Question about Poulan 42-Inch Steel Deck 17.5 HP Briggs & Stratton I/C Engine With 6 Speed
I have a poulan pxt 16542, replaced the drive belt and it will not stay in place
2 Suggested Answers
  • 376 Answers
SOURCE: Replacing the Drive Belt on a Poulan Riding Mower
Without an impact, it's will be more difficult. The only way to get back-up on the bolt is to remove the screen over the flywheel on top and put a socket on the flywheel nut
Posted on May 28, 2009
My poulan pxt 12530 starts fine but won't move changed put the drive belt on tranny and still nothing
be sure that the hydro-stat is locked in. if you pulled the pins to free wheel it and forgot to push them back seems to be a common problem. is the belt on correctly? is any pulley damaged or missing?
Sep 27, 2017 | Poulan Garden
Poulan continually throwing drive belt
adjust the belt tensioner properly
check that the pulleys are in alignment
Apr 16, 2017 | Poulan Garden
Drive belt pops off even after replacement for riding mower poulan pro
Either you replaced it with wrong belt or you need pully adjustment for new belt.
Can I have a diagram on hoe to replace the drive belt for a Poulan Pro 42inch 18hp?
Here is link to parts manual. Page 14 shows belt and shape to go around belts. I have found it easiest to remove deck and clean drive shafts for blades and idlers etc. that way new belt will last longer.
Feb 27, 2017 | Poulan Garden
Drive belt keeps slipping off when clutch is pushed in
when you replaced the belt did you put the tabs bad into place that keep it from coming off the pulleys?is there a bad pulley?
May 29, 2012 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
I have a Poulan pro, 42 in, 18hp, How do i adjust or replace the drive belt?
steps:
1. elevate tractor.
2. lower blades all the way down.
3. remove battery and battery slot
4. place belt through battery slot around first pulley and then feed it through the middle two.
finally loosen the front pulley and slide new belt over the front of the last (front) pulley,
note: be sure to feed belt through all medal guides on the bottom of the tracoitr or else the belt will continue to fall off.
May 02, 2011 | Poulan Pro 46Inch 22 HP Yard Tractor with...
We have a 48" 23 hp poulan pro riding mower, our problem is the drive belt from the engine to the deck is always breaking, this is the 4th one we bought this summer. what could be the problem
More than likely, you are using a automotive belt not a "V" belt. Automotive belts are pretty tuff but can not stand up to the beating a mower takes. Go to your mower place and get the proper size "V" belt for your Poulan. Make sure it is both the proper size and a quality belt. I recommend "Gates" belts.
When you start your mower, start it with the engine at slow speed, to lessen the shock that the belts and clutches take.
Thanks for your interest in FixYa.com
Aug 16, 2010 | Poulan Pro 46Inch 22 HP Yard Tractor with...
May 28, 2009 | Poulan Garden
I need repair parts for poulan pro 240 42 cc recoil pulley
I would go to Poulanpro.com and look at a breakdown and get your part numbers there. If not give me the model number and I will go to a couple other sites I know and try and help that way.
Feb 19, 2009 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Poulan 42-Inch Steel Deck 17.5 HP Briggs & Stratton I/C Engine With 6 Speed Logo
137 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
