Question about Maytag Bravos MTW6600T Top Load Washer
I hate my Maytag Bravos Top Load Washing Machine! I've had it ALMOST 2 years AND in the past 4 monts have replace the water pump 3 (yes three) times!! I am totally disgusted with Maytag AND I will purchase a new machine this evening instead of replacing the pump for the 4th time - my new machine will NOT be a Maytag!! You lost my business as I have ALWAYS owend a Maytag...NOT anymore!! Piece of ****!!
SOURCE: Maytag Neptune stops during rinse cycles
I think the cold side of your water valve is stopped up at the screen. Just take your hose off at the machine and get the crud off the screen in the valve. It only does it in rinse because you have cold rinses. When warm water comes in, it will fill just fine because the hot water is not blocked
Posted on Sep 07, 2007
Jimster
  • 240 Answers
SOURCE: Leak from maytag top load coin machine during spin drain cycle only
Possible that you would have a tub seal leak if it is only noticable during spin cycle. Possible that it "drips" slightly while in agitation, but not enough to notice it. While in spin mode you have a lot more parts moving as well as a lot more water pressure on the seal itself. Pump could also be leaking, but highly doubtful since it would leak a constant amount at all times. Good Luck!!! Jim
Posted on Sep 09, 2007
  • 1216 Answers
SOURCE: maytag washing machine #mav6260aw
If you are a good DYI'er you can find the parts here http://www.repairclinic.com/0003.asp you'll need a couple of hours set aside and maybe a few beers for after. If you are not going to fix it yourself the labor costs and parts would come
to just about the price of a new one. Hope this helps.
Posted on Nov 11, 2007
Washer_tech
  • 164 Answers
SOURCE: fuse keeps blowing out in my maytag washing machine
the power surge probably shorted out something in the main wire harness or fried your motor. remove the screws from the control panel and look for any wires that are discolored, charred or disconnected. in the event you do't find it there trace the wiring thru the cabinet looking for the same thing. if you don't find that, replace the motor
Posted on Nov 17, 2007
  • 183 Answers
SOURCE: Maytag front load washing machine Model MAH5500B misses spin cycle
either balance load sensor or machine failing to drain in the allocated time, check pump/filter for blockage
Posted on Dec 27, 2007
Washer drain pump continually runs even with power off.
have a technician check the power board as the pump power is not terminating when the machine switches off.
Jun 27, 2015 | Maytag Bravos XL 4.6 cu. ft....
My Maytag bravo is leaking out of the rear left side, any ideas?
I think I'd be checking the dispenser in the left rear for a crack or rub mark. Also the hoses going to and from the dispenser. They are plastic and fragile.if the top has been lifted or an extremely
off balance load ,one may be damaged.
Jan 18, 2015 | Maytag Bravos MTW6600T Top Load Washer
I have a maytag bravo and it making a humming sound and wont drain water
There isn't much I can add to Gordon's Appliance solution.
thats exactly where I'd go for the solution .
Dec 11, 2014 | Maytag Bravos MTW6600T Top Load Washer
Why is my maytag bravos mvwb750wq washer so loud on spin cycle?
Is it moving around? I am guessing not so guess would be the drum is out of balance.
Jul 21, 2014 | Maytag Bravos Top Load Washer
My Maytag bravos wont spin out
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Aug 23, 2010 | Maytag Bravos MTW6600T Top Load Washer
How do you select the load size on the Maytag Bravos Top load washer?
This machine is equipped with technology that allows it to sense the load size and will use the appropriate amount of water for that load. Takes the guesswork out!
Apr 21, 2010 | Maytag Bravos MTW6600T Top Load Washer
We have well water w/sediment filter. soap in dishwasher and washing machine does not dissolve. washing machine has heavy build-up around rim after only a few wahings.
get water tested,sounds hard,filter doesn't solve,test before invest, get 2-3 reputable solutions,they will be salesmen,u may simply need softner or could be more difficulty such as iron,etc
Aug 02, 2009 | Maytag Bravos MTW6600T Top Load Washer
Maytag Bravos MTW6600T Top Load Washer Logo
115 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
