Question about Acer 22" X223w LCD Monitor
No colour on my monitor
My acer 22 inch monitor has no colour just blue and green it was fine this morning i put it in sleep mode for a few hours while out of town , have tried turning it off for a few minutes and turning it back on with no luck can you help me
  • Acer Master
  • 5,568 Answers
One missing color could just as well be caused by the graphics card (or chip) or, if using a multi-pin interface connector, it could simply be a pin that isn't contacting anymore. The problem is, that red drive is missing.
Remove the end(s) of the video connection cable and reinsert several times to 'wipe' the contacts.
If the problem is constant and you have the opportunity, swap your Acer with another monitor or try yours with a different computer. You need to roughly locate which electronics is at fault and that is the easiest way.
Posted on Jul 08, 2010
My screen is saying burn in and keep switching colours all the time.(white,red,green,blue.
You may need to send in unit for service because your unit is unable to go to sleep mode when the signal cable is disconnected or the PC is turned off. Please call ViewSonic Customer Care for support.
Although this will not hurt the monitor, you just need to apply an active video signal to get a display correctly. However, it will not work as expected to go into sleep mode. You'll need to call ViewSonic Customer Care to get this taken care of.
May 09, 2014 | ViewSonic VA721 17" LCD Monitor
Acer p223w monitor does not turn on
Try a different monitor, check the connections to the pc. When the monitor light changes to orange, press the spacebar to see if the light changes back to blue. Your pc power settings might need to be re-adjusted, is the pc going to sleep or hibernating too soon?
Jan 02, 2014 | Acer Computers & Internet
Monitor will not power on
The monitor has entered permanent sleep mode. After four years of service, it probably is not worth repairing
Oct 21, 2012 | HP W2408H 24-inch Widescreen LCD Monitor
My Acer AL2216W monitor this morning went blank. I woke up, turned on pc and went to sleep like an hour more, when I woke up, the screen was black and light orange, as usual, when pc is not used for a...
Go to Control Panel, (top right View Small Icons). Then look for Power Options. On this page, you'll have the option to leave the monitor on. You should also check "Advanced Power Options". Don't be afraid of the word, "Advanced." It only means "customizeable"
If your mouse isn't waking your monitor, try the keyboard's space bar. I found it works better than the mouse at waking a sleeping computer
Apr 04, 2017 | Acer AL2216W LCD Monitor
I have my acer p205h 20 inch monitor hooked up to my tobshiba laptop and it works great except it will not go into sleep mode when laptop goes into sleep mode the monitor goes to there is not signal check...
Unfortunately, this is a standard problem, as when your laptop goes into sleep mode, it shuts off power to the secondary monitor, without giving it the signal to go into sleep mode. You could try digging around your settings, but most likely you'll just need to turn off the monitor when you're not using it.
Mar 01, 2011 | Acer P205H Widescreen LCD Monitor
LCD is on...seems like backlight is not functional; when external monitor connected, boot-up and bios screen visible. After boot-up, screen goes to "power save" mode and will not return
Use the 'FN' key (blue coloured?) and one of the other blue-coloured keys to "toggle" the video:
1. LCD only
2. external monitor only
3. both LCD & external
After boot-up, Windows defaults to "LCD only", and so the external monitor goes to "sleep".
Dec 11, 2009 | Acer TravelMate 4010 Notebook
Acer monitor will not come on after going to sleep
Well there is 2 straight things to check, first make sure all the connections are solid and connected properly, secondly make sure to test the system that is connected with the same connections on another monitor. Now that you have tested the hardware test the software, most monitors especially lcd's will have a menu where you can change the time set for sleep mode, I suggest checking this and changing it see if it has any effect. If still you have the problem, then we are probably looking more at an internal problem on the monitor directly to do with the video connection going out, the reason I say that, is because the monitor goes to sleep mode is not the real problem, the problem is that the video connection is set to make it do that. If the video connection is bad, you pretty much have to find replacment part and someone to solder it, or replace the whole board.
Oct 31, 2009 | Acer AL2216WD 22 inch LCD Monitor
Monitor has a hard time starting up
replace the "keyboard board" and the "power inverter board" (both boards)....
Oct 09, 2008 | ViewSonic Optiquest Q9b 19" Flat Panel LCD...
Acer 22" X223w LCD Monitor Logo
203 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
