Question about Car Audio & Video
2003 Chevy Trailblazer: CD player error
I have 3 CDs currently in the player. I cannot play or eject the CDs. States there is a ''player error.'' Everything worked fine with player when I left for vacation last week. When I came back and went to use my car, CDs no longer working. Anyone have any ideas how I can fix this issue?
  • 108 Answers
SOURCE: My cds are stuck in the player. They won't play or
Hi Texasgirl826,
There is nothing I can tell you to do that won`t damage the player.
I have one sugestion, go to a shop that installs car stereo, don`t go into the store, go to the bay where the workshop is and ask one of the installers real nice like if he could take it out for you, I`m sure he would.
It is a bit tricky to do it, but it can be done, without having to remove the deck and taking it apart.
Good luck.
Posted on Dec 20, 2009
  • 14 Answers
SOURCE: CD player won't play CDs
Try getting a cd cleaning tool come with a disk with tiny brushes on it and cleaning solution to clean the eye or if you are using burned cds try and see what format you are buring such as mp3s mp4s some cd player only will play a certain formats such as mp3s.
Posted on May 07, 2009
localwonder
  • 6784 Answers
SOURCE: my cd player is not loading, neither is it ejecting cds
Hi, this is a common problem with in car cd players. the shock absorber can only protect the internals from a minimal amount of shock that will be distributed from the road and normal driving situations. there is a mechanism inside the CD player(changer) that will become unstable over time. this will allow for many mechanisms that make up the unit to loosen and separate from the original structure design, in return, allowing the lens assembly to become jammed or misaligned.
When this happens, the only option is to take to a local audio electronics store like best buy. they will have audio tech in store that can disassemble the entire device to retrieve the Cd's inside. the actual cd changer itself will have to be rebuilt or replaced.
You can also take your car to the dealership for this extraction as well.
Please rate and have a great day:)
Posted on May 14, 2009
SOURCE: ford 6006e cd changer with e 3 error keeps happening
The only way to do it is to remove the radio using DIN radio removal tool - then you will have easy acces to remove cd's if you do not have this tools try to use coat hanger (do small catss on the ends)
(you can try to hold eject button and swich off - swich on button - probably it will not work but try few times
Good luck,
Kamil
Posted on Jun 24, 2009
Molson02536
  • 3854 Answers
SOURCE: CD player not working correctly
Try turning off the radio and disconnecting the battery for 1 min and then reconnecting the battery. Turn on the radio and see if that reset the radio so you can get your CD out and try cleaning the CD player with a cd player cleaner. Note you have to make sure the radio is off before you disconnect the battery. Good luck and hope this helps
Posted on Jul 29, 2009
Cd player is not reading cds what can i do to repair it.
Subject: Radio With Six Disc CD Changer Does Not Recognize Loaded CD And Displays An "INITIALIZING" Message, CD Will Not Play, CD Cannot Be Ejected, Or Disc Icon Does Not Illuminate (Reprogram Radio)
Models:
2005-2006 Chevrolet Avalanche, Suburban, Tahoe
2005-2007 Chevrolet Colorado, Express, Silverado Classic, TrailBlazer
2005-2006 GMC Yukon, Yukon XL
2005-2007 GMC Canyon, Envoy, Savana, Sierra Classic
2005-2006 HUMMER H2 with Six Disc CD Changer Equipped Audio System (RPO UC6)
Condition
Some customers may comment on any of the following conditions:
• The CD loaded in the radio will not play.
• The CD loaded in the radio will not eject.
• The disc icon on the radio will not illuminate.
• The radio displays an "INITIALIZING" message for approximately 30 seconds after vehicle start up.
Important: Do not attempt to play CDs with paper labels on them in this CD player. The labels may warp or wrinkle and jam the CD player mechanism. Refer to the Compact Disc Care and Cleaning procedure (Document ID# 1656123) in SI for more information.
Technicians are to reprogram the radio with new operating software using the following procedure:
1. If the radio has a CD(s)2008 General will be necessary to reset the radio and remove them
before the radio is reprogrammed. Remove and reinstall the radio fuse to reset the radio and then eject the CD(s). If cycling the power to the radio does not allow the CD(s) to be removed, the radio may have another failure that will not be corrected by the reprogramming procedure that follows. Refer to the Diagnostic Starting Point - Entertainment procedure in SI to begin your diagnosis of this failure to eject CDs concern before reprogramming the radio.
2. Reprogram the radio using the Service Programming System (SPS) with the latest software available on TIS2WEB. Refer to the SPS procedures and the Radio Programming and Set procedure in SI for more information. As always make sure your Tech 2® is updated with the latest software version.
3. Verify proper operation of the radio and make sure that all CDs can be ejected.
Hope helps (remember to rate this).
Oct 03, 2010 | 2005 Chevrolet Trailblazer Ext
Cd player keeps going out when i try to play/load/reject get 'error' message
Take out #7 and #31 fuses. Start the vehicle, the radio/cd will not come on. Shut the vehicle off and replace the fuses. Start the vehicle again and you shoud hear the cd player cycling through the cds. Be patient and let it go through the process. Then play/eject/load cds. It worked for me.
Mar 03, 2010 | 2003 Ford Expedition
My CD player on my 03 Chevy Trailblazer has had a check CD on it and will not play any CDs even if there not a burned CD i heard it might be something internally where could i bring this to try and fix the...
chances are you cd player is done you might want to put in an aftermarket radio in this because the factory radios are stupidly expensive. But you can try finding the radio fuse and unplug it wait about 30 seconds and plug it back in. It may reset itself.
Feb 10, 2010 | 2003 Chevrolet TrailBlazer
2003 Ford Expositi CD Player will not play or eject
Does the CD door open or is it stuck open? If it is open look to see if you have a jammed CD. This happened to me and this is what I did. A CD had gotten off track and jammed the CD changer turn table. I stuck a little key in the slot and was able to pull the CD out. This fixed my problem. Hope it helps.
Dec 21, 2009 | 2003 Ford Expedition
Jul 29, 2009 | 2003 Ford Escape
Alpine CDE0-7826P Cd Player doesn't always work
If It dosent play burned cds its not an mp3 compatiable cd player as far as the other problem kinda seems like its time for a new cd player
Jun 14, 2009 | Alpine CDE-7826P
2003 infiniti g35 cd player
its a very common problem with g35 in dash clarion cd changer head units. a small plastic gear gets worn or brakes and wont eject or change cds. you need a new one, should be covered under your warranty.
and to get your cds out try this.
Feb 03, 2009 | 2004 Infiniti G35 Sport Coupe
Jammed cd player
it started and stopped the cd player in the middle of all that kyoss now it doesn't know that disc are in there.. in plug the power source and plug it back in that should kick them out..
good luck ray
Jan 19, 2009 | 2003 Dodge Neon
Car Audio & Video Logo
515 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
