Question about Pentax Optio W60 Digital Camera
My pentax optio w60 won't turn on. it appears
My pentax optio w60 won't turn on. it appears that the battery is fully charged
SOURCE: Camera turns on, beeps, turns off.
I've managed to fix my camera - but it took several hours and I needed someone to help. Not sure everyone will want to do this.
Here goes:
Need small Philips screw driver. Pair of tweezers for the small screws. A small flat screw driver for leveraging
1. Remove the battery and memory card.
2. Remove wrist strap
3. Take off the battery cover by gently lifting the retaining metal strap (with small flat screwdriver).
4. Remove all screws of the front cover of the camera housing. (one of the screws is smaller than the others). There's a screw above wrist strap loop.
5. The top of the cover is clipped in under the shiny silver bit with the on/off switch and shutter button (I’ll call it the switch/speaker assembly). I find that inserting a finger nail and gently applying pressure works well.
6. The switch/speaker assembly is best kept secure by an elastic band.
7. Verify the problem is the same: looking into the lens, at bottom right corner of camera is a small motor (silver). Look carefully, you’ll see a white plastic gear which connects the motor with a (hidden) pink gear. This pink gear is attached to a worm gear (a pin with a fine screw thread) that is brass/golden. On this worm gear is a U-shaped blue piece of plastic, which in my case was no longer at right angles to the shaft/worm gear. That's the problem.
You should be able to see all of this under a strong light and peering into the little openings.
8. Resist the temptation to just fix this by leveraging the blue rider with a tiny screwdriver (or something) until it is back in its original position. You might strip the screw thread inside the blue rider and that would be the end of the camera.
9. Next take the LCD display off. Above the little motor is a metal clip attached with 2 screws hidden behind self-adhesive copper strips.
10. Fold the LCD panel away from the camera body. Then carefully and gently unplug the power plug (pink & white in my case). Careful, the green PCB (printed circuit board) to which the socket is attached is flimsy. I don’t think it can take much force. Rather try to pry the plug & socket apart by using a knife or tiny flat screwdriver?
11. With the power cable removed, you can turn the LCD panel over (anti-clockwise) to undo the fold that is in the flat cable. The flat cable is attached to a small white plug on the PC board that contains the rear panel buttons of the camera. There is a thin, orange plastic sheet stuck over this. Lift it away gently and store somewhere for later re-assembly.
12. The socket for the flat cable has a black flap that can be lifted to release the cable. Gently tug the flat cable out of its socket and you can put the LCD panel aside.
13. Remove the metal plate that covers the rear of the lens assembly. First remove the two small screws, then unclip it at the bottom and on the side.
14. CAREFUL: in the centre of the lens assembly is the CCD (charge coupled device). This is the “thing” that contains 7 Megapixels and takes the pictures. NEVER TOUCH THE FRONT OF IT (or so I have read – I think it prudent to observe this.
15. Remove the 3 screws that hold the CCD in place. It needs to be lifted vertically from the lens assembly, otherwise it gets stuck. NOTE that my camera had two small washers under the CCD assembly: top right screw = copper, bottom screw = silver washer. The CCD assembly, too, is attached with a flat cable. The socket works exactly the same as the LCD display. I put my CCD assembly into my glasses case to prevent it from getting dust or dirt on it.
16. Now remove the 4 screws that keep the rear cover of the lens assembly attached.
17. Before removing the cover, unhook the little metal spring that is attached to the mechanism next to the worm gear. Take it right out, feed a bit of thread through one end (for re-assembly) and put it aside. (If you attach the thread immediately, the risk of losing it is reduced.)
18. Then, using your finger nail gently unclip the plastic hook next to the worm gear and lift the lens assembly cover off. There is a long plastic pin so you need to lift it quite high. Observe how the pink gear is situated relative to the plastic mechanism crossing the lens assembly. Remove the pink gear/worm gear with the blue “rider”. Be careful not to lose the small white gear that makes the connection to the driving motor.
19. Unscrew the blue “rider” from the worm gear. Ensure you keep the same orientation and gently find the correct way of putting it back. That is at right angles to the worm. Leave it fairly close to the end of the worm gear away from the pink gear.
20. Now put it back carefully. Try not to lift the part that crosses the lens assembly (the one that was attached with the little spring) too much. Otherwise a little lens flips down and you’ll have extra work to put it all back correctly. There is also a pin on which the plastic piece rides which then needs guidance when re-assembling. (Happened to me, not the end of the world.) (BTW, I think this is the auto-focus mechanism, but I can’t be sure.)
21. Hook the spring over one of its attachment points. Feed the thread through to the other side and use it to hook up the other end of the spring. Cut and remove the thread.
22. Replace the rear lens assembly cover. The long plastic pin needs to find its corresponding hole near the middle of the lens assembly. Remember the hook at the worm-gear corner. Do that one last (after the screws), ensuring that all gears and shafts/pins are in their respective holes.
23. Put back the CCD. I attached the flat cable first (flip down the black locking lever on the socket), then put in the screws. (Remember the washers.)
24. Now put back the metal plate. Clip it in on the left side first, then at the bottom, then the screws.
25. Attach the LCD flat cable. (Remember to lock the socket.) Flip it over and attach the power cable to the LCD. Remember again to be careful with the plug & socket since the PCB is flimsy. Try to apply pressure only on the plug & socket.
