Question about Keurig B60 Coffee Maker
I am looking for the funnel.
I am looking for the k cup funnel.
  • 3 Answers
Check Ebay for this part. I have seen them come up several times.
Posted on Jul 11, 2010
The coffee stream is weak and does not make as much ciffee as it should. I have descaled the coffee maker and it does not seem to have made a difference.
Clean the Kcup holder.
Cleaning the K-Cup Holder
  1. Remove the K-Cup assembly
    To remove the assembly from the brewer, open the cover by lifting the handle. Grasp the top of the K-Cup Holder with one hand while pushing up on the bottom of the assembly from underneath with the other until it releases. The K-Cup Holder is dishwasher safe.
  2. Clean the Funnel
    The Funnel can be removed from the K-Cup Holder by pulling on it until it snaps off. The Funnel is dishwasher safe. To replace it just snap it back onto the K-Cup Holder.
  3. Clean the exit needle
    The exit needle is located on the inside bottom of the K-Cup Holder. If coffee grounds or cocoa mix gets clogged in the exit needle, it can be cleaned using a paper clip or similar tool. Remove the Funnel from the K-Cup Holder, insert the paper clip into the tube and move it around to loosen the clog and remove any debris. Please note, you cannot poke all the way through the needle as the opening of the needle is located on the side and not the top.
  4. Install the K-Cup assembly into the brewer
    After cleaning, align the K-Cup Holder tabs with the opening placing the two front tabs on the bottom and the single tab on top and snap it into place by pushing down on the top rim.
May 31, 2011 | Keurig B50 Coffee Maker
I was cleaning the grinder and brew cup. When i went to put the brew cup back in place i accidently pushed the PUSH button. Now i cant get it back in the machine. The gears to the brew cup seam to be off...
Hi
To return the brew group to the centered position, you first need to drop the funnel. To do this, look on the opposite side of the brew group from the handle. At the top you will see an object that looks like a sharks fin. If you follow this piece down you will see 2 horizontal bars on the brew group body. Push your finger between these 2 bars and the funnel will drop. Now you can push the puck slide on the left side down and to the center. (You can insert your key into the hole in the front and twist the key to return the brew unit to the center. Line up the 2 diamonds and it centered) If you look down through the funnel you should see a piston. This should be centered in the funnel. If not, locate the slide on the left side of the brew unit,(it should be hanging down, a flat rectangular piece attached to the cylinder) and push the slide to the right until it does. Push the press button and you are now ready to reinsert the brew group in to the machine. First you must insert the drip tray and dredge drawer, close the door and turn on the machine without having the brew group in. Turn the machine on. You will hear the motor turn on and when it stops completely, open the door and remove the tray, now insert the brew group and replace the tray, and test.
Apr 05, 2011 | Saeco Incanto Classic Espresso Machine
When I put a k-cup in and it brews the coffee, it leaves coffe grounds all over the top of the k-cup and in the holder area and I get some in my coffee, it looks like the top needle is making too big of...
Sorry to read about your problem, I hope this helps you out.
I would follow the cleaning list below, I an addition you may have a bad batch of k-cups
plus just run some hot water, with out a kcup in the holder.
  2. Clean the Funnel
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
2 Thumbs - Somewhat Helpful
Dec 29, 2010 | Vacuums
I need a replacement K cup holder system for the Special Edition Brewing System
i think you are talking about the black funnel part, the replacement k cup holder, i know of this great site that sells all kinds of replacement keurig parts i hope this helps http://stores.ilikenew.com/-strse-14/coffecoffee,-tea,-shakes,-diet,/Detail.bok
Jul 31, 2010 | Keurig B60 Coffee Maker
Espresso irregularly spurts out the center post
It IS the gasket!!!!! Store the pot with the two parts screwed TIGHTLY together for about a week. Tighten it up as the new gasket compresses. Problem solved in two weeks or less. Funnel had NOTHING to do with my problem. Also cook on medium to low heat. High flame seems to make the problem worse.
Feb 09, 2009 | Bialetti Moka Express 6-Cup Coffee Maker
Parts on the Pink car Nebulizer
The funnel is called a "diffuser". It just sets inside the measuring cup and will gently vibrate during a treatment to ensure all the medication runs off the sides the cup to be atomized. You can also ask your family Dr. to review the set up with you if you are concerned that you are not using it right.
Dec 31, 2008 | Drive Medical Checker Nebulizer Yellow - 1...
I need a new funnel for my vev vigano kontessa 6 cup stove top espresso
Usually most stove top espresso makers manufacture these parts to the same standard. Take your old funnel, go to a kitchen store where they sell Bialetti, and compare their funnel size to your funnel size (for the same size put). I noticed that usually, it's the rubber gaskets that may differ slightly. Or you could email customer service of www.vev-vigano.com.
Jun 15, 2008 | Vev Vigano Kontessa Oro 12-Cup Espresso...
Directions on how to use my Black and Decker Espresso Mio coffee maker
Be sure the red rubber gasket is in place and clean (ridge side in) and bottom water cup is screwed firmly on to avoid leaking.
HOW TO USE:
1) Fill the bottom water cup with cold water up to the inside lip.
2) Set funnel into bottom water cup
3) Fill coffee basket with expresso grind coffee and level off. (Do not tamp or pack). Make sure it's filled to the top.
4) Place filter onto coffee basket and set coffee basket into funnel
5) Place brewer over bottom water cup and screw firmly into place.
6) Place unit with lid in the center of a microwave oven set on high for 1-1/2 minutes. If boil over occurs, reduce the brew time in 10-second increments until no boil over occurs.
7) Grasp handle to remove unit from microwave when finished brewing.
8) Remove lid and check the level of espresso in the brewer cup. Standard brew is at least 2 oz. If you don't have this level brew, replace lid and microwave on high another 10 seconds. Wait 20-30 seconds for bubbling to stop.
CLEANING/ADDITIONAL BREWING:
1. Under cold running water, unscrew the bottom water cup. CAUTION: It is normal for some water to be left in the bottom water cup. Both the coffee basket and any water in the bottom water cup will be extremely hot! If you prefer, allow the unit to cool for at least 3 minutes before unscrewing it.
2) To brew additional espresso, rinse Funnel, coffee basket and filter, then repeat brewing steps 1-8 above.
3) Parts are top rack dishwasher-safe -- hand washing filter is recommended.
Mar 10, 2008 | Coffee Makers & Espresso Machines
Keurig B60 Coffee Maker Logo
93 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
