If the computer is restarted it is slow to respond. When does respond it very slow. It seems to hang up before it display the hp logo. the same occassionally happens coming out of sleep or hiberation mode. only solution I have found is to terminate the rebooting by holding down the power key then start the computer through the power button. i often have terminate the rebooting two or three times before the computer reacts normally.
  • 1,606 Answers
Slow booting can be caused by several things. Usually when it hangs it is a driver or update program that is having problems. For example when adobe reader updates it can take a few minutes to check to see if there is a update and so on. These are annoying as the intent is they pop up first thing to say they have an update instead of doing in the background and showing a message a few minutes after booting.
What can also happen is having to reboot it or force it to reboot it can corupt a setup and the program stalls or won't run the next time.
What you need to do is remove any programs you can out of the startup menu to start with. There are a couple of speed loaders that may be in here. Office and adobe as examples. Just move them out of the startup or delete them. They don't need to run and I've never seen them actually save any time in how fast the programs start.
There are other programs such as MSN or other programs that are set by default to run at startup. Those you can change to start when you start them not when windows does. These also can slow things down bu usually when you see the desktop.
The next place to look is add remove programs. Look for any programs that you have recently installed or do not use anymore. If you can remeber you may be able to spot which one was the one that was installed just before everything slowed down. Again this could be updates or corrupt parts of the program.
At this point if you haven't found te problem then it will be either a virus or corrupt driver. Depending on what version of windows you have you can run regedit or msconfig from the start/run window and then look at what starts up.
You should also try running antivirus or antispyware programs. Spyware tend to be dumber versions of viruses. Those will keep downloading more and more until the computer is running so slow it may take an hour or so just to put. There are several online sites that will run searches and let you fix them. there are a lot more that do the search and say spend money. A good one is www.microtrend.com called housecall. It is good at find viruses and spyware and gets rid of them.
Thats covers quite a bit but you should be able to narrow it down and then if it still is slow get specific help to finish it up if it is still slow.
Posted on Jul 08, 2010
On startup os logo hangs up
Is not compatible with your device
Mar 20, 2013 | HP Compaq 6730b Notebook
Hp pavillion dv5 not booting,turns on and hangs on the hp logo. not responding to any key commands.
Mine did that but its power dvd9..something like that... but it wouldnt work... so i kept logging off then turning it off..i did that twice and it finally worked.. i wanted to watch a movie **** it!! <----yes, i know...simple but who knows... maybe it will work for you too??... i hope you get your dvd working.. :)
Dec 17, 2011 | Computers & Internet
My HP compaq nx6110 windows xp sp3 hangs at boot
Take a look at this post that deals with a HP nx6110 laptop with random freeze ups. If the described symptoms also happen on your laptop. If you do experience random freezeups or slow DVD you're facing the same FSB chip problem. All peripherals, USB ports included, are connected on the Front Side Bus. Poor soldering causes intermittent contact which in turn results in hanging, slow, or totally non bootable (stuck at HP logo) laptop. Hope this helps.
Nov 14, 2010 | HP Compaq nx6110 Notebook
Have presario 6000. Would not boot but received message that new keyboard needed. Purchased "universal" aftermarket keyboard. New message "Hard drive failure imminent" and still would not boot to allow...
Prepare to Diagnose the Computer
Perform the following actions to prepare the computer for troubleshooting a startup problem.
1. Remove the battery and AC adapter from the notebook.
2.Remove any optical disks (CD or DVD), and disconnect any external devices or peripherals such as USB devices, printers, docking stations etc.
3.Plug the AC adapter directly into a functioning wall socket.
4.Press the Power button to turn on the computer.
NOTE:After the battery, optical media and peripherals are removed, the Notebook PC may startup normally. If this occurs see Windows starts after the battery, optical media and peripherals are removed .
Symptoms and Resolutions
When the notebook stops responding or displays an error message, let me know what symptom that most closely resembles what is seen on the Notebook PC screen.
* Screen is blank with no cursor or text
*An error message is displayed on a black background
*An error message is displayed on a blue background
*PC stops responding on a red Compaq or blue HP logo screen
*PC Stops responding on the Windows logo screen
* The Microsoft Windows 'Advanced Options Menu' is displayed
* PC stops responding with a blinking cursor is displayed in the upper left corner of a black screen.
*Password is requested but password is forgotten or lost.
*Microsoft Windows starts, but a 'serious error' message is displayed that prompts you to send an error report to Microsoft for evaluation.
* Microsoft Windows starts , but the PC stops responding or restarts automatically
*Display is very dim during and after startup
*Microsoft Windows starts, but runs abnormally slow
Jan 28, 2010 | HP Pavilion dv9000z Notebook
Will not boot up. Screen displays Window XP
Use your original Windows XP CD and run the recovery console when starting up the pc. Thats should repair any files which are hanging the pc at the XP logo
Oct 13, 2009 | HP vs17
HP Pavilion Notebook Monitor display is green and have not been able to get back to blue . The computer is working but you can not see the icons, text, etc very well.
Try uninstalling the display driver from the Device Manager then restart the Computer. After restarting the Computer, reinstall the display driver.
Perform the steps given below to access the Device Manager:
(i) Please press the Windows logo on the Keyboard and then press the "R" key while holding down the Windows logo key to open the Run dialog box.
(ii) Then, please type "devmgmt.msc" in the Run dialog box and click OK to open the Device Manager window.
(iii) Click on the plus sign next to the "Display Adaptor" category to locate the display adaptor.
(iv) Right click on the display driver then click Uninstall.
You can download the display driver from the support site of the Computer manufacturer.
Sep 04, 2009 | HP Pavilion dv9000z Notebook
Hang up
Try to restore using itunes, and make sure you are updated to the newest firmware.
Jul 05, 2009 | Apple iPhone Smartphone
Problem with booting-up on HP Pavilion dv9334us laptop
1.there is problem in screen fl inverter replace it screen will on
2.format and reload the windows
Mar 26, 2009 | Computers & Internet
My hp tx2000 webcam never responds the cyberlink you cam with some up but become un responsive and hangs there and vista will not let me force quit it... it just hangs there forcing me to restart the...
Try installing the Acer Chicony webcam driver, instead of the HP one.
Alternatively ensure the software is explicitly looking at the HP camera, not just 'default'
Sep 12, 2008 | HP Pavilion TX2000Z Notebook
Computers & Internet Logo
88 people viewed this question
David Payne
David Payne
