Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
What is an F1 error message?
El codigo F1 para las Whirlpool Cabrio lo define la se?al de presion fuera de rango, para esto, primero hay que verificar el estado del tubing plastico ? manguerita que va de la tina hasta el sensor que esta en la tarjeta principal, que no este rota y/o doblada, luego realizar el test # 6, nivel de agua y calibraci?n del sensor de presion. Para esto hay que estar seguro de que la tina este sin agua, al igual que el tubing, luego entrar en test modo 2 y seguir los pasos.
Posted on Jul 09, 2010
El cod.f1 signica q tienes un problema con la computadora principal es necesari conbiarla.
Posted on May 07, 2013
Call whirlpool, let them know that you are getting the F1 code and they will have a tech come out, at no charge to you.. It is a recall that they are not letting anyone know about.. I found out online, by looking up the problem
Posted on Jul 14, 2010
Laptop not used for some years. could enter bios OK to reset Replaced U/S CMOS battery with no problem. Restarted............ Message press F1 ibm bios setup press F11 to invoke IBM product recovery...
I received an IBM laptop with same issue a few months back. The error message due to the drained out CMOS RTC (coin-cell battery), which retains and other BIOS settings.
The system is OK and all you have to do is to get the CMOS/RTC battery replaced by the a professional.
Good Luck!
CreativeTECH
Dec 31, 2010 | IBM ThinkPad R30 2656 Notebook
Can you tell me what an F1 error Message means - 30 minutes into baking, I got beeping and an F1 error message. Canceling did not turn the oven off and the only thing I could do is turn it off at the...
"F1" code clearly indicates that main control board has failed. The possible fix for this kind of problem is you have to replace the faulty circuit board. This is the only solution and you cant repair anything else in this unit when F1 flashes.
Thank you !!
May 30, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
The F1 error message keeps coming up. what do i
Indicates a fatal error on computer board, WHIRLPOOL has had numerous problems with this issue.I would call Whirlpool to see if they will help
Nov 15, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
F1 error message on the clock. Oven will not work. I purchased a new clock and recieved the same error. What could be the problem? Could it be the heating element?
The meaning of the various error codes varies by manufacturer and model. If you replaced the clock/control board you may have found a tech sheet taped to the panel that you removed to get at it. Usually the tech sheet will explain the error messages. If not, email me at bruce@fixyourboard.com and I will attempt to find the info for you.
Oct 14, 2009 | Kitchen Ranges
F1 error message Kenmore Electric range model 790.95680301
Hi
F1 error means that you have either a bad ERC (clock) or a bad touch pad. To check these please follow these simple instructions:
  1. Disconnect power to stove
  2. Gain access to the back of the clock (electronic range control or ERC).
  3. Unplug the touch pad ribbon connector from the ERC. This will be a flat wire approx. 1 1/2" to 2" wide.
  4. Make sure everything is clear and will not short out when power is turned back on.
  5. Turn power back on to stove.
  6. Watch for the F1 and listen for the beep.
  7. If you get the F1 and beep, replace the ERC.
  8. If after approx. 30 minutes you do NOT get the F1 and hear the beep, replace the touch pad.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Aug 10, 2009 | Kenmore Kitchen Ranges
Whirlpool Cabrio Washer Error message code F1
HELLO, Error code F1 indicates a control failure and most likely the machine control board will have to be replaced. Depending on when you purchased the machine, the board may be covered under extended component warranty.
I had the same F1 problem and they had to replace the control board and something relating to the balance. The tech told me this is a common problem.
Apr 06, 2009 | Whirlpool Duet 3.8 cu. ft. Front Load...
Whirlpool did a recall on this problem here is there number try this first. Whirlpool 1-800-253-1301
On a number of ranges this can mean a number of things, the most common being a failed ERC(EOC, Clock assembly)or a faulty touchpad. Firstly if you are using a recent Maytag range it may pay to test the oven sensor as described above as this may cause an F1 error if faulty (may apply to some other ranges as well) this is not a common cause but is worth discounting. To check the ERC and touchpad
  1. Disconnect the power
  2. Gain access to the back of the ERC
  3. Disconnect the ribbon cable that connects the ERC to the touchpad
  4. Check nothing will short when power is reconnected
  5. reconnect the power and switch on
  6. Watch for F1 and listen for the beep
  7. If you get the F1 and the beep this means the fault is with the ERC and it will need replacing
  8. If after 30 mins you do not see the F1 error and hear the beep, replace the touchpad
Feb 13, 2009 | Whirlpool Washing Machines
f1 code means the main control needs to be replaced. pretty common repair
Dec 12, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
F1 error message on kenmore gas range
The F1 usually means a problem with the touchpanel. It is also related to the F7 problem. I have developed a fix which may solve you problem. Please go to the following link for my fix.
http://www.fixya.com/howto/h155060-dreaded_f7_error
I have shared my fix with over two thousand unhappy GE customers. Most report success. Please let me know if this works for you too. I am making a statistical study of this problem.
Regards,
Powerman
hutchipop@yahoo.com
Dec 05, 2008 | Kenmore Ovens
Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
552 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
