure meaning the only solution is geting a new one thanks and good luck
Oct 20, 2009 | EPoX EP-8KTA3+ Pro Motherboard
Computer not turning on
open core voltage connection after if that power on
so problem in your motherboard vrm circuit goes off
Jan 17, 2009 | Evga nForce 680i SLI (122CKNF68)...
Computer will not turn on. it is just "sparking" ie fans/lights/come on for split second and then everything goes off. on my evga motherboard there is a FF display. i have been troubleshooting easy things...
Not sure about the FF. If everything comes on and then powers off after only a split second, there is not time for the display to show anything. I'm suspecting it is indicating there is no signal.
The very first thing I would try on this computer is the power supply (assuming it's a desktop system).
A faulty power supply can act like this.
Recieving error code FF and pc will not boot/recognise harddrive
the problem it is in harddisk
is that u have ur smp (power supply)
just check the power supply & insert the cable
properly in to the slot of motherboard & check whether the display has come if it comes than boot the xp cd if problem occurs go to nearest shop of computer
Dec 04, 2008 | Abit AV8 Motherboard
Mother board dead
Hello how are you. Please give me ome detailed information the make and model of the computer. i will help you with this. Easy. This is what I do for a living.
Thank you hope to here from you
Feb 10, 2008 | Intel Motherboard
What is "FF"?
Nov 27, 2007 | EPoX EP-4PEA+ Motherboard
EPoX EP-8KRA2+ Motherboard Logo
113 people viewed this question
Top EPoX Computers & Internet Experts
Steven Wander
Steven Wander
Are you an EPoX Computer and Internet Expert? Answer questions, earn points and help others