26. Replace the orange plastic that covers the electronics.
27. If you like, try out the camera to see the effect of the repair. I used an elastic band to keep the LCD and switch/speaker assembly in place. The battery can be inserted as per normal. NOTE: Where you observe the little blue rider in its installed position, there is a plastic pin sticking up towards the front of the camera (just under the lens). You have to hold something over this hole to prevent the pin (which is being pulled up by the little spring we removed/replaced earlier) from coming up too far. I held my thumb over the hole. If you don’t do this, you camera won’t switch on properly or won’t focus correctly. (In normal operation the front cover stops the pin from advancing too far.) Now switch on and see that all is in order. Careful when operating the zoom and other switches, since you don’t want to break the plastic covering of the switches.
28. If all is OK, then finish the assembly. REMOVE the battery! Next is the little metal plate that keeps the LCD panel in place from the side of the camera. (Remember to flatten/re-attach the adhesive copper strips.)
29. Clean the LCD panel and inside of the rear cover very well. Then put on the back cover.
30. Attach the front cover, clipping in the top carefully. Be careful to position the speaker/switch assembly properly. There is a tiny locating pin (made of plastic) - don’t break this.
31. Put back the screws all around the camera housing. Remember there is one smaller screw that fits underneath the lens. Remember also the screw just above the wrist strap loop.
32. Slide back the battery compartment cover onto its metal strip. Insert battery & memory card. Attach wrist strap. Done!
Stephan
Posted on Jul 12, 2008
SOURCE: Pentax Optio M30 won't turn on!
MY CAMERA WONT TURN ON... I HAVE CHARGED THE BATTERY SO I KNOW IT IS CHARGED...ANYONE HAVE THIS PROBLEM.?
CHERI
Posted on Oct 30, 2008
SOURCE: Pentax Optio A30 - turns off when I zoom in
This might sound a bit silly, but as I have posted earlier I had a similar problem As soon as he lens came out ready to take pictures it retracted and turned off. Because i haave decided to buy another camera I held the Optio in my right hand and banged it into the palm of my left hand. No great shock to the camera, but hey presto it now works. Not sure if I can rely on it though......what does anyone else think about this?
Posted on Feb 13, 2009
wipdhuls
  • 133 Answers
SOURCE: camera wont turn on!! help!!
Dear Texaslilly,
Although there is nothing much to do but you can still try the following.
  1. Try with different set of batteries
  2. Remove the memory card from the camera
  3. Cameras generally do have an option to plug-in external power supply..Try with external power supply .. if there is any.
  4. Now this might sound little crazy but no harm in trying .... Remove batteries... Press and hold the power button for few seconds... release the power button ... reinsert the batteries and try to power on without memory card.
Try the above and let me know if it works.
Regards,
Srinivas.
Posted on Jun 19, 2009
BillB-SA
  • 2761 Answers
SOURCE: my camera pentax optio wp wont turn on. though is
If possible, check the charger output or the charge status of the batteries with a voltmeter. That will narrow the field for you. If the charger and batteries seem OK, your problem may be due to corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, your camera may have a problem that requires professional repair.
Posted on Oct 21, 2009
Driver optio w60
Do you really need a driver?
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo management program such as Picasa ( http://picasa.google.com ).
Jan 14, 2014 | Pentax Optio W60 Digital Camera
The camera is locked, But i still can use the play mode to watch old photes, buat cannot turn it on to make new ones
SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Aug 11, 2010 | Pentax Optio W60 Digital Camera
When I try to take a picture with my Pentax W60, it will focus but not take the picture no matter how long I hold the button
I have the same issue, no message appears - every now and again after I push & hold the shutter button (sometimes 4-5 times, 5-10 seonds) it will finally take the picture. But, again - once it focuses it doesn't take the picture when the shutter ****on is fully engaged.
Apr 10, 2010 | Pentax Optio W60 Digital Camera
Pentax Optio S10 cannot take photos in flash mode
HI there check the battery first. Red light blinking in working mode when the battery not having enough power for flashing. So i suggest you charged the battery fully or if its old then replaced it. Thnaks.
Apr 04, 2010 | Pentax Optio S10 Digital Camera
It won't turn on even with a fully charged battery. What do I do? I've owned it for at least 5 years and have three batteries and a pentax charger that turns green when a battery is charged. I put the...
yeah if you have had it for that long the batteries might be dead even if the appear to be charged i would get new batteries or get a new camera get one cheap on eBay ! have a good day :)
Apr 01, 2010 | Pentax Optio 430RS Digital Camera
Pentax Optio M20
Maybe.
But it does seem to be a lens problem. Possibly the lens is out of sync as mentioned in another post here.If there is a grinding, the lens is probably damaged by dirt or sand.
Make sure the batteries or battery is fully charged.
May 31, 2008 | Pentax Optio M20 Digital Camera
CHERI
Feb 25, 2008 | Pentax Optio M30 Digital Camera
Pentax Optio W60 Digital Camera Logo
279 people viewed this question
Top Pentax Cameras Experts
Greg Cann
Greg Cann
Jerry Greenberg
Jerry Greenberg
Are you a Pentax Camera Expert? Answer questions, earn points and help others
