Question about KitchenAid KSRB22FNSS Stainless Steel
Refrigerator temp not going below 50 degrees
The refrigerator temp will not go below 50 degrees. It is on the coolest setting and the freezer is working fine. I vaccummed out the back and underneath.
  • 1,344 Answers
You have one of two different problems. Either the fan in the freezer side is not running/working or you have a defrost problem. Check on the freezer side to see if you can hear the fan running, and if it is, look on the back freezer wall for a build up of ice. If you have that, one of the components of the defrost system (timer, defrost thermostat or defrost heater) is bad. List your brand so I can be more specific.
Posted on Oct 30, 2010
How do I get my maytag side by side refrigerator model# msd2756geq to cool down below 50
first turn your refrigerator temp setting to 1 then wait for the compressor to kick off, this will send the unit into defrost mode, and most units take between 1 to 2 hours to acclimate(get tempered) correctly. after a few hours gradually turn your unit towards 9 until the compressor kicks on, when it does , stop turning the knob, it will acclimate again, 1-2 hours (some units can acclimate in 15 minutes) check your unit temp and do not use the unit if it won't cool down to 43 or less degrees, you run the chance of food poisoning. hope this was helpful.
Aug 01, 2014 | Maytag Refrigerators
Why won't my refrigerator and freezer stay below 50 degrees?
Barbara, does it stay at 50 degrees even if you set it lower? I have a similar problem but temps. look ok.
Jul 30, 2014 | Maytag Refrigerators
Freezer works great, but fridg. will not get below 50
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
Sep 17, 2009 | Maytag MZD2766GES Side by Side...
Whirlpool 6 sense model WSC5513- A+ X side by side, without ice or water dispenser. Refrigerator part not cooling properly. Temperature setting is -18 degrees Celsius for the freezer and 2 degrees...
The temp for the fridge is about right and -18 for the freezer is ok so check to see if the water filter is plugged, at 8 degrees Celsius is about 18 degrees fht. Which is freezing so the numbers don't add up. 26 degrees below zero on the freezer side is what you want if it that cold it could have frozen the water line.
Aug 20, 2009 | Refrigerators
It doesn't cool properly
it the freezer froze up?if so its a defrost proublem
May 04, 2009 | Frigidaire PLRU1777DS Stainless Steel...
Top mounted freezer on refrigerator not working
Move the refrigerator to a room that is at least 50 degrees F.
Temps on most refrigerators are regulated by the fresh foods temp. If your garage is let's say 35 degrees, the fresh foods temp will most likely never raise enough to turn the refrigerator on. With the refrigerator never running, the freezer compartment will warm to 35 degrees, resulting in everything melting. Even if garage is a bit warmer, say 45, the refrig will not run long enough for the freezer to maintain a low enough temperture. If the garage temp falls to below freezing, say 20 degrees, the food in the fresh foods compartment will freeze. (outdoor beverage dispensers have internal heaters to prevent product from freezing !) Please don't rate this if not a Fix-Ya for you, as anything else lowers my score.
Jan 22, 2009 | Frigidaire 5 cu. ft. / 142 liter Chest...
Ge Side by Side not cooling
check the freezer panel in the back for frosty ice build-up. is the freezer evaporator fan running?
Aug 03, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
KitchenAid KSRB22FNSS Stainless Steel Logo
133 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
mike cooper
Todd Arndt
Todd Arndt
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
