Question about Kenmore 24 in. 17033 Built-in Dishwasher
Kenmore dishwasher model #665-17034402 the dishes
Kenmore dishwasher model #665-17034402 the dishes on the top rack do not get clean
  • 3,230 Answers
Well it seems that there must be some problem with the spray arms - There's a spray arm at the bottom of your dishwasher, and other spray arm located directly beneath the upper rack of dishes and/or above the upper rack, it may have a tall spray tube mounted to the center of it. If debris is blocking the holes in the spray arms where the water comes out, it could cause cleaning problems. Regularly inspect each of the spray arms and clean out the holes as necessary. Please post comments for further help or information.........
Good Luck!!
Thanks
Posted on Jul 08, 2010
Kenmore dishwasher 66513242k900wont clean top dishes
Check that nothing is clogging the outlets on the spray arm. They do need cleaning every now and then.
Aug 11, 2014 | Dishwashers
I have a Kenmore model 1374 (ultrawash quiet guard). Recently I've noticed a lot of dirty residue left on the top rack dishes. I looked in the back of the dishwasher and noticed something with the little...
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
Dishwasher Residue and Film on Dishes
heatman101
Dec 26, 2010 | Kenmore 13742 / 13744 / 13749 Built-in...
Not cleaning properly
take a good look at the two spinning washers they are easy to remove i would suspect they are clogged clean and replace.adrian,,,,
Jul 14, 2010 | Kenmore Dishwashers
DISHES ON TOP RACK ARE NOT GETTING CLEAN TOP SPINNER NOT SPINNING POSSIBLY NOT ENOUGH WATER PRESSURE?
It would help if you provided the make and model of the dishwasher.
Most likely cause of not getting enough water pressure to top rack is the water diverter may be faulty.
Depending on the model - it is a small ball floating in a vertical channel which alternately opens and closes the bottom and top water inlets to the spray arms. Check part at Repair Clinic after selecting make & model of your dishwasher.
Jun 17, 2010 | Kenmore Dishwashers
Dishes not clean?
Check all the water jet orfices in the moving arm. Try cleaning without loading the top rack.
If cleans well, mostly the upper rack dishes not arranged properly.
I hope you are using the main wash detergents. Rinse aid is just to remove the stains after the main wash rinse.
Apr 01, 2010 | Dishwashers
My kenmore dishwasher model66516034401 does not
do you have a sprayer on top portion of dishwasher? if you do make sure it turns when dishwasher is running. check to see if holes in sprayer are open and not colgged up. you can clen it by pacing it in vinegar.
Aug 20, 2009 | Kenmore Dishwashers
Dishes on top rack don't get clean
The following suggestions will greatly enhance the ability of your dishwasher to clean all of the dishes thoroughly:
1. Rinse all of the food off of the dishes before you put them in the dishwasher.
2. Run the hot water into the sink until it is as hot as it gets before you start the dishwasher.
3. Do not pack the dishes into the dishwasher, just put in a reasonable number without crowding or stacking them on either shelf.
4. Pull the top shelf all the way out to be sure that the water connection at the rear of the top shelf is connected. Sometimes, this connector comes disconnected preventing the water from entering the top spray assembly.
THese things should make a huge difference.
Good luck with this and please rate my answer. Thanks. Joe
Feb 03, 2009 | Kenmore 24 in. 15079 Built-in Dishwasher
The top rack on my kenmore dishwasher is not cleaning the dishes!
check the inlet strainer at the bottom of the unit - and also the nozzles on the top are for clogs/sediment.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 16, 2009 | Kenmore Elite 45986 Front Load Washer
DISHES ON TOP RACK NOT GETTING CLEAN.
MAYTAG MODEL MDB7160AWB DISHWASHER
fills,starts wash cycle and shuts down about 2 min. into cycle
Nov 12, 2008 | Maytag 24 in. MDB5600A Jetclean II...
Dishes not getting clean
brittgee, there has been a number of service flashes on this model. One that has to do with the upper spray arm assy. Complaint is poor washability; gritty glasses, food redeposited on glasses, especially in the corners. They redesigned the upper spray arm to improve water spray to all corners of the upper rack. The new part number is 8269022. They also redesigned the third level spinner for more consistant rotation and better washability. This was also under a service flash. Part number.8193768. Other reasons for poor wash would be; low water temperature, rinse aid disp. not working, loading etc. Catriver...post back.
Nov 25, 2006 | Kenmore 24 in. 15933 Built-in Dishwasher
Kenmore 24 in. 17033 Built-in Dishwasher Logo
432 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
